Sponsored by BAVSOUND
Thread Tools Search this Thread Rating: Thread Rating: 534 votes, 4.99 average.
Old 06-01-2011, 02:10 PM   #1021
jeffb325@NavigationSolutions
J&T Distributing
My Ride: BMW
I used it all morning while I was out and about. Seems to work good. But it is the basic igo program, ive been running a skinned version of 8.3 and then Primo for the last year in my windows based dynavin so im used to something a bit more advanced and adjustable. But.... although simple, this version works good!
jeffb325@NavigationSolutions is offline   Reply With Quote
Old 06-01-2011, 02:45 PM   #1022
singry
My Ride: 2001 BMW 325i
I just installed it and took a five mile drive.....so far so good. I need atleast a week with this thing.
Anyone else thinks its ok?
MR. 325i
singry is offline   Reply With Quote
Old 06-01-2011, 09:13 PM   #1023
opey
My Ride: 04 M3 coupe
installed igo and the maps, seems to work great. i just need a bigger SD card now since its like 1.5 gb with all the maps and poi's
IR/IR 6 speed
opey is offline   Reply With Quote
Old 06-01-2011, 10:18 PM   #1024
Danoff
My Ride: '04 330i ZSP
Originally Posted by Danoff View Post
Did you find LEDs? If so, where? Nobody near me stocks them, and I'm not confident in my abilities to pick one out online that will fit.
Edit:
http://www.ecstuning.com/Search/LED_...ight/ES259587/
$50!?
Damn, that actually looks right.
http://www.khoalty.com/bmw-e46/light...te-lights.html
^^ That's more like it. But now I'm worried about getting errors (though I'm not currently getting any errors and I don't have a bulb in there.
Wow, keeps getting better.
http://www.ledautomotive.com/product.php?id_product=129
Bought the Khoaltys, installed them this evening. They look great and solve the temperature problem. Very nice.
Danoff is offline   Reply With Quote
Old 06-01-2011, 10:22 PM   #1025
singry
What temperature problem did this solve? maybe i missed it....sorry.
MR. 325i
Old 06-01-2011, 10:28 PM   #1026
J&T Distributing
My Ride: BMW
they are having a side discussion about lighting....not about the dynavin.
Old 06-01-2011, 10:37 PM   #1027
singry
Yeah i figured out that part. Was wondering if it has anything to do with the reverse cam being that it replaced one of the light....
By the way the water dried and my reverse cam is just not the same, so i'm definitely gonna have to purchase one from you.
But lets get back to dynavin...
MR. 325i
Old 06-02-2011, 06:44 AM   #1028
podge3
My Ride: Rover 75 CDTi
Originally Posted by jmejiaa View Post
You would need a USB BT and drivers for the Android unit I would think
Thats what I was thinking.
I have seen BT stuff working on Android tablets and phones so hopefully it can be done on the Dynavins.
podge3 is offline   Reply With Quote
Old 06-02-2011, 08:11 AM   #1029
tomb25
My Ride: BMW 323i
Here are some pictures of igo.
I havent really used it but so far looks pretty good.
The whole argument of not having an offline nav out of the box is stupid, android users get to choose which program they want to use. I'm running co-pilot and now igo, you can't get that on the windows V5 version
tomb25 is offline   Reply With Quote
Old 06-02-2011, 11:20 AM   #1030
dayusmc
My Ride: 01 325ci & 06 325ci
Darkoz did you ever get iGo to hold your settings?
dayusmc is offline   Reply With Quote
Old 06-02-2011, 01:02 PM   #1031
Danoff
Got in the car this morning with my phone tethering off. Started rolling down the road and decided I wanted to check traffic, so I turned my tethering on at a stop sign. The unit doesn't always find a new wifi available right away (does sometimes), and in this case, it didn't find my tethering signal quickly. I think this is fairly typical of android. To fix this, I cycled the dynavin wifi power using the power control widget that I have on my home screen. Once the cycle completed, the unit connected immediately. This is a trick I learned on my android phone and it appears to work wonders on the unit.
Hopefully this helps others.
Old 06-02-2011, 01:06 PM   #1032
jmejiaa
My Ride: 2002 M3
What if you put a power widget on your homescreen, disable wifi and enable it again. I keep my wifi off on my phone and enable only when needed, it always picks up right away.
http://www.appbrain.com/app/wifi-tog...fitogglewidget
jmejiaa is offline   Reply With Quote
Old 06-02-2011, 01:15 PM   #1033
J&T Distributing
My Ride: BMW
yep, this is exactly what I do, if I activate the hotspot while the dynaivn is on and dont want to wait for it to autoconnect, I just toggle the wifi off and on using the power widget.
according to our resident android expert Rob, Android goes out and checks for wifi at a predetermined time interval, it is a value programed into the android system. It always checks at startup, and then every so often after that. I dont know what the actual time is but im sure somebody could figure it out, seems like a couple minutes to me. Where you are in that cycle determines how quickly it will auto-find and connect. That is why sometimes it connects fast and other times it takes awhile.
Old 06-02-2011, 01:20 PM   #1034
jmejiaa
My Ride: 2002 M3
Could somebody run a logcat and post it on here? I'm curious to see if the rest of steering wheel controls provide some sort of input into the android side, if the case is that android simply doesn't understand the input and doesn't do anything then I'm thinking I can write a simple app to make it do very specific actions, like "next" if the music player is active for example.
If someone can play with the android side, press buttons on the steering wheel and possibly on the unit itself(does the unit have >> button?) and THEN do a logcat maybe I can find useful info.
Android logcat:
http://www.appbrain.com/app/alogcat-...rg.jtb.alogcat
Old 06-02-2011, 01:40 PM   #1035
dayusmc
Originally Posted by opey View Post
with a simple google search last night i found the android iGo, im going to try to install today
I know why I couldn't find it. I was looking on there website and it said you couldn't buy it for android. I am going to give it a try. But I also was looking for Legit software that people buying the unit can buy or download. In my field, I really can't suggest to people that they use Software that was not intended for them
Old 06-02-2011, 01:43 PM   #1036
J&T Distributing
My Ride: BMW
Android logcat:
I doubt that would work, the android board is completely separate from the radio board so as far as I know there is no circuitry to get the steering wheel control wires to the android board.....the hardware would have to be changed.
Old 06-02-2011, 01:46 PM   #1037
jmejiaa
My Ride: 2002 M3
Might be worth a shot..
When you press the volume, does it actually change the Android volume? Or does the android volume not change?
Old 06-02-2011, 02:16 PM   #1038
ilbmwista
My Ride: 320 ci
Exclamation
Hi guy!!my compliments for the reportageIt's very great job!!!
i have a dynavin v5 d-90 (italian), can i update my unit with this update ?
Dynavin android 2.2 ?
http://www.dynavin.com/android.php
17-05-2011 ?
I will wait your news about !
Thanks very much!
ilbmwista is offline   Reply With Quote
Old 06-02-2011, 02:20 PM   #1039
hahols
My Ride: e30
"Dynavin will change GPS system from Wince 5.0 to Wince 6.0 on June.
The new wince 6.0 GPS system will not support 3G connection..
The customer who need internet function in car need to wait till when we
launch Android 2.2 system on about October.
2011.05.13.Dynavin"
http://www.dynavin.com/news/news20110513.php
I have read statements in other post on the forum that a unit with WinCE will not be possible to upgrade to Android, but have Dynavin comfirmed those statements?
hahols is offline   Reply With Quote
Old 06-02-2011, 02:22 PM   #1040
jmejiaa
My Ride: 2002 M3
2011.05.13.Dynavin"
So it sounds like Dynavin will have both Android and WinCE units out?
Rate This Thread
