Old 05-29-2011, 12:37 PM   #1
mjhockey155
My Ride: 330ci
Trailer Harness for LED Lights
I have a 04 330ci with the LED tail lights. I need to install a trailer harness, however, I cant seem to find any information on which wires control the brake lights and turn signals that lead into the circuit board. Below is the link of the harness that I plan on using.
http://www.etrailer.com/p-119176KIT.html
Does any one have a fsm that could possible look it up?
mjhockey155 is offline   Reply With Quote
Old 05-29-2011, 03:00 PM   #2
330ciandr6
My Ride: .
Send a message via AIM to 330ciandr6 Send a message via Yahoo to 330ciandr6
i'd simply use a multimeter and just test em and figure it out.
Have a oil or coolant leak? Click here!:http://forum.e46fanatics.com/showthr...732&highlight=
ABS/DSC/Brake/Airbag light on?? Click here!:http://forum.e46fanatics.com/showthr...648&highlight=
330ciandr6 is offline   Reply With Quote
Old 05-30-2011, 11:01 AM   #3
mjhockey155
My Ride: 330ci
There has to be someone out there that has LED tail lights with a trailer.
Old 05-30-2011, 03:38 PM   #4
E-XLVI
My Ride: 05 330Ci ZPP/ZHP/ZCW
Your post motivated me to post my working diagram.
http://forum.e46fanatics.com/showthr...1#post13224061
PIN7 -taillight ground
PIN5 -taillight on
PIN3 & PIN6 -braking & indicator
Seems PIN3 & PIN6 maybe the interesting connection. Here's some additional info:
http://blog.bavauto.com/bmw-e46/bmw-...-and-converter
I recommend using the kit's circuit tester to review all connections. Then, please post the working connections and wires in the Lighting or DIY forum. Thanks
** assumptions: OEM LED taillights; resistors, etc are on the circuit board. Aftermarket, you'll have to move infront of the external resistor box.
E-XLVI is offline   Reply With Quote
