Old 06-16-2011, 03:20 PM   #1
Liam.attwood
My Ride: 3 series coupe '01'
E46 buzzing noise
Hey all,
i have noticed a buzzing noise coming from the engine bay.. i have located the culprit, i have a pic *below*
Can anyone tell me what this box is that is buzzing (blue) and can anyone confirm that the red circel'd area is the oil seperator?
i have been told that a faulty oil seperator causes oil loss.. that is my problem.. are these two things (in pic) joined, and will replacing the oil seperator (red circel'd area?) stop this buzzz. thanks.
Liam.attwood is offline   Reply With Quote
Old 06-16-2011, 03:53 PM   #2
maurer
My Ride: 04 Coupe
The box is the DISA valve. If its buzzing like you say its broke and needs to be replaced. It will make your CEl come on if it isnt on already. They run around $200. It's purpose is to raise the low and midrange torque "and" raise the top end power output. It's a valve that opens or closes intake ports depending on the load. Its really easy to change...theres a ton of videos on youtube that shows you step by step how to change it. Good luck!
maurer is offline   Reply With Quote
Old 06-16-2011, 03:55 PM   #3
maurer
My Ride: 04 Coupe
Almost forgot....the part you have circled in red is part of the DISA valve....not the oil seperator. Use the search function up top and find out where the oil separator is.
Old 06-16-2011, 04:31 PM   #4
Liam.attwood
ok thanks looks like its getting expensive lol.. just out of interest, i have read up that if you put a bag over the oil filler and it sucks in, your oil seperator is shot... mine does suck in, but could this be down to the 'DISA' or is it definitly the oil seperator. thanks
Old 06-16-2011, 06:05 PM   #5
dmax
dmax's Avatar
My Ride: '99 328i 300K miles
You should have some suction, just not a lot.
Also, you know the ccv is right behind the disa, and it wouldn't surprise me if it does buzz when it's failed a certain way. It makes a chewbacca noise, why not buzzing?
Just doublecheck your assumptions before you buy a disa. I know they fail, but I also know mine hasn't...though my and everyone else's ccv has failed after so many miles.
I wish there was a better test for ccv failure than the sucking bag!
See me in June!
dmax on Facebook
Mangofy your E46!
Old 06-17-2011, 07:18 AM   #6
Liam.attwood
Me too... so the ccv = oil seperator? and it is behind the DISA... someone told me the oil seperator was deeper in the engine (under the disa if you like)
apparantly if it sucks in, then the oil seperator is shot? im just wondering if its sucking in because the DISA is shot.. or are they both at fault (getting expensive )
Old 06-17-2011, 07:54 AM   #7
Drewfus2101
My Ride: N/A
Yes, Crank Vent Valve is the oil seperator. It is under the intake manifold, burried under there. So I wouldn't say it's just behind the DISA.
I always heard the best way to know if it was bad, is when you turn the car off, if you hear the loud chewbacca noise. Not the mild 'whoosh' noise, but a loud noise. There is a video on here somewhere. I've never heard of a buzzing sound associated with the CVV.
The crankcase 'sucking' won't have anything to do with the DISA.
I knew my DISA was bad when I pulled it out. It has a flap that is held open (or maybe closed) with a spring. The DME will close it as needed. Just pull it out, and make sure the spring isn't broken. It should be real obvious. BUT, if it's buzzing, I guess the problem could be electrical related with the DISA.
Drewfus2101 is offline   Reply With Quote
Old 06-17-2011, 12:05 PM   #8
Liam.attwood
ok thanks, just to confirm,
As my filler sucks air in (quite alot), the oil seperator (ccv) needs replacing?
and the DISA may have a broken spring or something broken inside causing this noise.. hopefully not elecrical.
thanks for the help
Old 01-22-2017, 02:32 PM   #9
swordsman11868
My Ride: 2003 325i
I have the same buzzing noise.
Anyone have a diy for a fix?
I'm just here to change the world.
BMW Wiki: http://www.bimmerfest.com/wiki/index.php
E46Fanatics inspiration Robolop: http://forum.e46fanatics.com/showthr...87566&page=101
2016 Beheadings in Saudi Arabia: 92.
swordsman11868 is offline   Reply With Quote
Old 01-22-2017, 05:15 PM   #10
swordsman11868
My Ride: 2003 325i
Wouldn't it throw a CEL if it had electrically failed? Or mechanically?
