Old 07-27-2011, 05:26 PM   #1
jdhecker07
My Ride: 2000 323ci cabrio
Seize or no seize?
I'm about to change my spark plugs on my 323. I'm fairly handy as i've successfully done a couple diy jobs under the hood (valve cover gasket, ignition coils) so i'm not too worried about my mechanical abilities. My only question is whether I should use anti seize compound or not. I've done some reading here on the forums and elsewhere through google and some people say it's absolutely necessary while others say it isn't. What's the deal. Should I or shouldn't I?
jdhecker07 is offline   Reply With Quote
Old 07-28-2011, 01:33 AM   #2
paraklas
My Ride: ESS TS2 320ci
http://tis.spaghetticoder.org/s/view.pl?1/00/30/65
Does not mention anti-seize, personally I never used either so I'd say don't use.
http://www.ngksparkplugs.com/product...m.asp?mode=nml
"Trivalent Metal Plating provides superior anti-corrosion and anti-seizing properties"
Old 07-28-2011, 06:57 AM   #3
Sansho
My Ride: 2001 325i
Bentley says to lightly lubricate the threads with a copper-based anti seize compound.
Sansho is offline   Reply With Quote
Old 07-28-2011, 07:14 AM   #4
dmax
dmax's Avatar
My Ride: '99 328i 300K miles
Discussion has come up before...search 'anti-seize' and 'plugs' in title search.
I'm 99.99% that for some plugs yes, and others no. On ours? No.
Facebook.com/DMAXstandup
Mangofy your E46!
Old 07-28-2011, 07:35 AM   #5
CylonRed
My Ride: '01 E46 330i sport
I learned to change my BMW plugs from a guy that has 4 BMWs and he does all of the work on them. He uses a tiny bit of anti-seize on plugs, lugs, and the rotor set screw.
CylonRed is offline   Reply With Quote
Old 07-28-2011, 08:50 AM   #6
LeMansteve
My Ride: '04 330i 6mt ZSP ZPP
I've not done the plugs yet in my car, but have always used anti-seize on other cars. I figure a little bit can't hurt. Why risk a rusted-in spark plug?
Old 07-28-2011, 09:04 AM   #7
teamdfl
Slow in, slower out
My Ride: 325it
Always use a sparse amount of anti seize and a torque wrench on spark plug threads.
Mod the driver. Participate in your local BMWCCA autocross or driving school. Have you joined BMWCCA yet?
teamdfl is offline   Reply With Quote
Old 07-28-2011, 06:43 PM   #8
wildcat293
My Ride: 325xi
never use anything on lug bolts!
install them clean and dry
wildcat293 is offline   Reply With Quote
Old 07-28-2011, 06:52 PM   #9
dmax
dmax's Avatar
This is not the first time this discussion has been held here.
I'm very certain you should technically not use it. I also know that some plugs call for it and others don't.
I also know that the torque spec changes considerably between a plug with and a plug without antiseize. You use much less torque if you put on anti-seize.
Never on lugs, ever. And never just because this is how I learned...nothing personal.
Find out for real. You've already got both possible answers here--don't just flip a coin on it. It's a fundamental thing--fact checking and getting things right.
Mangofy your E46!
Old 07-28-2011, 08:56 PM   #10
Drewfus2101
My Ride: N/A
I was always told that with aluminum heads, you need the stuff. Iron heads don't. Pretty sure ours are aluminum.
Drewfus2101 is offline   Reply With Quote
Old 07-30-2011, 02:28 PM   #11
Kubelman
My Ride: 1999 323i
seize or not ?
jd--my vote lands in the little dab'l do ya camp--been wrenching air-cooled vw's for years--they run hot--you have not lived until you have struggled with a hard to reach tight plug--suffice to say a tiny amount of anti-seize compound can't hurt and will most assuredly help----
Kubelman is offline   Reply With Quote
Old 07-30-2011, 04:15 PM   #12
John in VA
My Ride: 328i/325xi
I understood that the NGK Laser Platinum BKR6EQUP plugs came with a Trivalent Metal Plating, providing superior anti-corrosion and anti-seizing properties, making anti-seize unnecessary.
John in VA
'13 328i xDrive
'06 330ci ZHP
'03 530i
'02 325xi
'00 328i
'86 535i
'85 535i
'85 325e - RIP
'74 2002tii
John in VA is offline   Reply With Quote
anti, compound, plug, seize, spark
