Old 04-14-2011, 09:21 PM   #21
desi-e46
My Ride: 4dr e46
I have ordered the harness also, will let you know the results once i install the harness.
desi-e46 is offline   Reply With Quote
Old 04-15-2011, 01:11 AM   #22
Rajput
My Ride: 2001 325i 5MT
Thanks bro... @Desi-e46, Hor kidan fe NY da haal..
Rajput is offline   Reply With Quote
Old 04-17-2011, 10:39 PM   #23
nadeemp8
My Ride: 05 325i
Installed the harness today, and the damn high beam light still flashes on the dash when I turn the fogs on...wtf!!
nadeemp8 is offline   Reply With Quote
Old 04-17-2011, 11:21 PM   #24
sillieidiot
My Ride: '06 AW 330ci
did you install it right? Check your connections
Old 04-21-2011, 02:10 AM   #25
Rajput
So, what happened people? Installed the harness or no? Whats the update on this?
Old 04-21-2011, 08:11 PM   #26
rizwan1377
My Ride: 04 M56,LC 100,RX300
Send a message via AIM to rizwan1377 Send a message via MSN to rizwan1377 Send a message via Yahoo to rizwan1377
When my headlights are on, and i turn on the fogs the high beam indicator doesnt light up but when i headlights and fogs are both off and I turn the fogs on the high beam indicator comes on. Do you all have the same problem? I have a harness also, when i'll install it i'll post the results.
rizwan1377 is offline   Reply With Quote
Old 04-25-2011, 01:59 AM   #27
Rajput
Another bump for you guys? Whats the outcome on this? Your issue is resolved or no?
Old 04-25-2011, 03:51 AM   #28
sillieidiot
it's because the fogs are not made for HID at all. but yes, it's isolated to the fogs only. doesn't matter if the headlights are on or off.
depending on how cheap/crappy the relay is, you might need a diode to keep power from going back. i'm guessing this might be a problem for those of you that installed the harness (correctly anyways) and are still having a problem. either that, or the damage to the lcm/lsz is too bad for the harness to help.
Old 04-25-2011, 10:18 AM   #29
Solidjake
Zero. Leaks.
Solidjake's Avatar
My Ride: '02 330i 6MT
I put in the wiring harness from DDM and plugged both male ends to the ballasts and only one female end to the factory wiring. My electric surge when turning on the lights is GONE. It really did make a world of a difference.
Refresh Your Lights Here - Projector Retrofit - Angel Eye Install Guide
Youtube DIY Videos/Guides - Electric Fan Swap - NY to LA cross country
Orion V2 - Osram CBI Low - ZKW Clear Lenses - Osram Rallye H7 - Morimoto XB Fog
Old 04-25-2011, 06:48 PM   #30
cuz.iknim
My Ride: 2004 325xi
Send a message via AIM to cuz.iknim Send a message via MSN to cuz.iknim
I didn't think this would cause any problem. I guess I need to buy the harness but, now where do I install this? do I install in behind the fog HID kit that I currently have installed? or does it go somewhere else?
cuz.iknim is offline   Reply With Quote
Old 04-25-2011, 06:55 PM   #31
cuz.iknim
My Ride: 2004 325xi
another quick question. I have one of my low beam ballast(p46) out for about 2 weeks now. I am looking for the new set instead of just purchasing replacement ballast.
But I just realized that my angel eye went out. I checked my fuse and it was blown. Replaced it, and it blowed again.
So I replaced with higher Amps fuse, and only one side of the angel eye came one (where I have good ballast).
Does low beam ballast have any relation to the angel eyes on p46s? I have no idea why only one side of angel eye is working. I have had p46s for about 2 yrs now...
Old 04-25-2011, 07:05 PM   #32
rizwan1377
the one I bought had the instructions:
Installation
Connect #4 and #5 to HID ballast
Connect #1 to battery positive
Connect #2 and #3 to ground
Connect #6 to stock harness or the wiring from the HID bulb and then to stock harness
Old 04-25-2011, 07:07 PM   #33
rizwan1377
I haven't installed it yet, so I can't tell the difference.
Old 04-25-2011, 07:51 PM   #34
Solidjake
Zero. Leaks.
Solidjake's Avatar
Some harnesses vary but it's like this
Power
Ground
Two male plugs to ballast
One female to ONE factory wire, if the harness comes with an extra just tape it off
That's it
Old 04-25-2011, 08:13 PM   #35
Schnitzer325ci
My Ride: BMW 325ci Schnitzer
Send a message via MSN to Schnitzer325ci
Power
Ground
That's it
Jakes the man!
Sent from my iPhone using BimmerApp
Genuine AC Schnitzer
Genuine AC Schnitzer 19's Type III
Genuine AC Schnitzer Short Shift
Genuine AC Schnitzer Pedals & Ebrake
Genuine Bi-Xenon Retrofit
BMW Dice iPod Connect
Smoked LEDs, Sides & Repeaters
Privacy Glass
Black Grills
Purple Angel Eyes
Imola Red M3 Leathers - SOLD
More to follow...
WRITTEN OFF BY SOME PUNK BYATCH!
Reppin the U.K
Schnitzer325ci is offline   Reply With Quote
Old 04-26-2011, 06:44 AM   #36
sillieidiot
sounds like you have a short in the system. probably from the bad side of the angel eyes. most likely the inverter. do not replace the fuse with a higher one. defeats the purpose of a fuse if you do that lol
the angel eyes should not be connected to the ballast for xenons in anyway, unless you or whoever installed it somehow made it that way.
Old 05-02-2011, 06:25 PM   #37
cuz.iknim
My Ride: 2004 325xi
Then do I need purchase new set of angel eyes and reassemble everything?
Old 05-02-2011, 07:49 PM   #38
sillieidiot
all you would need is a new inverter, unless you want a whole new set of angel eyes? if you do decide on new angels, i would disconnect everything and make sure the xenons are fine then continue on with the install.
Old 05-02-2011, 10:13 PM   #39
Rajput
I gave up. I am back with halogens.. Probably gonna get yellow bulbs when I get a new bumper.
Old 05-04-2011, 01:31 PM   #40
cuz.iknim
My Ride: 2004 325xi
Installation
This would make sense if I was working in the headlight.. but this is Fog light that we are talking about.. how would you connect it to battery?
