Go Back   E46Fanatics > Tuning & Tech > Forced Induction Forum Sponsored by Active Autowerke
Old 05-08-2011, 06:57 PM   #101
zx5rider
My Ride: TT Turbo 2003 330i
Send a message via AIM to zx5rider
Stage 2 is the last official "kit", but there are a number hardware changes a person can make that will bump power above this level. The problem is that so many parts need to be upgraded once you get above Stage 2 power levels, that most people with 330s won't be able to justify the cost. Nick is open to discussing hardware additions, but it would be on a strictly case by case basis. I really don't think there's a business case to offer a kit above Stage 2.
The good news is that if you do decide to add the supporting mods, the Technique Tuning kit is very well setup to accommodate the added airflow because it's a "blow through" system. Porting the head, adding mild cams, or adding a huge open exhaust will be "seen" by the MAF so the appropriate amount of fuel can be added. It won't run as smoothly as the Stage 2 tune, but you'd probably be pretty close.
Or...you can pay Nick to do a custom tune by sending him your car.
Speaking of that.....
Would it be a bad Idea to(once the car is done)drive the car down to nick with the Stage 1 tune? That should be safe right considering ill have the 8.5psi spring in? I guess it will actually be a little bit slower with with the lower compression.
Oh and yes supporting mods indeed
I plan on getting new/stronger clutch and LWFW.
LSD
Not sure if I will use factory engine mounts or not I have 2 brand new ones laying around.
Not sure what else I need.
All in all the reason I'm doing this is not because I want more power but because I blew the engine sucking up water a few times.
Technique Tuning Turbo Stage 2|Magnaflow Catback|Tein Super Street|EAS Eagle Eyes Tail Lights|3500k Fogs|ATR CF Power Buldge Hood|BMW Performance CF Strut Bar|Dynavin V5|Infinity Reference all around
2011 BMW S1000rr
zx5rider is online now   Reply With Quote
Old 05-09-2011, 12:17 AM   #102
calialx1
My Ride: FL 330i, 3000GT
I wish I had the guts to do what you are doing.....I'm too chicken **** to touch any thing beyond the valve cover gasket.
calialx1 is offline   Reply With Quote
Old 05-09-2011, 12:29 AM   #103
Steven747
My Ride: 05 330ci
+1 perfectly worded ill just pay someone to do things above vcg
Old 05-09-2011, 12:33 AM   #104
BimmerDude18
My Ride: 1998 528i
Driving on the stage 1 tune should be fine, low compression tunes can run more timing at the same boost levels, so you should be safe as long as your EGT's aren't out of control.
-Tyler
1998 528i 5-speed Work in progress
1988 Toyota Pickup (4WD 5-speed) daily
2007 San Marino Blue 350z 6-speed sold
1996 328i 5-speed sold
www.e46nonM.com - www.precision-sport.com - www.flyingwindowtinters.com - www.techniquetuning.com
BimmerDude18 is offline   Reply With Quote
Old 05-09-2011, 03:08 AM   #105
Rob43
My Ride: 2003 BMW 331Ci, 5spd
I plan on getting new/stronger clutch and LWFW....
LSD
Keep in mind that your stock Duel Mass Flywheel acts like a harmonic balancer
on the back of your motor. When you go to a LWF, it's like removing one of your harmonic balancer's. And the front one is not that great to begin with. Chances of having a high RPM oil pump failure now go way up. That's why PEI330CI & I both recommend getting the ATI dampener and the Greg Smith "vaio76109" Upgraded Oil Pump. Those two pieces would be the best insurance you could put on your new motor.
Good Luck.
SUMMIT POINT WV 1:24:229 S.C.C.A.
http://www.vimeo.com/8486878 (Dyno Video)
........add a sh!tload of cowbell.
Old 05-09-2011, 06:56 PM   #106
zx5rider
Good Luck.
So would it be a good idea to just get a new clutch and keep the stock flywheel?
Because thats about $2300 just for those 4 things.....
2011 BMW S1000rr
Old 05-09-2011, 07:28 PM   #107
BimmerDude18
My Ride: 1998 528i
I won't go into details, but many have good luck with just welding the nut on a stock BMW oil pump. Many of those I speak of are racing their cars (no VIN).
That said, the dual mass is kindof nice in a street car. You won't get gear rattle, and driving around will be easier on you...
-Tyler
Old 05-09-2011, 08:50 PM   #108
Rob43
I will direct you to an old thread by Adam "PEI330Ci", this thread has an extreme wealth of information in it. Take a look at #202 and a response from John "mrshelley" #206
http://www.e46fanatics.com/forum/sho...445340&page=11
Hope this helps.
Old 05-10-2011, 07:40 PM   #109
zx5rider
Hope this helps.
It does help thanks.
Seems like how I'll be using the car I won't have any problems.
Now that my motorcycle is running (and gets 55mpg)I'll still ride that most of the time.
But I think ill have enough to get the Oil pump now and damper later.
Although it does worry me that when I took the oil pan off the nut was loose.
2011 BMW S1000rr
Old 05-10-2011, 10:01 PM   #110
///TRNSPRTR
My Ride: 07 Tundra, 02 M3
Props to you bro for doing this...
///TRNSPRTR is offline   Reply With Quote
Old 05-11-2011, 05:09 PM   #111
zx5rider
Thanks man hows the E60? and did you sell your 330?
I'm get upset that I'm doing this every time I go out side and see my car I just want to go for a drive ha. Motorcycles aren't fun like they used to be.....
2011 BMW S1000rr
Old 05-12-2011, 03:28 AM   #112
giving_birth
My Ride: 316i E46
Keep us posted!
giving_birth is offline   Reply With Quote
Old 05-12-2011, 03:49 PM   #113
zx5rider
Called the machine shop today said they just now got the crank bolt off and It was a lot of work.
2011 BMW S1000rr
Old 05-15-2011, 06:43 PM   #114
zx5rider
http://www.ecstuning.com/ES17871/?gc...FUXe4AodKTNqBw
Is this worth it?
ZHP cams correct?
2011 BMW S1000rr
Old 05-15-2011, 07:15 PM   #115
Steven747
My Ride: 05 330ci
Is this worth it?
ZHP cams correct?
no man those are shown to loose power why dont you get shrick?
Old 05-15-2011, 07:24 PM   #116
zx5rider
Haha O really now? and because i wasn't really looking for cams or spending that much....these are less then half the price.
2011 BMW S1000rr
Old 05-15-2011, 07:40 PM   #117
SweTurbo
Banned User
My Ride: 323i -98
They aren't shown to loose power(if talking about ZHP cams) ?
If you don't upgrade the ECU tune ZHP cams won't give much though.
Old 05-15-2011, 07:46 PM   #118
zx5rider
Oh Yeah the car is getting retuned after all of this.
2011 BMW S1000rr
Old 05-15-2011, 08:51 PM   #119
Rob43
Is this worth it?
ZHP cams correct?
Yes....they're 248/248
I seem to remember reading a recent thread on these, I don't think they made much at all over stock M54B30 cams.
Also, if you did get these,make sure they're HARDENED, if not....well you know where I'm going.
PM sent.
Old 05-16-2011, 05:42 AM   #120
PEI330Ci
58mm of Bliss
PEI330Ci's Avatar
My Ride: 330i, 330Ci
I would keep the OEM cams and put your $$ into getting the engine back up and running. There are costs coming that will surprise you a bit, but it's all part of rebuilding a BMW engine.
