Old 05-31-2011, 10:40 AM   #1
pcstan
My Ride: 2003 330CiC Sport
Engine makes a "CHUFF" sound when I turn it off
I just rebuilt my alternator and while I was already greasy I dropped in a new set of plugs. I used Bosch +4 iR Fusion (Platinum/Iridium surface gap hybrid). When I got everything back together and went for a test drive it was fine. When I shut off the engine it made a "chuff" sound through the airbox (pretty sure) like a valve releasing compression from a cylinder. It's never done this before but now it does it every time. Any ideas?
It's a 2003 330CiC Sport.
Thanks.
pcstan is offline   Reply With Quote
Old 05-31-2011, 10:48 AM   #2
Solidjake
Zero. Leaks.
Solidjake's Avatar
My Ride: '02 330i 6MT
Like a sneezing sound? That is normal.
Old 05-31-2011, 10:58 AM   #3
spencers
My Ride: 2006 330i
Yeah, it has to be normal. My car, my mother's car, and my dad's car (all M54's) all make the same noise on occasion when shutting the engine off.
spencers is offline   Reply With Quote
Old 05-31-2011, 08:03 PM   #4
pcstan
Thanks for the input. I'll sleep better tonight. Any idea why it started so suddenly? (right after a tune-up, oil change and alternator). Just curious.
Thanks again!
Old 05-31-2011, 08:39 PM   #5
phamine
My Ride: 01 Orient Blue 330i
Send a message via AIM to phamine Send a message via Yahoo to phamine
Thats the brake booster you're hearing when you turn the car off.
phamine is offline   Reply With Quote
Old 05-31-2011, 08:42 PM   #6
JJR4884
My Ride: BMW
then why is mine louder since i have a k&n 57 intake... iirc, its the intake making that noise
JJR4884 is offline   Reply With Quote
Old 06-02-2011, 11:40 AM   #7
fuufuu
My Ride: 04 325i
mine only started doing it loud enough to hear from in the car when i changed my intake as well, never noticed before that
fuufuu is offline   Reply With Quote
Old 06-02-2011, 03:06 PM   #8
e46mook
My Ride: 2004 330cic
I also noticed a volume increase when I installed my AFE. My last car with a ram air intake did the same as well
Remus - Dinan - H&R - AC Schnitzer
e46mook is offline   Reply With Quote
Old 06-06-2011, 03:45 AM   #9
pcstan
During my tune-up/alternator repair I pulled out my air filter (K&N) and washed & oiled it. While the airbox was open I had someone start the car then shut it off. The sneeze/chuff/pressure release sound came out of the intake with a little puff of air. Odd that it would start doing that now.
UPDATE: Now I have a dreaded "check engine" light. It's code PO174 (Bank 2 running lean). Coincidence? I've heard everything from K&N oil in the MAF to cracked intake manifold to intake manifold gasket/seal issues to "unsolvable" regarding this one. Anyone want to take a fresh shot at it? I suppose I'll start by pulling the intake manifold, checking it for cracks and reassembling with all new seals. If that doesn't work....
