Old 06-18-2011, 10:53 AM   #1
shifty1982
My Ride: e46 323ci
bmw 323ci with stage 2 cams & supersprint
i just fitted a stage 2 schrick cams in my car 272/256 and a supersprint exhaust will let u know how much power i gain after tune anyone else done this mod
shifty1982 is offline   Reply With Quote
Old 06-18-2011, 10:56 AM   #2
Iceman00
Banned User
My Ride: E90 6MT
Nope. But you might also want a M54B30 intake manifold. I'm very curious to see what you're power curve looks like, I'm betting peak power will be made in the low to mid 6000rpm area and hold till redline, only because the manifold will not keep up with the cams flow.
Old 06-18-2011, 11:02 AM   #3
Steven747
My Ride: 05 330ci
sounds like op wasted a good chunk of money
Old 06-18-2011, 11:09 AM   #4
secono330ci
My Ride: 04' 330ci/15' A3 TDI
Lets wait to see how it comes out before making assumptions!
Oh...and the "$300 here, $600 there" scenario will turn into "$3000 here, $6000 there". I've had an enourmous amount of labor put into my car. (Luckily the majority of it was done by myself) Also, I've spent over $5k on my tool set since I started my project. You've been warned...
secono330ci is offline   Reply With Quote
Old 06-18-2011, 11:12 AM   #5
aggieE46
Keep it clean
aggieE46's Avatar
My Ride: 03 Evo, 07 Passat
Do you have a "before" dyno?
Old 06-18-2011, 11:27 AM   #6
shifty1982
My Ride: e46 323ci
no i dont have a before dyno unfortunatly but i was told that i will lose a bit of torque down low but will gain 30 to 40 hp
Old 06-18-2011, 11:28 AM   #7
shifty1982
My Ride: e46 323ci
does m54b30 manifold bolt straight on or do i need an adapter plate
Old 06-18-2011, 11:29 AM   #8
shifty1982
My Ride: e46 323ci
Old 06-18-2011, 11:35 AM   #9
Iceman00
Banned User
My Ride: E90 6MT
Very true. Those are VERY large cams though, they normally would be making power around redline or even above it.
Old 06-18-2011, 11:35 AM   #10
Iceman00
Banned User
My Ride: E90 6MT
You need an adapter plate for the throttle body. Turner Motorsports sells one.
Old 06-18-2011, 11:37 AM   #11
shifty1982
My Ride: e46 323ci
how much gain did u get from your install
Old 06-18-2011, 11:39 AM   #12
secono330ci
Yeah, schrick says peak power would be around 7300-7500 if I remember correctly.
Old 06-18-2011, 11:41 AM   #13
SK330ci
My Ride: 02 330ci w/ 3 Pedals
Is your car a manual or auto ?
Have you upgraded your Diff yet ?
Mods: Header, CAI, Shark, Koni Sport Struts, Rob43 9 Way Shocks, Big Sway Bar, Special Lowering Springs, 3.38 Diff, PFC Z-Pads, 75 Shot Of N20
E46 M3's are just tasty snacks i eat for lunch.
SK330ci is online now   Reply With Quote
Old 06-18-2011, 11:43 AM   #14
shifty1982
My Ride: e46 323ci
i wouldnt waste my time with auto ofcourse its a manual and no havnt upgraded diff yet shouldnt need to there pretty strong diffs
Old 06-18-2011, 11:44 AM   #15
shifty1982
My Ride: e46 323ci
Old 06-18-2011, 12:39 PM   #16
PEI330Ci
58mm of Bliss
PEI330Ci's Avatar
My Ride: 330i, 330Ci
Jumped right in with both feet!!!
I love it!!!
What you are probably going to see is a power curve that keeps climbing right to the fuel cut off.
Enjoy your car. You don't "need" a new diff, or intake manifold...but you might "want" them later on.
BTW, don't let the dyno operator tie onto the rear lower control arms with tie straps. They will bend.
Old 06-18-2011, 12:47 PM   #17
shifty1982
My Ride: e46 323ci
I love it!!!
Thanx for that bit of info mate and thanx for ur support I can't wait for tune should be interesting
Old 06-18-2011, 12:54 PM   #18
Iceman00
Banned User
My Ride: E90 6MT
I love it!!!
I'm expecting this. A M54B30 and Shrick Cams with a M52tu intake manifold. Notice the plateau of power because the manifold is restricting flow in the higher rpm range. This car is down about a good 5whp from a stock cam B30 with similar mods and down 15whp from those with cams.
Old 06-19-2011, 02:53 AM   #19
PEI330Ci
58mm of Bliss
PEI330Ci's Avatar
You are the dyno chart king...I wont' argue that. But...I wouldn't put too much weight on an uncorrected dyno. The chart needs to be SAE for it to be "valid" in my opinion.
Old 06-19-2011, 05:51 PM   #20
Iceman00
Banned User
My Ride: E90 6MT
My SAE numbers were a little lower than my uncorrected numbers and at times, spot on. I don't think we'd see a huge change in power curve with it applied. I will admit though, there is more to this dyno that I lead on, including disabled vanos...
