Old 05-02-2011, 08:36 PM   #81
jacobs323i
My Ride: blown 323i
the fan blades on all turbos do that over time that is perfectly normal
jacobs323i is offline   Reply With Quote
Old 05-03-2011, 10:29 AM   #82
zx5rider
My Ride: 03 M3 , 03 TT 330,
Send a message via AIM to zx5rider
Oh ok
Sent from my ADR6400L using Bimmer App
'03 330 Technique Tuning Stage 2 Turbo. (Parting out)
'03 M3
'11 BMW s1000rr
zx5rider is offline   Reply With Quote
Old 05-03-2011, 12:05 PM   #83
zx5rider
So who's gonna help me put it back together
'03 M3
'11 BMW s1000rr
Old 05-03-2011, 12:51 PM   #84
MaverickM3
My Ride: gets badge
Your kinda far away from me. Lol
MaverickM3 is offline   Reply With Quote
Old 05-03-2011, 02:00 PM   #85
PEI330Ci
58mm of Bliss
PEI330Ci's Avatar
My Ride: 330i, 330Ci
Originally Posted by Pir4t View Post
The burnmarks(might be "rust" from the nearby metal too) on the sparkplugs are fine if the plugs have been used for abit of time, although in rare cases it can be that they leak exhaust gasses.
The color of the plugs isn't the issue, it's the tip of the ground strap that's been melted. The edges should be square, and sharp, not rounded.
Secondly, the heat mark is not visible on the ground straps....clean them up with brake cleaner and we'll have something that tells the real story....
If I had the time and was closer, no problem....
Old 05-03-2011, 03:17 PM   #86
zx5rider
Okay will do now.
So I just came from the machine shop and was talking to them about the engine.
1. They told me they need the pistons, mainly the rings to finish the block. Does that sound right? I'm really with remembering sometimes, but it has to do with the gap on the rings where the ends come together.
2. They also wanted to know how much boost I was planning on running(told them around 15psi) and the compression ratio.
'03 M3
'11 BMW s1000rr
Old 05-03-2011, 03:20 PM   #87
aggieE46
Keep it clean
aggieE46's Avatar
My Ride: 03 Evo, 07 Passat
Yes, the shop will want to test-fit the rings for proper gap. If it's too little, they'll grind away a bit (evenly on both sides) to get it perfect.
Old 05-03-2011, 05:15 PM   #88
PEI330Ci
58mm of Bliss
PEI330Ci's Avatar
Okay will do now.
They are asking the right questions.
They will need the pistons, rings, rod bearings, main bearings, rods, and the block that you've provided already.
Most important, you need to tell them the power you plan to make, (Sounds like around 500 crank hp) and what oil you will be using. The reason is that the more power you make, the more the rings will expand as they transfer that heat to the cylinder walls. There is a general formula for how much ring clearance X bore size X power. The oil type will help them make sure the bearing clearances are right when they check them all prior to final assembly.
For the machine work and clearancing, they will need the following torque values when working with fasteners:
Rod bolts: 5nm, then 20nm, then 70 degrees
Main bearing cap bolts: 20nm, then 70 degrees
Last, your pistons will be lighter, so it's advisable to have the crank balanced to compensate for this.
I would also highly suggest an ATI Super Damper for your engine, as well as one of Greg's oil pumps.
What head studs/bolts are you planning to use again?
As a point of reference, I pay around $2k for a block to be machined and assembled, and to have a head stripped down, blueprinted, and re-assembled. That's just machine work and labor. The parts being used are extra....
Old 05-03-2011, 05:24 PM   #89
zx5rider
Figured I'd just go with the studs that Nick supplies with the stage 2.
Where can I get that oil pump? I saw your thread on it.
'03 M3
'11 BMW s1000rr
Old 05-03-2011, 06:55 PM   #90
SweTurbo
Big Pimpin'
My Ride: 323i -98
You could gap the rings yourself using a dial(idk if thats the proper english term)
On another note What kind of HG are you planning on using ?
Old 05-03-2011, 06:59 PM   #91
zx5rider
victor reinz .7mm Head Gasket
'03 M3
'11 BMW s1000rr
Old 05-07-2011, 10:40 AM   #92
zx5rider
Can someone tell me what I did wrong. When I originally replaced the CCV, I had to remove the dipstick and ever since then it was blowing a lot of oil from the dipstick/oil pan area. If there a gasket i should have replaced or something?
'03 M3
'11 BMW s1000rr
Old 05-07-2011, 11:17 AM   #93
aggieE46
Keep it clean
aggieE46's Avatar
There's an o-ring on the dipstick tube. Might need to replace that.
Old 05-07-2011, 01:09 PM   #94
McSpeed
My Ride: 2005 ZHP TT Stg 1
Yeah & make sure you cover it in silicone grease and put it on the dipstick tube before forcing the dipstick back into the oil pan - otherwise the o-ring will get cut, which is probably what happened to begin with.
SOLD but fondly remembered...
Technique Tuning Stage 1 Turbo w/ Greddy Profec B Spec II | 3.07 Quaife
ATI Super Damper | Vaio Oil Pump | VAC Pan Baffle | SRE Organic Clutch
Turner Reinforcements | SPC Camber Arms | Powerflex FCABs & SFBs
Turbo Driveability Video
Horsepower vs. Torque
McSpeed is offline   Reply With Quote
Old 05-07-2011, 09:24 PM   #95
zx5rider
Oh ok cool thanks
'03 M3
'11 BMW s1000rr
Old 05-07-2011, 09:40 PM   #96
McSpeed
Oh ok cool thanks
Also- there'll be a definite 'click' feeling when it goes in (after applying an incredible amount of downward force).
Old 05-07-2011, 11:47 PM   #97
Steven747
My Ride: 05 330ci
awsome thread of F/I infor i cant wait to see the final product and 15 psi? on a TT kit whats stage 2 come from Nick at? and i believe around 375 crank for stage 2 is what i rememebr is there a stage 3 or 4 now?
Old 05-08-2011, 08:50 AM   #98
zx5rider
Its 375 at the wheels because if thats the case then my stage 1 is faster I dynoed about 320 hp at the wheels.
and right now there is no stage 3 or 4.
'03 M3
'11 BMW s1000rr
Old 05-08-2011, 11:07 AM   #99
PEI330Ci
58mm of Bliss
PEI330Ci's Avatar
Stage 2 is the last official "kit", but there are a number hardware changes a person can make that will bump power above this level. The problem is that so many parts need to be upgraded once you get above Stage 2 power levels, that most people with 330s won't be able to justify the cost. Nick is open to discussing hardware additions, but it would be on a strictly case by case basis. I really don't think there's a business case to offer a kit above Stage 2.
The good news is that if you do decide to add the supporting mods, the Technique Tuning kit is very well setup to accommodate the added airflow because it's a "blow through" system. Porting the head, adding mild cams, or adding a huge open exhaust will be "seen" by the MAF so the appropriate amount of fuel can be added. It won't run as smoothly as the Stage 2 tune, but you'd probably be pretty close.
Or...you can pay Nick to do a custom tune by sending him your car.
Old 05-08-2011, 11:42 AM   #100
Rob43
Rob43's Avatar
My Ride: 03 331Ci 5spd R1200R
Originally Posted by pei330ci View Post
they are asking the right questions.....
I would also highly suggest an ati super damper for your engine, as well as one of greg's oil pumps.....
BIG Yes & Yes.
There's no sense in having 415WHP that's constantly running through high RPM
without a little insurance.
Any mention of a new clutch ?
Good luck
SUMMIT POINT WV 1:24:229 SCCA
