2000 323ci driver rear tire inside tire wear, causes? - E46Fanatics E46 BMW Social Directory E46 FAQ 3-Series Discussion Forums BMW Photo Gallery BMW 3-Series Technical Information E46 Fanatics - The Ultimate BMW Resource BMW Vendors General E46 Forum The Tire Rack's Tire Wheel Forum Forced Induction Forum The Off-Topic The E46 BMW Showroom For Sale, For Trade or Wanting to Buy
Old 07-17-2011, 08:35 PM   #1
Rubenk
My Ride: M35A2
So I noticed some roaring when I went to the store earlier, got there and suspected a low tire. They all looked good so I looked underneath, and boy am I glad I did!!
My driver-side rear tire, has steel showing on the inside. The rest of the tire and the passenger side are all decent looking. I started measuring around and my tire-fender gap is different on each side. All other measurements are identical. Measured camber on each side and it looked same. Wheel is centered on the body as well.
I had the rear subframe repair done by a BMW dealer about 6 months ago, but otherwise have not done any rear suspension work since I bought it a year ago. Its a 5spd with 125k miles.
Here are a few pictures, not sure if they help at all. Let me know if you need pics of anything else.
driver rear tire.
Driver side rear
Passenger Rear, measured from the ground.
Rubenk is offline   Reply With Quote
Old 07-17-2011, 09:02 PM   #2
Zchild
My Ride: 2000 BMW 3XXi ZSP
Dude, when was the last time you had a four wheel alignment, I get mine aligned every 15,000 miles or after I purchase a new set of tires or do suspension changes. Just my two and a half cents worth...
V/R Zachary Pullins Sr.
National Capital Chapter BMWCCA
NCC Member Recognition Chairman
NCC High Performance Driving School Back-Up Registrar
NCC Auto-X BOD Liaison
DIY Senior Committee Coordinator
2006 E90 325Xi & 2000 E46 3XXi
" Vision without resources is just hallucination"
Zchild is offline   Reply With Quote
Old 07-17-2011, 09:06 PM   #3
Rubenk
My Ride: M35A2
I'm quite sure the dealer did an alignment. They changed out the lcabs the same time as the rear subframe repair. So around 8k miles ago.
I figured if the alignment was *that* bad more than one tire would be chewed up? It drives as straight as an arrow.
Old 07-17-2011, 09:25 PM   #4
RockLee
My Ride: 99 328i. ZSP, ZPP,
Send a message via Yahoo to RockLee
You think you got it bad?
http://forum.e46fanatics.com/showthr...506&highlight=
After replacing the FCAB's and RTAB's with powerflex and having an allignment done made it perfect again.
1999 328i Sport Package, Premium Package, 5 speed, Alpine white.
RockLee is offline   Reply With Quote
Old 07-17-2011, 09:31 PM   #5
Zchild
The don't think they did such a good job on your driver's side rear alignment. The tire wear is an indicator that your alignment on that wheel is off. Looks like your rear driver's side camber needs adjustment. Independent race shops do a much better job aligning bimmer's than the dealerships. Just my two and a half cents worth...
Old 07-18-2011, 12:51 AM   #6
hardtop
hardtop's Avatar
My Ride: 05' 3 pedals 2 doors
I would say alignment or possible RTAB's if they havent yet been replaced
Owen
hardtop is offline   Reply With Quote
Old 07-18-2011, 05:14 AM   #7
IxNay
My Ride: 2000 328Ci 5sp SP
The inside rear tire always wears first on the E46 due to the camber settings. So, to some extent this is normal but your wear seems excessive.
IxNay is offline   Reply With Quote
Old 07-18-2011, 11:38 AM   #8
Rubenk
My Ride: M35A2
I dont guess I was aware that each wheel could be aligned independently of the rest. I'm too used to 4x4's with solid axles!
What exactly is the RTAB and how can I verify if that is an issue? I'll get it to an alignment shop asap.
Looks like I need new tires too...wooooo...
Thanks everybody!
Old 07-18-2011, 12:09 PM   #9
Zchild
A RTAB is a rear trailing arm bushing which is the bushing assembly for the rear of the vehicle versus the front control bushing assembly. The alignment shop should be able to tell you whether your RTAB requires replacement as well. Just my two and a half cents worth...
Old 07-18-2011, 12:11 PM   #10
southpaw
My Ride: E36 M3 and E36 318ti
Alignment.
Or too many fat chicks and/or dead hookers in your trunk.
-Brandon
239whp/227wtq @2700lbs
southpaw is offline   Reply With Quote
Old 07-18-2011, 12:27 PM   #11
Rubenk
My Ride: M35A2
lol thanks guys, I'll lay off the fat hookers and get er aligned!
Old 07-18-2011, 02:40 PM   #12
Alex323Ci
My Ride: M3 & 323Ci (sold)
hard to say, but yes BMW was suppose to align the cars after doing the subframe fix.
when measuring height, you're suppose to measure from the cetercap (or top of rim) to the fender if you want to see how much it's off in height. height doesn't mean the alignment's off though
Old 07-18-2011, 02:46 PM   #13
Rubenk
My Ride: M35A2
Measuring from the centercap showed the same difference in height. Maybe its just normal sag for a 12 year old car?
I have an appointment with my dealer this friday to get it on the alignment rack and see what the deal is.
Also, does my car look lowered? I havent compared it to a known stock car to verify...
Thanks again everybody!
