DIY: hid retrofit on a budget! (for halogen lights) - E46Fanatics E46 BMW Social Directory E46 FAQ 3-Series Discussion Forums BMW Photo Gallery BMW 3-Series Technical Information E46 Fanatics - The Ultimate BMW Resource BMW Vendors General E46 Forum The Tire Rack's Tire Wheel Forum Forced Induction Forum The Off-Topic The E46 BMW Showroom For Sale, For Trade or Wanting to Buy
Thread Tools Search this Thread Rating: Thread Rating: 173 votes, 4.93 average.
Old 05-01-2011, 08:19 PM   #1
fat-marshmellow
My Ride: ///M3 SMG
Exclamation DIY: hid retrofit on a budget! (for halogen lights)
Hello fanatics, this is my DIY on xenon/hid conversion if you have OEM halogen lights and don't want to spend money on buying OEM or DEPO projector headlights. Personally I do not like the looks of the DEPO headlights as there is a day and night difference in the appearance of them. This is a DIY on a budget...the total cost was less then buying a set of DEPOs and at the same time the performance and looks of the headlights is significantly improved.
The retrofit hid I used is the Morimoto Mini H1 bi-xenon projector that can be purchase from Umnitza or TRS. Why did i choose this instead of the FX-R? Well like I stated I am doing this on a budget and it's easier to retrofit because you don't have to do any cutting or trimming.
They fit right into the bulb holes in the halogen lights and doing a D2S conversion costs more money for the ballasts/bulbs and a lot of cutting. I paired them up with a set of 6000K H1 bulbs and ballasts from ddm tunning and the results were amazing considering they use the same clear lens found in the FX-R or so theretrofitsource says....
the parts you need...
*1 pair of morimoto mini H1 projector -
https://www.theretrofitsource.com/co...l#.Vn1VjvmANBc
*1 pair of e46 replica shrouds - (I bought the budget ones for $15)
https://www.theretrofitsource.com/co...l#.Vn1V6PmANBc
*1 pair of whatever kelvin hid H1 lights/ballast
https://www.theretrofitsource.com/co...l#.Vn1WCfmANBc
*or the entire kit with the wiring harness:
https://www.theretrofitsource.com/co...l#.Vn1VsvmANBc
Total amount for this whole DIY should be roughly $250, less then DEPO reps!!!
You can also buy the complete kit here:
https://www.umnitza.com/hid-projecto...h-options.html
Select: no accessories, no angel eyes, LHD for US, H1 mini projector, 5000k temp for pure white, superslim three5 ballasts, H1 standard bulb and E46 R shrouds. Comes to $225 plus shipping
*Optional, flat black paint
tools you need
*Philips screw driver
*Flathead screw driver
*Small needle nose pliers
--Do this at your own risk, I am not liable if things do not go accordingly or any damages that may occur to you or your headlights--
Here is a video by Solidjake
To start off, remove your headlights from the car...
Then take your headlights apart following this thread.
http://forum.e46fanatics.com/showthr...lace+headlight
you should have this by the time you are done.
*Optional - you can knock out this H7 adapter if you so choose, the projector should twist right in even if you dont knock it out but I didn't know that until I already took it out so I just left it out.
Heres the projector nice and pretty
The back of the projector, you are going to need to remove the backing, to do so just unscrew the 3 small philips screw drivers and everything should come apart. Don't lose the screws though.
How is should look like with the backing off
Here's the package of goodies that should come with the projectors
Now take this white rubber piece, the package comes with 2 different size white rings but I chose to use the larger one so the projector will sit farther up in the housing.
Put that rubber ring on the projector like so
Now put the projector through the bulb opening in the housing and use this part and twist it on the back of the projector
It should look like this when its on, you will need a small needle nose plier to twist it on snugly, after it's in there nice and tight put back the bulb holder with the 3 small screws.
Here's how it looks like when it's in there
Make sure the part that says TOP is on the top!!
Hehe my workspace...nice and clean
*Optional - if you choose to paint your housing and shrouds, like me, then you need to remove the projector again otherwise you may leave it in and skip these next couple of steps.
I decided to paint my housing and shrouds flat black. I used regular Krylon flat black paint found at any store ie walmart, home dept and such.
Once the paint is dry, re-assemble the projector into the headlight.
On a side note, if you want to hook up the bi-xenon feature you will need to drill a small hole to run the wires through from the housing.
As far as mounting the shrouds, this setup will NOT have the auto leveling feature so what I did was use BLACK RTV silicon and apply a light amount onto the back of the shrouds and the edge of the projector. Be very careful not to get it on the lens!
The rtv should dry in about an hour or so but I couldn't wait so I cheated and used a hair blower to speed up the process hehe...Once it's dry, it's time to assemble the headlight together, assemble is the same as taking it apart just backwards...
While your at it, add some angel eyes or so to add to the already so sexy headlights.
Once everything is assembled it will look like this...(while your at it, clean up your lenses!!!!)
Now mount them back on to your sexy e46 and install your hid lights. Sorry I don't have any pictures but if you got a kit from ddm like me the install should be straight forward without any wire splicing or cutting. The only hard part is finding where to mount the ballast so I mounted mine behind the bumper support with a couple of zip ties. This is also a good time to wire up the bi-xenon feature also.
Now comes the hard part, aligning the lights. Follow the guide for hid alignment for up and down leveling
http://www.diymybmw.com/e46/aligning-xenon-headlights/
To get perfect alignment horizontally you will need to make sure the projectors are lined up as horizontal as possible, tighten the back nut and turn the lights on on the car to see how they look. If they are still a bit crooked then loosen the back nut and turn the projectors as needed and try again.
_________ __________
__________ / ___________/
You will need to make sure the projectors are lined up as horizontal as possible, tighten the back nut and turn the lights on on the car to see how they look. If they are still a bit crooked then loosen the back nut and turn the projectors as needed and try again.
Now comes the hardest part, waiting till nightfall to test out your lights....and TADA!! This is what it should look like!!!
Notice the beautiful blue cutoff!!! (this is with 6000k bulbs)
Here's a shot with the angel eyes and the hid's on
Here's some daytime shots of them on my car, they really do add some sexyness to the car!!! lol
Thank you for looking at this DIY, this is my first diy so be nice with me hehe. Like I said this DIY is for us with halogen headlights that want xenon hids with projectors without paying an arm and leg for. This is a simple little mod if your on a budget....somewhat ghetto, but hey it works hehe
Sorry I could not get anymore pictures, I sold the car a couple months ago =( and these were all the pics I can find on the memory card. Any questions please feel free to ask
ex: 2002 TIAG 325xi (sold), 2007 suzuki gsxr (sold)
current: 2002 carbon black ///M SMG
halogen headlights? want hid projectors? on a budget? maybe i can help! go here!!
http://forum.e46fanatics.com/showthread.php?t=840919
fat-marshmellow is offline   Reply With Quote
Old 05-01-2011, 08:27 PM   #2
sillieidiot
My Ride: '06 AW 330ci
looks good, good job. i wish you didn't go with ddm bulbs though, the output from their bulbs are poor. but i guess it's better than nothing on a budget
Old 05-01-2011, 08:30 PM   #3
fat-marshmellow
My Ride: ///M3 SMG
thanks =D
Old 05-01-2011, 08:41 PM   #4
infinite012
My Ride: White '08 STI
Looks great. I was wondering if the Morimotos would fit in the OEM halogen headlights. My question has been answered.
Now we can refer the noobs to this thread if they ever ask "what's the best HID kit omglolhai!?"
infinite012 is offline   Reply With Quote
Old 05-01-2011, 08:51 PM   #5
fat-marshmellow
My Ride: ///M3 SMG
haha yea the morimoto fits nice with the halogens without any modification to the housing at all. i was afraid they werent going to fit too but i figure oh well ill just do it lol...
Old 05-01-2011, 11:20 PM   #6
fat-marshmellow
My Ride: ///M3 SMG
yea i know the bulb quality and output was not that good. i will find a better setup next time, but i dont have the car anymore but yep better then nothing
Old 05-02-2011, 01:13 AM   #7
bwallace530
My Ride: 325
Great DIY I am going to be doing this soon.
Thanks for making this.
bwallace530 is offline   Reply With Quote
Old 05-02-2011, 03:55 PM   #8
Tate325xi
My Ride: 325xi 5MT
Great write up
-Tate
Originally Posted by 217Bimmer View Post
sometimes i'm into it and my one hand gets tired, i try switching, but then it's like someone with lou gehrig's trying to peel a carrot.
Tate325xi is offline   Reply With Quote
Old 05-05-2011, 11:52 AM   #9
honkifyoubonk
My Ride: E 6666
a few questions, did you get the h7 adapter plate? (obv . my car takes h7 bulbs now but idk) and what kinda of wiring did you have to do if any?
would this be sufficient for the bulbs and ballasts? im a little confused on the options for the kit though? any help would be appreciated.
http://www.ddmtuning.com/Products/Ap...Raptor-HID-Kit
honkifyoubonk is offline   Reply With Quote
Old 05-05-2011, 02:05 PM   #10
n3985
My Ride: E92 soon?
Great DIY, I wonder if the same process can be used to add the projector to the high beam for us with OEM Xenons resulting in a cheap quad projector setup.
n3985 is offline   Reply With Quote
Old 05-05-2011, 02:21 PM   #11
infinite012
Everything you need is sold as a kit from www.theretrofitsource.com
Old 05-05-2011, 06:50 PM   #12
honkifyoubonk
My Ride: E 6666
that is more expensive than buying everything in parts listed by the OP..
Old 05-05-2011, 07:00 PM   #13
infinite012
Good luck ordering and receiving your order from DDM. I hear their HID kits are stuck in the ocean or some such nonsense.
Old 05-05-2011, 08:57 PM   #14
psan03
My Ride: 2003 BMW M3
Will this throw an error?
psan03 is offline   Reply With Quote
Old 05-05-2011, 08:58 PM   #15
psan03
I wonder the same thing...maybe someone can chime in on this
Old 05-05-2011, 09:08 PM   #16
xaviman
My Ride: Supercharged
thissssss is awesome .. i have been waiting for this for a looong time.
Screen shot 2014-01-25 at 12.36.33 PM by xaviman, on Flickr
Instagram: xaviman
xaviman is offline   Reply With Quote
Old 05-05-2011, 10:03 PM   #17
sillieidiot
i'm pretty sure it can, on the halogen bowls, but the highs and lows look exactly the same except the high beam bowl is pointed more upwards.
Old 05-06-2011, 10:16 AM   #18
fat-marshmellow
My Ride: ///M3 SMG
yea that would be the kit, and as far as the adapaters, the projector will come with it when you order the projectors off of theretrofitsource.com
you can use it in the highbeam bowls but like stated above, it wont benefit the highbeams much...you just have quad projectors but for light perfomances, its a bi-xenon, hook it up, get it flashed and just leave the highbeams for flash to pass lol
nope it wont
Old 05-06-2011, 01:19 PM   #19
Solidjake
Zero. Leaks.
Solidjake's Avatar
My Ride: '02 330i 6MT
Extremely nice write up. I wish this was done sooner so I can show the lighting noobs what to do.
Old 05-07-2011, 11:44 AM   #20
fat-marshmellow
My Ride: ///M3 SMG
lol its not too late yet, im sure there will be more new members on here with questions...just hope they search hehe
Rate This Thread
