#1 |
I was driving around on my 99 328i sedan
and the suddently the ! sign pop put on the dash next to the D on my dash... the ! sign have a gear sign around it .. ![]() I've check what the sign means, and its my transmission, shut the car off, went see fast five , worried.., after the movie, the sign went off and drives fine is it a sign that my transmission is going bad ? any idea ? help ? suggestion ? Help please fanatics : (
#2 |
Does it look like this? If so
k.
#3 |
yea dude, you should get your tranny checked out!!!
I turn my car on and this happens, i think its time to junk it Last edited by E46tknv; 05-03-2011 at 10:45 PM. |
#4 |
Mod
He's talking about this
http://img241.imageshack.us/img241/9976/0606002226.jpg |
#5 | |
k.
#6 |
Sol?
#7 |
Mod
So out of luck. Search the forum for transmission light
#8 |
You have to read the codes - mine was the clutch solenoid, I changed it and it is ok now
The technical term is Pressure regulator,convert.lockup clutch part# 24327532013 on a 2000 323ci |
#9 |
fixed
k.
