Go Back   E46Fanatics > Tuning & Tech > Suspension & Braking
Old 05-09-2011, 11:04 PM   #1
Jkim
My Ride: needs work...
10mm spacer needs custom work to fit??
so i was looking for 10mm spacers and came upon Turners site.
"A note about 10mm spacers: Any 10mm spacer is considered a custom fitment. The stock hubcentric lip on BMWs can stick out by as much as 11mm. This leaves a gap between the spacer and the hub which seriously compromises safety. We recommend using a larger spacer (12mm and larger do not have this issue) or check that the lip sticks out less than 10mm."
and they said if you do go with a 10mm, to file down the lip on your car so it sits flush... anyone use a 10mm? any input please? THANKS!
Jkim is offline   Reply With Quote
Old 05-09-2011, 11:19 PM   #2
TrippinBimmer
My Ride: ZHP Custom Stage 3.5
Mine sit flush on the hub but not on the Wheels Face. I have to run a 1-3mm spacer for the DPE to be FLUSH.
-TrippinBimmer
Old 05-09-2011, 11:26 PM   #3
Jkim
Should I just get a 12mm then?
Sent from my HTC Glacier using Bimmer App
Old 05-09-2011, 11:37 PM   #4
TrippinBimmer
I think it's due to my wheels not spacer. Should work fine tho.
Sent from my iPhone using BimmerApp
Old 05-09-2011, 11:39 PM   #5
Jkim
appreciate your input. yea, ill probably go with the 12. slightest difference in size, and hopefully i wont have to deal with it for any type of wheels or suspension i get.
