Old 07-19-2011, 12:22 AM   #1
zga
My Ride: 2000 323i
P1522 code after new Vanos seals & 2 new CPS
I have a p1522 code- generic code scanner indicates that the there's a problem with the exhaust camshaft actuator.
I recently replaced the Vanos seals and both camshaft position sensors.
I also took off the exhaust Vanos and found that the piston was stuck in the closed position. After applying pressure, it broke free. I reset the code, but it came back after a couple of days of driving.
The car seems to have slightly less torque and gas mileage.
Could it be that I need a new spring piece for the interface at the exhaust solenoid of the Vanos? Or maybe the wiring that supplies power to the solenoids needs to be replaced?
Has anyone encountered a similar issue?
Thanks!
zga is offline   Reply With Quote
Old 07-19-2011, 12:59 AM   #2
flashmeow
Banned User
My Ride: E30-E46-E90-E90M-F30
call Rajae ...he is a stand up guy and will help you
