Old 06-26-2011, 08:06 PM   #1
clydesdale
My Ride: e30, 2004 zhp
Air release sound on shut down of motor?? 330i
I believe it is something to do with the vacuum. I hear a motor turning inside the car and when the motor sound stops I hear an air release sound. Anybody know what this is? Thanks.
clydesdale is offline   Reply With Quote
Old 06-27-2011, 12:26 AM   #2
BMW_Stu
My Ride: HPF 330ci
im pretty sure thats normal. i remember my Camaro ALWAYS did it. i don't particularly remember it happening on the e46 but i never payed specific attention to it. ill listen out 4 it tomorrow.
BMW_Stu is offline   Reply With Quote
Old 06-27-2011, 12:41 AM   #3
j_block
My Ride: 2003 325i
mine does that too, but i think cause of my intake
j_block is offline   Reply With Quote
Old 06-27-2011, 06:56 AM   #4
cak323i
My Ride: ///M3 & 330i ZHP
OP,
Funny you mention this because I recently noticed this with my ZHP as well. Not sure what causes it but now that I'm aware of this it does happen every time I shut down my engine.
2004 TiAg ///M - 171,000 miles.......................2003 Imola ZHP - 180,254 miles
cak323i is offline   Reply With Quote
Old 06-27-2011, 07:10 AM   #5
Hukerfaker
My Ride: My wife.
How about air con pressure release?
Hukerfaker is offline   Reply With Quote
Old 06-27-2011, 07:25 AM   #6
dvd64
My Ride: bmw e46 CI
Mine do the same ...
dvd64 is offline   Reply With Quote
Old 06-27-2011, 08:24 AM   #7
alwaysbored786
My Ride: M3
It seems to be a fairly normal occurrence. Some people say its the oil separator and some say its the ac compressor releasing pressure. Either way, i dont think its really harmful.
if it makes any difference, my noise was more noticeable with my CAI on, weird?
*NO F-BOMBS IN SIGS*
How to refinish rims
2004 Noble M12 GTO 3R
1998 M3 Coupe
1996 BMW M3
2003 330I ZHP
1998 Honda Civic - Sister Totaled
2002 330CI - SOLD
2006 CBR 600RR - SOLD
1995 M3 Coupe - SOLD
1988 325E - SOLD
1996 Cherokee - SOLD
alwaysbored786 is offline   Reply With Quote
Old 06-27-2011, 08:25 AM   #8
kpeng
Banned User
My Ride: E46 330 and E30 325
It's normal. Do you have a cold air intake?
kpeng is offline   Reply With Quote
Old 06-27-2011, 08:32 AM   #9
omarmarji
Banned User
My Ride: E36 332i
i have the k&n short ram and it does the same thing, but it only started happening when i took my entire A.C. system
omarmarji is offline   Reply With Quote
Old 06-27-2011, 12:38 PM   #10
clydesdale
It has the stock airbox, the a/c is already off, and it occurs probably about 5-10 seconds after the engine shuts off. You can hear an electrical motor running, like a HVAC vent is electronically closing and when that stops, you hear the air release.
Old 06-27-2011, 12:43 PM   #11
///Miller325ci
My Ride: 2005 Dinan-S2 325Ci
mine does it too... i think it could be the sound of the throttle body closing... that is why its more audible for those with air intakes
///Miller325ci is offline   Reply With Quote
Old 06-27-2011, 02:01 PM   #12
OrientBlau
My Ride: 2003 330i
Its the vaccum pressure being released.
All truth passes through three stages. First, it is ridiculed. Second, it is violently opposed. Third, it is accepted as being self-evident. - Arthur Schopenhauer
OrientBlau is offline   Reply With Quote
Old 06-27-2011, 05:21 PM   #13
omarmarji
Banned User
My Ride: E36 332i
yeah most likely you are right because the same time when i took out my a.c. i also fixed my vacuum leak and i guess thats the reason why im getting the sound cause its the pressure being released properly threw the intake.
Old 06-27-2011, 11:13 PM   #14
Chris-alfonso
My Ride: 330i
It's normal and I think it becomes more nocitable when you have a CAI.
Chris-alfonso is offline   Reply With Quote
Old 06-28-2011, 07:55 AM   #15
napaxcon
My Ride: 02 325i
yup that is normal. the air that gets sucked in while you drive cant just stay there. its even louder if you have a cai. also if anyone is wondering a slight whistle from a cai is normal to. it usually happens when you press the pedal down about 1/4 the way !
napaxcon is offline   Reply With Quote
Old 06-28-2011, 10:00 AM   #16
jdstrickland
My Ride: '94 325iC & '00 323i
Normal.
Old 07-13-2011, 08:59 PM   #17
Sir Binkley
My Ride: 2004 330xi
On my 2004 330 whistle turned into squeal after car warmed up. Finally traced it down to gummed up oil separator valve & piping. Car was starved for air after it warmed up and was pulling air thru the crankcase seal. Easy way to tell was remove the oil cap and start it up. Whistle was immediately gone as vacuum had a new source of air. Gumming up condition is a known problem and BMW has a larger diameter oil dipstuck tube, insulated valve assembly etc. to fix it. Often caused by numerous short trips. 3.8 hrs of mechanic time & parts cost me $1,000 though.
Sir Binkley is offline   Reply With Quote
