Old 05-16-2011, 10:44 AM   #121
zx5rider
My Ride: 03 M3 , 03 TT 330,
Send a message via AIM to zx5rider
Can you elaborate?
Sent from my ADR6400L using Bimmer App
'03 330 Technique Tuning Stage 2 Turbo. (Parting out)
'03 M3
'11 BMW s1000rr
zx5rider is offline   Reply With Quote
Old 05-16-2011, 11:17 AM   #122
PEI330Ci
58mm of Bliss
PEI330Ci's Avatar
My Ride: 330i, 330Ci
Originally Posted by zx5rider View Post
Can you elaborate?
I don't mean to scare you, but in general everything took me nearly 2-3 times as long to finish than what I initially planned on my first engine rebuild. Probably the most nasty one was receiving the wrong parts from vendors...which I got to foot the shipping bill on. In one case, the part was completely unusable from a well known vendor, and they refused to take any action.
I don't think you'll run into the exact same issues I did, as I can guide you through a lot of this, but there still will be "surprise" $500 costs by the time you get this back together.
Old 05-16-2011, 11:33 AM   #123
zx5rider
Oh ok well I didn't really want the cams I just ran into them so I thought I'd ask.
'03 M3
'11 BMW s1000rr
Old 05-16-2011, 11:43 AM   #124
NickG@TechniqueTuning
Past Site Sponsor
My Ride: E46 330ci Turbo
http://www.ecstuning.com/ES17871/?gc...FUXe4AodKTNqBw
Is this worth it?
ZHP cams correct?
Yes, those are the ZHP cams. I'd get them if I were you.......oh wait, I already did
NickG@TechniqueTuning is offline   Reply With Quote
Old 05-16-2011, 12:19 PM   #125
zx5rider
Too late I just ordered My pistons got CP instead of Weisco.....about a $200 difference.
Vac motorsports are some great people BTW.
Takes 30 days tho
'03 M3
'11 BMW s1000rr
Old 05-16-2011, 12:23 PM   #126
zx5rider
I'm taking donations.
If you have extra......
'03 M3
'11 BMW s1000rr
Old 05-16-2011, 12:24 PM   #127
zx5rider
Sorry but what is hardened?
Originally Posted by Rob43 View Post
Yes....they're 248/248
I seem to remember reading a recent thread on these, I don't think they made much at all over stock M54B30 cams.
Also, if you did get these,make sure they're HARDENED, if not....well you know where I'm going.
PM sent.
'03 M3
'11 BMW s1000rr
Old 05-16-2011, 02:41 PM   #128
Rob43
Rob43's Avatar
My Ride: 03 331Ci 5spd R1200R
This will explain it best. Without this a cheap set of cams will probably fail......quick.
http://en.wikipedia.org/wiki/Case_hardening
SUMMIT POINT WV 1:24:229 SCCA
Old 05-16-2011, 03:02 PM   #129
Past Site Sponsor
So are you saying that a set of factory OEM cams, made and sold by BMW, are suspect to failing?
Old 05-16-2011, 03:50 PM   #130
zx5rider
....are those oem?
'03 M3
'11 BMW s1000rr
Old 05-16-2011, 03:51 PM   #131
Rob43
Rob43's Avatar
That's not at all what I am saying.
Please don't make assumptions for me.
OF COURSE AVL SCHRICK GmbH are hardened, they are Chilled hardened.
"Why are SCHRICK camshafts so special ?
They are machined to precise tolerances,
using the latest CNC machines.
They are usually made from expensive, extremely
wearresistant “chilled” cast-iron.
Warranty: 1 year without kilometer limitation."
CHILLED HARDENED:
"Chilled cast iron outperforms traditional induction-hardened cast iron billets typically found in the U.S. Cast iron cams are typically used for flat tappet applications whereas steel cams are used for roller follower applications.
In this process, surface hardening of the cams is obtained by locating metal chills in the mold. These chills act as quenches which remove heat rapidly. The rapid cooling makes the material near the chill much harder than the surrounding material without the chill. The hardening depth goes much beyond any other process. Other types of hardening only produce a thin "scab" hardness with very soft metal underneath."
Have a great day.
Old 05-16-2011, 08:17 PM   #132
zx5rider
^^^ Anyways On another note. Going against what i was told
I was convinced that going with an 84.5mm bore was pretty much the only option I had.
1 Reason I was told is that the rings only come in .5mm increments and although the engine can't be bored anymore that 84.5 should be fine.
Worst thing that could happen is Re-sleeve.......
So I Ordered the 8.8:1 84.5mm CP Pistons
I'm going to hold off on the ATI Dampener and get a UUC Light weight flywheel+M5 Clutch and Greg's Oil Pump.
How does that sound?
'03 M3
'11 BMW s1000rr
Old 05-17-2011, 02:03 AM   #133
PEI330Ci
58mm of Bliss
PEI330Ci's Avatar
I should consult with you before hand so we can get our stories straight.
One step at a time. Pistons are good.
Next step I would look at are bearings. What are you doing for those?
Old 05-17-2011, 01:24 PM   #134
zx5rider
VAC - M50/ M52/ M52TU/ M54 /S50 (US) /S52 (US) Performance Coated Main Bearing Set
VAC - M50/M52/M52TU/M54/S50 (US) /S52 (US) Performance Coated Rod Bearing Set
'03 M3
'11 BMW s1000rr
Old 05-17-2011, 02:14 PM   #135
BimmerDude18
My Ride: 1998 528i
I'd get the damper before the lightweight flywheel. But I actually like the dual mass flywheels.
-Tyler
1998 528i 5-speed Work in progress
1988 Toyota Pickup (4WD 5-speed) daily
2007 San Marino Blue 350z 6-speed sold
1996 328i 5-speed sold
www.e46nonM.com - www.precision-sport.com - www.flyingwindowtinters.com - www.techniquetuning.com
BimmerDude18 is offline   Reply With Quote
Old 05-18-2011, 09:04 PM   #136
zx5rider
Almost died on my motorcycle now I have nothing
'03 M3
'11 BMW s1000rr
Old 05-18-2011, 11:03 PM   #137
MarcusLSB
My Ride: X5, CT200h, CLK63 BS
Old 05-19-2011, 05:51 AM   #138
aggieE46
Keep it clean
aggieE46's Avatar
My Ride: 03 Evo, 07 Passat
Uh oh.
Old 05-19-2011, 04:47 PM   #139
zx5rider
Yeah its all good now......
Can someone tell me all the tools I will need for the timing.
Is this everything?
'03 M3
'11 BMW s1000rr
Old 05-19-2011, 06:31 PM   #140
SweTurbo
Big Pimpin'
My Ride: 323i -98
Is this everything?
Yes , you don't really need the vanos air fitting or the vanos(single) turning tool.
Any chance you'd be selling this kit when you're done with it ?
