The Showroom
Thread Tools Search this Thread Rating: Thread Rating: 33 votes, 5.00 average. Display Modes
Old 04-28-2011, 10:19 AM   #141
E462j
My Ride: 323ci
Originally Posted by QuotedFive View Post
Manual's are for kiddies trying to impress school girls, Auto's win races...
Anyways this stand alone computer for the trans you're talking about... lol
Who's tuning the car? Any idea on final gear ratio? I want to see how this comp works to calcualte slippage from the tq converter to compensate for over reving of the motor to achieve proper shift points. I'm curious to see how a "stand alone" trans comp is going to be able to do these calculations without talking to the main ecu. I mean you do realize your never going to get the speed of an smg shift even on a manual valve body trans. Auto's can shift extremely fast with pre set shift points. I'm curious to see the timing on these shifts with this "controller" your talking about.
What are you using to engine management? Stock gte ecu won't do manual shifts on an auto, at least not well to say the least. Ive never heard of this trans controller. Does it piggy back of the main ecu or do you need a full out standalone ems? Haltech, AEM? Please tell me your not using Map Ecu...
Anyways good luck! Thats one way to solve the Vanos issue lol.
Im running an SAFC II, i heard of people using map ecu wuts the problem with those lol......
ive never driven a SMG but heres a suprastick video. I dont think his tranny is built.
A built a340e transmission ( billet gears, high pressure valve body, lightened accumulators and forward piston) the shifts are insanely fast when the trannys shifting on its own, I mean its like push down the gas pedal and hold on for your life when the 30lbs of boost kicks in!!! the auto holds boost through all gears, the closest thing i can compare it to is a take off in a 747/737 airplane lol. And I was launching with the stock stall converter with i think is like 1800rpm with an open diff. Weir dialing in the boost to around 38lbs, i cant imagine launching with the 3800rpm mutidisc lockup converter in full boost of the line with the new lsd. Im gona need some sticky drag radials.
This is one company but there are more, like level 10 and PCS....still debating
http://www.latentsolutions.com/suprastickuv.html
E462j is offline   Reply With Quote
Old 05-01-2011, 11:17 AM   #142
jlb37388
My Ride: 2000 323i
It has taken me a couple days to read through this whole thread. This thread has me ready to start my own swap, I am finishing up a previous project (rebuilding fiero 3800sc swap I done couple years ago) in the next few months and want to start the 2jz swap in my 2000 323i.
Will the Soarer 5sp shifter align with the shifter hole in the 323 or does it have to be from the Supra?
I know the op is using an automatic as i did in my other car, this one I want to stay with a 5sp. Also I read the Pontiac solstice uses the R154 but would need the 1/2jz bell housing swapped any further info would greatly appreciated and sorry I didn't mean to hijack the thread, just not much info in forums on the swap that I could find that is recent.
jlb37388 is offline   Reply With Quote
Old 05-01-2011, 01:56 PM   #143
QuotedFive
My Ride: ///M
Map ECU doesn't allow you to change timing.
Drag Radials are pointless I had NT05r's and I ripped them rolling from 60mph on 28lbs. I was running a Borg Warner S372.
Anyways good luck with it dude! Never even looked into built auto's too in love with the v160. The r154's always broke on 1st and 3rd so ya
I can't wait to see this thing run.
///M
Old: 01 GPGT | PT-70 | STr5 cam | Meth
487whp | 425tq - 15lbs Track - 21lbs :)
"If you pull the ebrake all of your girlfriends cloths will come off"- Jeremy Clarkson
QuotedFive is offline   Reply With Quote
Old 05-11-2011, 12:42 PM   #144
E462j
My Ride: 323ci
60 PSI boost and meth controller
Photobucket
Old 05-11-2011, 07:39 PM   #145
E462j
My Ride: 323ci
Starting the full tranny overhaul !!!
http://www.atfspeed.com/store/index....roducts_id=403
Old 05-11-2011, 07:49 PM   #146
blow me
My Ride: 04 Coupe
Anyone ever put a 5.0 in a E46 yet? Hmmmmmmmm
blow me is offline   Reply With Quote
Old 07-05-2011, 08:06 PM   #147
CoconutGroveGuy
My Ride: MKIV supra
Send a message via MSN to CoconutGroveGuy
Originally Posted by nofingers View Post
except the 2jz can take nearly 800whp on stock internals
DOnt forget, the 2JZ will also be *safer* at that powerlevel, and last longer without problems, than the supercharged M3!
CoconutGroveGuy is offline   Reply With Quote
Old 07-05-2011, 08:56 PM   #148
BimmerFerret
My Ride: 08 G37S, 07 Sky RL
Uh oh, that last part is gonna cause a sh1tstorm. FI M3 owners are very um... passionate.
2008 Infiniti G37S - Big Brakes, Limited Slip, etc.
2007 Sky Redline
1998 Honda Civic EX Sedan
Originally Posted by Roxlo View Post
Class of '03, yet you're still an idiot. Whats your point? Do you really think that you're somehow a god because you joined a site before someone else? ****ing nerd.
BimmerFerret is offline   Reply With Quote
Old 07-14-2011, 10:25 PM   #149
CoconutGroveGuy
My Ride: MKIV supra
Haha... sorry point taken, I'm an '11 so I have lots to learn...
On another topic, anyone know if a car like this can be legally road registered in Kalifornia? I'm moving to the US come August/September, and will be missing the 2JZ powerplant but really like the E46 shell...
Old 07-14-2011, 11:31 PM   #150
djnekkon
My Ride: MB3ci & z33 HR
great
Old 11-29-2013, 12:58 AM   #151
bradferry
My Ride: 03 m3 CSL
how hard is it too do the actual computer or rewiring to convert to the 2j?
i have been thinking about parting with my s54 motor and trans and just going with either a 1j auto trans or 2j 5speed or 6.
I've done a minor rewire on a e55 swap into a e500 w211 not saying it was done right but it atleast started and everything but still had too send that out to get rewired. something with the amg computers and everything, usually cant be just plug-and-play usually needs to be reprogrammed.
my question is if i went with the auto 1z , 2jz
would i still have to run a stand alone computer?
or is it something that needs to be piggy backed?
i would like to sc or tc but , i would like to have save money..
im not trying to make huge numbers either , as it would be daily driven as long as i have more than 350
looking to bag it also on the stock 19's ..
its all about the wow factor..
bradferry is offline   Reply With Quote
Old 12-02-2013, 12:10 PM   #152
NPVR6
My Ride: 540i-6, 328i
Holy thread revival Batman!!
You should do an LS Swap and pickup a custom wiring harness.
2009 HD Nightster
2001 Yamaha R6 - Sold
328i - Sold
540i-6 - Sold
Originally Posted by ODEHBOY View Post
Person B needs some D in their A.
NPVR6 is offline   Reply With Quote
Old 11-01-2015, 12:45 AM   #153
verrückt
My Ride: 2003 325xi Manual
verrückt is offline   Reply With Quote
Old 11-03-2015, 07:13 PM   #154
mr_y82
My Ride: 01 325xi Sedan
^nice revival... at least some new members search the forums!
H&R Sport Springs on Bilstein Struts; Valeo SMF, non-SA Clutch, CDV delete, and E60 Shifter w/ ZHP knob; Beisan System VANOS Seals...
Mtech-II Front Bumper (PO got bumped in parking lot!); Eagle Eye LED Tail Lights... Lots of PM!!!
mr_y82 is offline   Reply With Quote
Old 05-26-2016, 08:51 PM   #155
2kE46
My Ride: E46
Thanks for this. Great read!
2kE46 is offline   Reply With Quote
