Forced Induction Forum Sponsored by Active Autowerke
Discuss supercharging, turbocharging and even nitrous and water injection here. Sponsored by Active Autowerke |
#1 |
HPF Guys, what plugs are you running?
So.. i'm having issues with the car running a bit rich, carbon build up on the plugs and eventually leading to what I believe to be high resistence and spark/ignition issues after about 1500mi.
What plugs are you guys running? I'm running the NGK Racing plugs, rated at a 10 for coldness. Is it possible the plugs are just to cold and I should be running the Denso Iridium's that the 2.75/other guys are running, or do I just need to have my tune adjusted? Here is a plug after 250mi or so w/no meth/race gas.. and almost no boosting: ![]() Here they are after about 1500mi with plenty of boosting, race gas, 91, meth, etc.. ![]() At the point the plugs get to where they look like the above the car begins to misfire (feels just like traction control) at about 4krpm.
#2 |
They're NGK-R R2525-10's.. I'm wondering if R2525-9's wouldn't be better?
#3 |
We should get some other Stage 3 guys to pull theirs and show us what they look like.
#4 |
That would be incredibly helpful. I'm pretty sure I'm running rich though, at mid 12's at idle.
#5 |
I will have Aaron (my personal mechanic) pull one for you next week.
I am running the "stock" stage 3 plugs that HPF built the car with; zero issues.
I can do everything through Christ who gives me strength.
Philippians 4:13 ![]() |
#6 |
Sweet. You've got about the same miles on yours as I do on the one high res one I pictured above. Maybe you have a little more now.. but it would be a great comparison. I'm not sure if you can see the numbers on the plug indicating if its a R2525-10 or R2525-9 but that would be helpful as well. Unless you're running Denso's, or some other variant.
#7 | |
![]() ![]() ![]() So true, lol. Side note, are you coming to Bfest? You can ride shotgun with me in the M5. I just got all my upgrades installed today, including the ESS software tune; WOW, what a BEAST she is now - seriously!!!! I am STOKED!
Philippians 4:13 ![]() Last edited by AirFrcd; 05-11-2011 at 09:10 PM. |
#8 | |
Big Pimpin'
#9 |
Psshhhht M3
Ixu27's here and they work pretty well for me. Changed them once so far after I noticed a small stuttering issue. I actually tried those plugs you have and my car would not run well at all.
#10 |
Not sure if the built motors take a different plug, but I was told to not use anything but Denso. I believe they tested the NGK and they just did not perform well. Of course, there is absolutely no place in my town that sells the Denso.
#11 | ||
Identical issue. Pull your plugs.. check em out.. bet they look the same. Quote:
Thats what I've seen all the 1-2.75 guys running.. maybe I should try those?
#12 |
Psshhhht M3
I tried the 9's, no good for me. Don't play too much with plugs tho, they are sensitive. The ixu27's have been good to me, my car runs alittle rich as well. These cars love fuel! Btw, I wouldn't listen to people on other forums with no experience.
#13 |
Jason has to have put a good 500-1000 miles on his car driving around the west coast. I wonder what he's running. Same w/MyTran.s
#14 | |
My Ride: 05'M3, 03 996TT
Looking at the video, symptoms are definitely not the same and you guys are good since Stage 3+ includes the Okadas. Also I am not putting nearly the same whp you guys are
![]() Best ET 11.93 Best Trap 134 Last edited by 02black330ci; 05-11-2011 at 10:38 PM. |
#15 |
You could
#16 |
LOL, agree, Stage 2.75 or 3 will be in my future, got other projects going on though
![]() Best ET 11.93 Best Trap 134 |
#17 | |
#18 | |
Mhhh taking the beast M5 instead of your monster M3? I think your M3 needs to stretch her legs ![]() Marcus, Yeah your car is running rich for sure....that is a lot of build up. My car idles at 14.2-14.6 afr which should be normal
05 BMW ///M3 SMG - Jet Black/Gray
HPF Stg2 Turbo 640rwhp, Eisenmann Race 83mmx4, Volk TE37 TA, Toyo T1R, Brembo BBK 380mm 6pots & 345, 6k HID, 6K HID Fogs, Depo Smoked Corners, Strassentech Front Lip, V-CSL Bootlid, V-CSL Diffuser ![]() Last edited by leletyM3; 05-11-2011 at 11:14 PM. |
#19 |
Ixu27's here, I tried the race plugs you had but they fouled up really fast.
#20 |
Psshhhht M3
Exactly!
