#41 |
I've always used Zimmerman cross drill brakes on my VW's. Now I have a set that is cross drilled and slotted on my 330ci. Never had any issues. They are great rotors. Picked F and R up for 315.
#42 |
their is a big reason why race cars use drilled and slotted rotors lol. They stop better and have way better cooling which is a lot less pressure on your brakes. It also depends on what brand and kind of rotors they are, as well as your brakes pads.
![]() Stretch + poke = All show, no go!!! Last edited by PRDesignsTony; 05-22-2011 at 09:34 AM. |
#43 |
I have had My Stoptech Rotors RED hot and they are slotted and cross drilled. ive had them so hot that my pads actually caught on fire once. but i have never had them crack Ebay ones will crack good brand names wont
Winter Authority When Hell freezes over,we'll play Hockey there too
![]() Its fundamental to our nature, man must explore. you've Met a terrible fate haven't you ? KONI /Michelin/Stoptec/ Bimmerbrake / MTechII/AA Stage one (for now) Questions about Header wrap? clickHere Supercharger build thread click Here |
#44 |
Tinfoilhatatarian
My Ride: .
Posts removed...
Back on track please Enough bickering
Malo periculosam libertatem quam quietum servitium
#45 |
My Ride: have 5 doors and FI
bickering...on such a touchy subject...noooooooooooo not on a forum
![]() /_________\ OO=[][]=OO |
#46 |
They don't all use drilled and slotted rotors, and what makes you think the brakes on a race car operate in even remotely comparable conditions to the average street car?
#47 | |
All truth passes through three stages. First, it is ridiculed. Second, it is violently opposed. Third, it is accepted as being self-evident. - Arthur Schopenhauer
#48 | |
Plus, they make your car stand out from the rest.
![]() Stretch + poke = All show, no go!!! |
#49 |
My .02c .. Drilled rotors look cool.
I wonder what happens when/if one cracks though... I can imagine some pretty violent stuff happening in the brake area.
#50 |
just don't go cheap when it comes to buying brakes and replace them when it's time to.
#51 | |
#52 |
Mercedes when they first introduced their cars with cross drilled rotors, they had a major recal due to majority of the rotors cracking.
We are talking about Benz here, I highly doubt the recal was due to design flaw. it's just fact that less space equals less traction, therefore less grip and performance, not to mention it eats up your pads faster, causes more brake dust. There was also a study somewhere when Benz recall happened, and according to it, if not drilled and designed properly cross drilled rotors will end up heating furthermore than blanks, poor air flow, same with slotted. It sure looks cooler, but you don't **** with suspension and the brakes.. Ever.. If I am on a track that requires ton of braking I would go slotted, on street blanks. My car still looks pretty damn good, and I rather not pay extra money to risk rollover or worse. Last edited by doshu; 05-22-2011 at 01:52 PM. |
#53 | |
#54 |
[QUOTE=mkodama;13195281]And I would say your entire argument is invalid since you don't even know high school level physics.[/]
If you want to prove my theory wrong I am all ears, but if you want to change my opinion you will need more than a neeneer reply. I am open to ideas, and not afraid of being proven wrong. ![]() My wife does that all the time.. Last edited by doshu; 05-22-2011 at 01:53 PM. |
#55 | ||
F: Force due to friction mu: coefficient of friction; varies by material N: normal force, the force "pushing" the two objects together If you notice, area does not come into this equation at all, which is where a lot of people get it wrong. EDIT: I was actually just kinda trolling you, but you gave an unexpectedly mature response so I will take the effort to write this stuff out. Last edited by mkodama; 05-22-2011 at 01:51 PM. |
#56 | |
![]() Shameless Seinfeld insert..... never gets old
#57 |
LULZ this thread!
#58 | |
#59 |
Same reason why a big brake kit won't show huge improvements over a properly designed oem system in a single 60-0 test. A bbk will have larger rotors for heat reasons, not surface area.
![]() ![]() De gustibus non est disputandum. |
#60 | |
Also technically a BBK will generate more brake torque than a smaller diameter brake. If one had a set of tires sufficiently sticky so as to not lock up with stock brakes, then a BBK absolutely will improve 60-0 distances. Torque = F*d*sin(theta) (in this case it'd be just f*d since the force is applied perpendicular to the rotor surface). |
