Forced Induction Forum Sponsored by Active Autowerke
Discuss supercharging, turbocharging and even nitrous and water injection here. Sponsored by Active Autowerke |
#1 |
My Ride: 03 AW 330I AA Stg 2.
Going FI, want to prep my car...
Hey guys hows it going, finally bit the bullet and made the decision to go FI. Car is payed off and i feel its time. I just have a few questions for all of you gurus out there. My car is an 03 330i and currently at 99k miles and im pretty sure i need to prep up the engine with some maintanence before going FI.
Heres the deal though, i live in south florida and have 2 great shops with kits around my area. One being Technique Tuning and the other Active Autowerke. Still debating which kit to go with, either stage 2 AA or stage 1 TT. Which do u guys think would be more reliable for a daily? Also here are the mechanical mods my car currently has with maintanence that have been performed. -F1 racing LTW chromoly flywheel with sachs clutch kit -Pilot bearing, Pivot pin, Clutch fork, T/O bearing with sleeve replaced -UUC Black Poly Tranny mounts w/ enforcers -UUC Delrin shift carrier bushings, all new OEM shifter bushings -BMW performance SSK -SS replica headers -Exhaust cut before 2nd resonator, 2 single 2.5 inch Magnaflow mufflers to custom dual center exits. (Adding Supersprint x-pipe) -Vanos seals replaced at 80k with new VCG. -Meyle HD FCABS with replaceable ball joints at 85k -Velocity Motorcars adjustable endlinks -Rokkor Tuning coils (replaced all strut mounts etc.) What i plan on doing before installing FI -TMS power pulleys -Complete Cooling system overhaul including all hoses etc. -Spark plugs -Replace all vacuum hoses in the engine (noticed many have been cracking/ breaking off) -AKG Motorsport Polyurethane 80a black engine mounts -Change MTF -Change Diff fluid -Fuel filter -RTABS -Leatherz VDO guage panel (Boost, Oil temp, oil pressure) Thats all i can think of right now, is there anything else that you guys would recommend to swap out/ replace? If so you guys would be a great help. Thanks in advance
#2 |
Beautiful car! I think what most people say is make sure to do a compression or leakdown test just to make sure the car can handle the boost. I want to go FI
Also, just a personal opinion, I say you go TT even though I know AA is great too. |
#3 |
Lutz Performance-FL BMW F/I
Have you done a subframe re-enforcement? Or had your current subframe inspected? Definitely a must do!
Lutz Performance
Ph(Shop):813-949-3540 Email: parts@lutzperfauto.net http://www.lutzperfauto.net/ ![]() HOME OF LARRY'S RECORD SETTING 135I!!!!!! 11.23 1/4 MILE |
#4 |
Just a heads up but I dont think you can do pullies with the super charger install.
#5 |
Definitely do subframe reinforcement. Skip the pulleys and instead of the AKG motor mounts, get either the BimmerWorld solid rubber mounts or stock M3 mounts. I'd also recommend a fresh fuel pump if one is not going to be included with the kit you buy.
#6 | ||||
Also do i do front and rear? Or just rear as thats the one to mainly fail? Quote:
And fuel pump/ fuel filter check. Thanks guys, anything else you would recommend?
#7 |
stewart water pump,
and also i thought i read somewhere that e9x m3 engine mounts can fit or might just be e46 m3 mounts? op what kinda brake setup do you have? maybe a bbk for the front? |
#8 |
Both AA and Technique Tuning are great companies. Cant go wrong with either one.
Nick at TT is a great guy to work with. TT web paige for their kits on the 330.. Stage 1 - 315whp / 300wtq - http://www.techniquetuning.com/e46330turbo.html Stage 2 - 375whp / 370wtq - http://www.techniquetuning.com/bmw-e...st2-turbo.html See Sig.. I love the TT turbo kit. Picks up full boost at low rpm and doesn't let off. Looking forward to going stage2. |
#9 |
Limited slip?
#10 | |
I like turbo
![]() Technique Tuning Stage 1 Turbo w/ Greddy Profec B Spec II | 3.07 Quaife ATI Super Damper | Vaio Oil Pump | VAC Pan Baffle | SRE Organic Clutch Turner Reinforcements | SPC Camber Arms | Powerflex FCABs & SFBs Turbo Driveability Video Horsepower vs. Torque - updated |
#11 | ||
Right now i have stock brakes, i think BBK is overkill for a street car. Ill probably upgrade to some slotted/cross drilled rotors and upgraded street pads. Yeah actually ive been doing alot of research on engine mounts lately, and i found out that the only engine mounts that you can purchase have been upgraded to the e9x m3 mounts. Which fit all e36, e46, 1 series and e9x chassis. Quote:
If i go TT im just going to stage 1 as i dont want to dish out all that money for head gasket replacement and such. So my plan is if i go TT to rock the stage 1 setup for a while as i rack up some more mileage on the car lol. Than once i feel its time and i get a new daily, ill dig into my motor hardcore. Ill go stage 2 and tear apart my engine, get the heads machined get all new rods and pistons. Upgrade to some schrick cams, get (davids or daniels?) upgraded oil pump and ATI damper. Just pretty much fully rebuild the engine. The thing is i dunno if i wanna go that route, or just get an AA blower and have some fun with it and use that money i would put in for a stage 2 TT/ engine rebuild and buy myself a mint ///M and work on that. Decisions decisions lol. But this baby is definitly getting some FI. Anything else you guys would recommend?
#12 |
Yeah, if i go TT ill have them install for me if they do installs. If not ill have my sponsor shop do the install for me, which i believe work with TT aswell.
#13 | |
Stage 2 FTW
Viral Vahia
Active Autowerke | 9940 SW 168 Terrace Miami, Florida 33157 www.activeautowerke.com | viral@activeautowerke.com Phone: 305.233.9300 Ext. 232 | Fax: 305-253-8921 |
#14 |
AW330, since your ride is lowered already, keep in mind that with AA kit you lose protective under engine panels and some clearance due to the intercooler pipings (unless the kit has been redesigned).
In a daily commute turbo will provide more driving pleasure, IMO, since you don't need to rev past 4000 RPM to feel some torque. Drive both and decide for yourself. |
#15 |
OP, is your car auto or 5spd??
#16 |
Have spare cash on hand.. things WILL break...
![]() and have fun dude.. welcome to club PSI
![]() M3. ONLY BETTER |
#17 | ||
its a 5 spd, i currently have 1100 miles on the new clutch. Its a f1 racing stage 1 kit which is a lightweight chromoly fllywheel weighing at i believe 14.8 lbs and a sachs clutch disc and pressure plate. When i had the tranny out i also replaced everything except the rear main seal as it still looked brand new. I got a new pivot pin, pivot pin clip, pivot arm, T/O bearing, T/O bearing guide tube. I was going to get a new slave cylinder but mine seemed pretty good so i kept it. Quote:
#18 |
My Ride: TT Turbo 2003 330i
I love my stage 1 TT but I wanted more.....but it is great as is. Also I am told you can get more from the turbo later on if you want.
![]() Technique Tuning Turbo Stage 2|Magnaflow Catback|Tein Super Street|EAS Eagle Eyes Tail Lights|3500k Fogs|ATR CF Power Buldge Hood|BMW Performance CF Strut Bar|Dynavin V5|Infinity Reference all around 2011 BMW S1000rr |
#19 |
oh yeah and i figured id drop a pic of the beast lol
#20 |
My Ride: 2006 E46 330Ci ZHP
If you go with the AA/2 they now provide a set of colder plugs (critical). And I agree with having a LSD - I love my OS Giken - otherwise you will just spin the right tire to shreds.
Jim |
