E46 Convertible
Thread Tools Search this Thread Rating: Thread Rating: 8 votes, 5.00 average. Display Modes
Old 07-04-2011, 11:13 PM   #1
ROOFLESS
My Ride: has a 3.2L bag now
Convertible Ski-pass Subwoofer...custom install
Hey guys,
I know my vert bros will appreciate this. I wanted to have more bass in the car but I didnt want to takeup trunk space seeing as how we barely have any already. My only option was to buy the BSW ski-pass subwoofer set up for like $699. Fvck that, I decided to create my own ski-pass sub box.
So here you have it. A 10" kicker sub (free air) providing me with lotsa bass, even with the top down on the highway! Its clean, compact and stealthy. It sounds great and Im so happy I built it myself (with help from a friend whos an engineer)....
ROOFLESS is offline   Reply With Quote
Old 07-05-2011, 10:52 AM   #2
bngu1
My Ride: 330Cic
hey, i have the exact same sub in my vert!!
bngu1 is offline   Reply With Quote
Old 07-05-2011, 12:17 PM   #3
EVMadman
My Ride: 944
Nice. Can you cover it back up for a stealthier look or does it need to be out in the open?
DAC
EVMadman is offline   Reply With Quote
Old 07-05-2011, 12:23 PM   #4
SMUUUUUV
My Ride: 330 VERT-4.4 X5-S550
DAC
Like mine?.......
SMUUUUUV is offline   Reply With Quote
Old 07-05-2011, 12:35 PM   #5
mtnbound
Town Clown
My Ride: 330Ci Vert, 325iT
both look good. nice work fellas.
Bay Area Top Dropper
Orient Blue 330 Ci Vert
mtnbound is offline   Reply With Quote
Old 07-05-2011, 01:15 PM   #6
ROOFLESS
Nice! Did you do a ski pass sub box also? Post up some pics??
DAC
Yes I can cover it up no problem. Suprisingly it still sounds good covered up
Old 07-06-2011, 01:02 AM   #7
bngu1
My Ride: 330Cic
here is my setup in my 330Ci Vert. i used those "Great Stuff" foam sealant to seal the edges that's why you see all that extra stuff at the edges.
Old 07-06-2011, 01:23 AM   #8
Mulatto325
My Ride: 325ci convertible
Same place i put my amps. I figured in the Florida heat that they would go into thermal overload protection but it has yet to happen. I was going to add a fan but so far no need to. I Have a similar kicker amp but mine is 600x1 had that thing for over 10 years and still going strong.
My tops down, its upset.
>>>Mulatto325<<< Build thread
http://forum.e46fanatics.com/showthr...087&highlight=
Mulatto325 is offline   Reply With Quote
Old 07-06-2011, 08:10 AM   #9
ap123ap
My Ride: 2002 E46 ///M3 Vert
Are all of these setups on Harmon Kardon units? if so, is it as easy as swapping the factory sub with an after market one?
ap123ap is offline   Reply With Quote
Old 07-06-2011, 11:56 AM   #10
DeM3n
My Ride: '88 M3, '05 ZHP
Nice upgrade guys!
DeM3n is offline   Reply With Quote
Old 07-06-2011, 11:57 AM   #11
bngu1
My Ride: 330Cic
well, i have HK but i swapped my Head Unit out with an Alpine Double Din
Old 07-06-2011, 06:19 PM   #12
M3man2001
My Ride: 03 M3 vert
I need one of these boxes they look great! Was thinking of going with the square kicker though - is there an advantage or reason you guys picked those subs? Who wants to make another box?
M3man2001 is offline   Reply With Quote
Old 07-06-2011, 07:52 PM   #13
bngu1
My Ride: 330Cic
for one, it is cheaper. the other thing is that i chose that sub because it is free air so it works virtually in any setup.
Old 07-11-2011, 04:54 PM   #14
Adamo99
My Ride: 2016 Wrangler 75thAE
I have the HK system, and left the stock amp in place, still driving the front and rear door speakers. My Kicker amp drives only the sub. Mine's not as clean an install though- looks really good, may have to build something like this too.
Adamo99 is offline   Reply With Quote
Old 07-12-2011, 02:21 AM   #15
ap123ap
cool. so where did you take the audio feed for the amp? did you just use the feed that was going into the stock sub?
Old 07-12-2011, 06:39 AM   #16
dan_1337
My Ride: 330CiC
What the...you can pull that thing between the two back seats down?
dan_1337 is offline   Reply With Quote
Old 07-12-2011, 07:16 AM   #17
Stuttgart330
My Ride: 05 330CIC ZHP
Wondering the same thing - I have the stock HK system and my sub doesn't even seem like it works - just going with an aftermarket sub and amp seems like a good start. How did you feed it?
2005 330CiC ZHP Hellrot - (mine)
2006 F350 Diesel CC - (Toy Hauler)
2009 528i Spacegrau Metallic - (wifes)
Stuttgart330 is offline   Reply With Quote
Old 07-12-2011, 01:58 PM   #18
Adamo99
I took the audio feed from the full-range signal being fed into the stock HK amp, and ran it to my Kicker amp. (700.5, I think- it's a 5-channel amp, but I'm only using the subwoofer channel for now). The Kicker amps are great, because you don't need any line-level converters, adapters, or anything. Just tap into the signal wires, connect some RCAs, and plug right into the amp.
I used the instructions from the BSW installation guide for the BSW ib110 subwoofer system:
http://www.bavariansoundwerks.com/pr...e-M3-3-Series/ - look under 'install info', and download the PDF.
Old 07-12-2011, 02:11 PM   #19
TiAgXi
My Ride: e46xi, e46m
Did you remove a ski bag or just punch out the sheet metal?
If you removed a ski bag, let me know the dimensions of it and I might buy it from you for $75.
TiAgXi is offline   Reply With Quote
Old 07-12-2011, 03:08 PM   #20
Adamo99
^^ not sure if this question was directed at me, but the HK system in my vert had a subwoofer that swung open and closed to allow for skis/etc to be passed through the opening. No sheetmetal blocking the subwoofer opening.
I merely unscrewed the subwoofer assembly, disconnected the wiring harness, and removed the whole thing. Right now, I have a small subwoofer box that sits in the trunk, taking up a bunch of space, so I'd love to build it into the opening with some MDF and a free air driver, like the examples above.
