E46 Xi Forum
Old 06-28-2011, 09:46 AM   #1
330xIce
My Ride: 2005 330xi
Send a message via AIM to 330xIce
Creaking Noise... Any Ideas??
Okay so its been going on for a few weeks now.. theres this weird creaking noise coming from the front passenger side wheel. The squeaks and creaks happen around bends and turns. Not sure what it could be, possibly a spring or a strut? Idk if anybodys had this problem... any ideas on how to diagnose or even fix it??
Follow Me On Instagram: JamesMarshall_E46
My Progress Thread - How To Set a Signature - Black Sedans FTMFW
-James-
330xIce is online now   Reply With Quote
Old 06-28-2011, 10:51 AM   #2
athayer187
My Ride: 2004 330xi
Do you have urethane control arm bushings?
1988 535is - EAT chip, style 5 wheels for track, style 29 wheels for street, urethane UCAB's,
urethane trans mounts, 500/450 IE Coilovers, UUC SSK, Mason Engineering strut bars,
Hella H1/H4 headlights, Schroth Rallye 3's, Dinan 25/19 swaybars, 750i brakes
2004 330xi - stock except for UUC SSK, RE RSM's, Koni Yellows, UUC TSE1
athayer187 is offline   Reply With Quote
Old 06-28-2011, 11:00 AM   #3
Kubica
My Ride: 2003 325xi
I'm guessing a loose ball joint - jack up the corner and shake the wheel to look for worn components.
Old 06-28-2011, 01:54 PM   #4
Sheisty
My Ride: '00 323i & 02 330xi
Bearing, bushing, or rotor would be my guess. Search the threads and you will find good ways to figure out your exact problem.
Sheisty is offline   Reply With Quote
Old 06-28-2011, 09:43 PM   #5
330xIce
My Ride: 2005 330xi
.....no idea... should i? lol
-James-
Old 06-29-2011, 02:30 PM   #6
wdeerfield
wdeerfield's Avatar
My Ride: 2009 328i xdrive
Could also be a swaybar endlink gone bad or loose
2009 MBM | ZPP | ZSP | ZCW | CA | 6FL | NAV | XENONS | 18x8.5 VB3s ET30/25
wdeerfield is offline   Reply With Quote
Old 06-29-2011, 02:57 PM   #7
Kubica
My Ride: 2003 325xi
^True. When they're bad they clank, when they're loose they can creak.
Old 06-29-2011, 04:36 PM   #8
TiAgXi
My Ride: 3.0 e46/16
http://forum.e46fanatics.com/showthr...204&highlight=
. . . just sayin
TiAgXi is offline   Reply With Quote
Old 06-30-2011, 03:35 PM   #9
wdeerfield
wdeerfield's Avatar
if it is the swaybar make sure to have a pretty short 16mm and a star bit to tighten. Do not refer to how the bentley says to tighten as XI's are different (which suck btw)
