Old 06-09-2011, 11:20 AM   #1
Solidjake
Mod
Solidjake's Avatar
My Ride: 2002 330i
DIY: Aux/mechanical fan to electric fan swap
All you need is is this:
floor jack and one jack stand
philips screwdriver
I think Torx 20 head
8" extension
ratchet
8mm socket or 8mm wrench
9mm socket
13mm socket
fan clutch tools
OEM electric fan: 17117561757
Expanding rivets: 51718229003 (4)
51118174185 (as many as your break)
51471919209 (as many as your break)
- Jack up one side of car (I did the drivers side) and put one jack on the metal plate
- Remove the 8mm bolts holding bumper to the fender liners
- Take out the reinforcement bolts with 9mm socket/ratchet/extension
- Slide bumper out (unclip wiring for fogs and horn)
- Take out the top air intake
- The center duct is held by four pop in screws
- Aux fan is held by four 13mm nuts, take them out
- Disconnect the aux fan by the fan shroud in the engine bay
- Slide the fan out
- Put the center duct back in and top air intake
- Put the front bumper back on in reverse order (slide in, put in the two reinforcement bar bolts and the assorted bolts to the liners.
- Next you have to take the mechanical fan out
- Pop out the fan control unit on the shroud and the other wiring and put them to the side
- Take out the 1 torx screw on the passenger side top and loosen up the fan shroud
- Use the fan clutch tool to loosen the bolt and take out the assembly
- Take your electric fan and slide it against the radiator and screw in the torx screw
- Plug the electric fan to the connector where the aux fan was plugged into
- Place back the control unit and the other wiring to the electric fan shroud
Viola, you're done.
I will make a DIY video later.
Old 06-11-2011, 02:39 PM   #2
Nervous
My Ride: 01 330CI 6MT ZSP EU3
Let me add some pictures.
Got BEHR fan for $199 shipped from here: http://cgi.ebay.com/ebaymotors/ws/eB...=STRK:MEWNX:IT
Work in progress:
Yuck!
I am so glad I had to mess with mech fan removal for LAST time!
Now, need to cleanup the crap off the condenser and begin to assemble back.
Ok, job's done!
I tested it by idling and monitoring coolant temp (func 7.0). Fan engages at 90C at slow speed (no A/C) and if I turn on A/C and temp rises up to 92C the fan starts to work faster and temp quickly goes down back to 90C. But even at high speed its noise is a whisper in comparison with aux/mech fans' noise. Later will do a test drive.
Nervous is offline   Reply With Quote
Old 06-11-2011, 02:40 PM   #3
Solidjake
Mod
Solidjake's Avatar
My Ride: 2002 330i
Thanks for the pics. I am still waiting for my friend if he wants to do it.
Old 06-11-2011, 02:47 PM   #4
Nervous
A little bit more detailed DIY for bumper removal (btw, I never used 9mm during the process (coupe))
http://www.e46fanatics.com/howto/how...hp?howto_id=41
Old 06-11-2011, 02:59 PM   #5
sellsellsell2000
My Ride: E46 seden
Send a message via AIM to sellsellsell2000
philips screwdriver
8" extension
ratchet
9mm socket
13mm socket
fan clutch tools
- Slide the fan out
Viola, you're done.
VIDEO VIDEO VIDEO VIDEO VIDEO VIDEO VIDEO VIDEO VIDEO VIDEO
BMW /// 323i
OEM M-Tech II front & rear bumper /// Cluster Ring /// Grimace Fog Lights /// CCFL angel eye
330i Diff /// REMUS Exhaust /// Heat Shield Cold Air Intake
sellsellsell2000 is offline   Reply With Quote
Old 06-15-2011, 02:15 PM   #6
Shakewell
My Ride: 2004 325i Sedan
So let me get this straight, you don't need the front pusher fan once you do this mod??
USMC - Aircraft Recovery - MCAS Miramar
Shakewell is offline   Reply With Quote
Old 06-15-2011, 02:16 PM   #7
Nervous
Correct.
Old 06-15-2011, 02:50 PM   #8
alibusoul
My Ride: TiAg e46 Vert
Sorry if I over read anything but can't you just leave the pusher fan on the car? What's the point of taking it off too?
alibusoul is offline   Reply With Quote
Old 06-15-2011, 03:02 PM   #9
Nervous
You can leave it disconnected, since the new fan will use the same connector the aux fan is using now. And as a downside of this decision - much worse air flow, since the shroud of the aux fan is pretty big. Plus, take a look on my pics above, how much crap is collected under the aux fan.
Old 06-15-2011, 04:21 PM   #10
Solidjake
Mod
Solidjake's Avatar
My Ride: 2002 330i
You can only have the electric fan alone. I would take it out because it will prevent airflow to go on the ac condenser.
Old 06-16-2011, 02:29 PM   #11
alibusoul
Ok I see, so that electric fan alone will keep the engine from over heating? Because 2 years ago I took out the mechanical fan and I've only been running the pusher fan, but damn that thing gets really REALLY loud.
Old 06-16-2011, 09:05 PM   #12
Solidjake
Mod
Solidjake's Avatar
My Ride: 2002 330i
I wouldn't run only the aux fan.....
Just do the swap.
Old 06-16-2011, 09:39 PM   #13
tesko.pk
My Ride: 2003 530i
Interested in this swap, can you provide some more detail behind your motivation for it?
tesko.pk is offline   Reply With Quote
Old 06-16-2011, 10:27 PM   #14
Solidjake
Mod
Solidjake's Avatar
My Ride: 2002 330i
- No truck sound when the car is hot
- No chance of the mechanical fan blowing up and taking out MANY parts
- Car feels more responsive due to less drag on the engine
- Better airflow to ac condenser
- Electric fan held by one screw, no special tool needed like the mechanical fan
Old 06-16-2011, 10:37 PM   #15
Nervous
Add one more - better gas mileage. Before the swap my average weekly mpg was 23 - 23.5. Now it is 25 - 25.5. Nothing else was changed in the car.
Old 06-16-2011, 11:48 PM   #16
kpeng
Banned User
My Ride: E46 330 and E30 325
You're welcome
kpeng is offline   Reply With Quote
Old 06-17-2011, 12:59 AM   #17
kpeng
Banned User
See the original thread for more info:
http://forum.e46fanatics.com/showthread.php?t=744994
Many thanks to Solidjake for writing up a DIY though!
Old 06-17-2011, 01:31 AM   #18
bernie21614
My Ride: 01 330i
This is sweet, I was planning on doing this to my auto but wasn't to sure about keeping or removing the outer fan, but now i know. Another thing i wasnt to sure of was wether to stick with an OEM fan or not, since OEM is alot easier ill just stick with it. Thanks for the good info
Sent from my Dell Streak using Bimmer App
bernie21614 is offline   Reply With Quote
Old 06-17-2011, 09:39 AM   #19
Nervous
Originally Posted by kpeng View Post
You're welcome
Today I reached 27 MPG - I never seen this number on my dashboard! Wow.
Old 06-17-2011, 09:39 AM   #20
Nervous
You are welcome for pics!
aux, auxiliary, behr, bosch, bumper, clutch, damage, electric, engine, explode, fan, hood, mechanical, mount, mounts, removal, swap
