#1 |
Headlight vibration
Hi everyone, I have a slight vibration on my pilot headlight (bixenon), I have already secured bolts and the lower part of the casing because it was a little bit loose.
I've noticed that when I smash the headlight softly with my fist, the projector is somehow loose. When I drive this vibration is very evident on the road. Is there any adjustment that can be done inside of the casing for the projector? I don't want to mess something with the autoleveling. Any help would be appreciated. |
#2 |
Well, hit it on the upper part, you know what I mean.
#3 |
I misunderstood - I thought the light bulb was loose - but you are saying that the projector is loose. - I suggest taking it apart - find the DIY for angel eyes and use that info to take the light apart so you can remove the chrome shroud and check for something loose.
#4 |
Thank you, will try that way!
| Tags |
| headlight, vibration |
