Old 05-31-2011, 12:35 AM   #1
missamo80
My Ride: 2001 325i
Fixed my airbag light today
Yeah, you guessed it: my airbag light came on. Ordered the Peake tool because I'm sick of the thing going on and having to pay someone to read the code.
Sure enough, code was 03/02: driver's side seat belt tensioner.
e46fanatics to the rescue. I used the search bar () and found lots of threads. It took some reading, but the first thing to try was the wiring harness fix. I ordered the harness for $15 and blindly stuck it in. I thought it was a sure-fire fix since the old harness had two wires clearly broken off it. No dice.
Read through a bit more and figured I'd either have to do the BMW documented solution of splicing around the harness, or replace the tensioner. My money was on the tensioner so I ordered one.
Anyway, today was repair day. Pulled the seat out and cut away the old wiring connector to the tensioner. Then I realized that some mechanic long ago had already applied the harness splice. That's why my connector had two wires cut off it. Had to haul out the soldering iron and shrink tubing to reconnect the two wires I'd chopped off during seat removal thing they were old and unneeded I have to say, whoever did the original repair did a crap job. Electrical tape everywhere instead of proper shrink tubing.
After that little mix-up I swapped in the new tensioner, stuck everything back together, cleared the code, and voila. No more airbag light.
If anyone in the Seattle area ever needs their code read let me know. I have the Peake tool now.
Neil
missamo80 is offline   Reply With Quote
Old 05-31-2011, 03:47 AM   #2
FrancoM
My Ride: 2005 BMW 330Ci
I need to fix my passenger side....
Is there a tutorial??
I'm scared if the airbag pops in my face
FrancoM is offline   Reply With Quote
Old 05-31-2011, 04:34 AM   #3
jetblackmaverick
My Ride: parting out...=(
crap, I may have done the same thing the other day when I pulled my driver's seat to install my dice silverline. I now have an airbag light on. damn it.
jetblackmaverick is offline   Reply With Quote
Old 05-31-2011, 04:37 AM   #4
j_block
My Ride: 2003 325i
my airbag is on too, would it matter if it was on or not, its not like the airbag wont deploy if the light were on, right?
j_block is offline   Reply With Quote
Old 05-31-2011, 08:45 AM   #5
ddombrowski
My Ride: 01 330ci 5spd
Send a message via AIM to ddombrowski
From what I've read, it won't deploy if the light is on.
ddombrowski is offline   Reply With Quote
Old 05-31-2011, 09:06 AM   #6
stevenluczynski
My Ride: Is Steel Blue
before you start working just disconnect the battery and you're safe.
stevenluczynski is offline   Reply With Quote
Old 05-31-2011, 09:18 AM   #7
Viper3812
My Ride: E39 M5, E53 X5
You don't need to unplug the battery or be afraid of it deloying unless your really trying to set it off.
Sent from my MB860 using Bimmer App
Viper3812 is offline   Reply With Quote
Old 05-31-2011, 10:02 AM   #8
myothercarisatruck
My Ride: 325i
Mine is on the passenger seat, and only if someone is sitting in the seat...
If you're gonna be stupid, you better be able to handle the consequences...
myothercarisatruck is offline   Reply With Quote
Old 05-31-2011, 10:09 AM   #9
Vinnie Vega
My Ride: 0032870Vette70Velle
splicing airbag wires is a huge no no. It calls for the entire harness to be replaced.
Vinnie Vega is offline   Reply With Quote
Old 05-31-2011, 10:46 AM   #10
Zell
Zell's Avatar
My Ride: so turbo wow
Disconnect the battery for 20 minutes and you'll be okay They have a decent-sized capacitor bank that holds a charge, designed so that in case your battery gets disconnected for some reason while driving, you will still have airbags for an ample amount of time. Any time you work with the airbag you should do this unless it is absolutely required to have the battery on to adjust something.
Old 05-31-2011, 10:51 AM   #11
missamo80
My Ride: 2001 325i
Could you please provide more details on why this is the case? The BMW repair instructions for their little fix kit specifically show splicing wires after stripping them. I figure if they can use crappy crimp connectors I can use the more robust soldering technique.
Neil
Old 05-31-2011, 10:53 AM   #12
missamo80
My Ride: 2001 325i
If you search for "airbag light" you'll find threads with a PDF attached that show how to do the seat removal. It's really quite easy. Unbolt the seat, then disconnect the battery, disconnect the wiring harness under the seat, pull the seat out, take one bolt off, put the new tensioner on, and reassemble.
Before doing the tensioner though you need to check and see if you have the BMW repair kit that re-routes the tensioner wires out of the wiring harness. If not, do that first since it's cheaper and more likely the cause.
Neil
Old 05-31-2011, 10:59 AM   #13
G-Hots
My Ride: ///M3 & 328ci
Send a message via AIM to G-Hots Send a message via MSN to G-Hots
move the seat all the way to the front unbolt two bolts
move the seat all the way to the back unbolt two bolts
disconnect battery, wait 10 mins
disconnect all the plugs
take the seat out of the car...
G-Hots is offline   Reply With Quote
Old 05-31-2011, 11:01 AM   #14
missamo80
My Ride: 2001 325i
One thing I'll add to the steps: make sure to lift the seat height up a bit from total bottom, otherwise when you go to run wires you won't be able to fit the connectors through the seat frame. I had to stick my seat back in the car in the middle and plug it in just to lift the seat 1/2 an inch. Sigh.
Neil
Old 05-31-2011, 02:19 PM   #15
guybeemer
My Ride: E46 M3 2003
My airbag light was on last week, had my indy mechanic doing some other work and he reset it, but now it's back on again (ugh). Wondering if I need to bother with it again. Would think that BMW would cover this since it's a safety issue and the low miles I have (67K)?
guybeemer is offline   Reply With Quote
Old 05-31-2011, 03:56 PM   #16
missamo80
My Ride: 2001 325i
Yes, you should bother with it, since if it's on the airbag won't fire
Neil
