Old 07-18-2011, 12:03 PM   #1
UGuideme
My Ride: 2001 325i
02 Sensor
Okay, Folks; I recently replaced the Pre-catalyst sensors and one of them is leaking exhaust. I place anti-seize to it and I torque it and am still having this issue. Suggestions Please!
UGuideme is offline   Reply With Quote
Old 07-18-2011, 12:14 PM   #2
Zchild
My Ride: 2000 BMW 3XXi ZSP
Did you possibly strip the thread when you removed the old O2 sensor. If you did you will have to retread the socket. Just my two and a half cents worth...
V/R Zachary Pullins Sr.
National Capital Chapter BMWCCA
NCC Member Recognition Chairman
NCC High Performance Driving School Back-Up Registrar
NCC Auto-X BOD Liaison
DIY Senior Committee Coordinator
2006 E90 325Xi & 2000 E46 3XXi
" Vision without resources is just hallucination"
Zchild is offline   Reply With Quote
Old 07-18-2011, 12:40 PM   #3
UGuideme
My Ride: 2001 325i
Cool in the manifold? "retreading" Its cheaper then buying a used Exhaust manifold. This calls for a job for El Shop!
Hey thanks Zchild
Old 07-18-2011, 12:52 PM   #4
Zchild
Cool
Hey thanks Zchild
No problem comrade, I had the same problem and had to rethread the O2 sensor threading because I waited too long to change my O2 sensors and one of them had rusted in place.
Old 07-18-2011, 01:01 PM   #5
dmax
dmax's Avatar
My Ride: '99 328i 300K miles
I don't know how experienced at working on cars you are...I'm not a mechanic, but play one here at times!
Anyway, I haven't done this for a long, long time, but there's a crush washer on the sensor, I'm sure...don't know if that comes on it (which I assume it does), but maybe small chance it didn't...or someone took it off...or maybe the old one might have been seized on and you didn't get it off?
Not sure if you scraped, cleaner area it came from, but it wouldn't take a lot to leak from there.
I don't know the torque, but feel for an issue with it being stripped before you try to make it tighter...and you know to keep the anti-seize away from the sensor, right?
If rethreading, then I suspect helicoil is okay, but time sert is probably better...not an impossible diy, but it's probably cheaper at good shop than buying the kit!
HTH
Facebook.com/DMAXstandup
Mangofy your E46!
Old 07-18-2011, 01:35 PM   #6
UGuideme
My Ride: 2001 325i
Dmax; Thanks for the insight. I check the diagram and their seems to be a washer, However, Its for a model without converters I have a 325i 2001 with one.
Old 07-18-2011, 03:49 PM   #7
LivesNearCostco
My Ride: 2003 ZHP 6MT
I think most of the O2 sensors come with a washer on the threaded end of the sensor.
LivesNearCostco is offline   Reply With Quote
Old 07-18-2011, 04:27 PM   #8
UGuideme
My Ride: 2001 325i
I pulled the 02 sensor out once again and behold their a washer. it has to be the manifold
