Old 06-16-2011, 01:39 PM   #21
Nervous
My Ride: 01 330CI 6MT ZSP EU3
Originally Posted by Blocked Out View Post
E46 M3 or E9x M3 mounts depending on which ones cost less as either will do the job just fine on your particular car.
They are the same, p/n 11812283798. Check the realoem.com
Nervous is offline   Reply With Quote
Old 06-16-2011, 01:41 PM   #22
Nervous
Originally Posted by I_Miss_My_///M View Post
Well, considering my stock mounts had 127,313 miles on them, I can feel a difference. And the e9x M3 mount is a different part number than the e46 M3, so I'm guessing the e9x mount is a bit more durable since it has 414hp to hold..
Again, e46 M and e92 M mounts ARE THE SAME, p/n 11812283798. Check the realoem.com
Old 06-16-2011, 01:49 PM   #23
handpainted
My Ride: 03 325i e46
yeah i'm trying to find out what the differences are in m3 mounts and the e46 mounts are. being they are different prices it makes me believe that there could be some differences, maybe in the type of hardened rubber?? i don't know.
-matt
handpainted is offline   Reply With Quote
Old 06-16-2011, 01:51 PM   #24
Nervous
btw, www.rmeuropean.com sells M mount just for $57 ea (and free shipping for orders $65+).
Old 06-16-2011, 01:52 PM   #25
TxZHP04
My Ride: ESS TS2+ ZHP
This same part number is also used on 325/330 xi models.
Old 06-16-2011, 01:58 PM   #26
handpainted
Nervous, that's freaking crazy pricing!! dude that's cheap!
Old 06-16-2011, 02:00 PM   #27
Nervous
^ and very good place too.
A complete list of models that use the same "M mounts":
Part 11812283798 (Rubber Mounting) was found on the following vehicles:
E36: Details on E36
E36 M3 Convertible
E36 M3 Sedan
E36 M3 Coupe
E46: Details on E46
E46 325xi Sedan
E46 325xi Touring
E46 330xi Sedan
E46 M3 Convertible
E46 M3 Coupe
E85: Details on E85
E85 Z4 M3.2 Roadster
E86: Details on E86
E86 Z4 M3.2 Coupe
E90: Details on E90
E90 M3 Sedan
E90N: Details on E90N
E90N M3 Sedan
E92: Details on E92
E92 M3 Coupe
E92N: Details on E92N
E92N M3 Coupe
E93: Details on E93
E93 M3 Convertible
E93N: Details on E93N
E93N M3 Convertible
Z3: Details on Z3
Z3 Z3 2.5 Roadster
Z3 Z3 2.5i Roadster
Z3 Z3 2.8 Coupe
Z3 Z3 2.8 Roadster
Z3 Z3 3.0i Coupe
Z3 Z3 3.0i Roadster
Z3 Z3 M Roadster
Z3 Z3 M Coupe
Old 06-16-2011, 02:11 PM   #28
TxZHP04
^ Keep in mind though that not all of these applications used the -3798 part from the factory. This part is the latest and greatest and has superceded several older designs. What this means is that when shopping for mounts, be sure to shop by part number. Many non-dealer parts vendors may still stock and sell the older, obsoleted part numbers.
Old 06-16-2011, 02:13 PM   #29
Nervous
^That might be true, agreed, even though realoem.com doesn't have "ENDED" mount parts for e46 M3.
Old 06-16-2011, 02:18 PM   #30
handpainted
nice side note for sure, i do know that manufacturers do that with components. i'm still needing to take my car in to see if my sub-frame is involved with the recall they had on 2003 e46 325i's that i recently heard of.
even if i do have a recall i don't think i just want rubber sub-frame bushings, i'd rather have powerflex
-matt
Old 06-16-2011, 02:21 PM   #31
TxZHP04
That's really only the case for the older e36/z3 platforms. Just didn't want anyone to assume that all of those cars listed had always used this one mount as they might get surprised by old stock with a different part number if they selected by vehicle rather than by part number.
Old 06-16-2011, 03:52 PM   #32
The_Don
My Ride: 2001, 325Ci
-matt
I believe that the m3 mounts are 30% stiffer than non-M motor mounts.
- UUC Stg. 1 LTW Flywheel - UUC SSK + DSSR - UUC TM +TME - UUC Rear Adjustable Control Arms - UUC Swaybarbarians - AST Sportline II -
- RE Underdrive Pullys - RE FCABs - BMW Performance Control Arms - Shark Injector - EMP High Flow Water Pump - TMS Adjustable Endlinks - K&N CAI -
- M3 Motor Mounts -
For Sale
The_Don is offline   Reply With Quote
Old 06-16-2011, 04:01 PM   #33
TxZHP04
And what is your source of information for that bit of trivia?
Old 06-16-2011, 04:05 PM   #34
handpainted
Yeah i was wondering i'm going to go ask the bmw dealership too
Old 06-16-2011, 04:17 PM   #35
TxZHP04
They probably won't know anything beyond the fact that there is a different part number.
Old 06-17-2011, 01:02 PM   #36
The_Don
I searched information when I replaced mine.
- M3 Motor Mounts -
For Sale
Old 06-17-2011, 01:42 PM   #37
TxZHP04
That information isn't readily available and contradicts actual test data I have from a manufacturer of engine mounts. Since you got this info via "search", was this just some random comment someone made or was there actual data to back it up? Your original comment stated that you "believe"... how confident are you in your search results and/or your recollection of those results? When evaluating the accuracy of internet "facts", you really have to know the true source of the "data".
Old 06-17-2011, 01:57 PM   #38
handpainted
well i'm ordering my mounts here soon, and i'm likely just to get oem mounts for my make, i'm suspecting that if i would go with urethane engine mounts that it would be too noisy
Old 06-17-2011, 04:04 PM   #39
The_Don
Relax man. Just like you pointed out, I stated "I believe..." and then answered your question about how I came across the information. The "fact" is that they are stiffer than non-M mounts. If you have the test data that contradicts that statement then please post the information. I am always eager to learn more.
- M3 Motor Mounts -
For Sale
Old 06-17-2011, 04:25 PM   #40
TxZHP04
Just trying to differentiate between internet myth and actual facts. Yes, of course the M mounts are stiffer than non-M I was merely questioning your claim of 30% stiffer.
