Auto Transmission Ruining My Life - E46Fanatics E46 BMW Social Directory E46 FAQ 3-Series Discussion Forums BMW Photo Gallery BMW 3-Series Technical Information E46 Fanatics - The Ultimate BMW Resource BMW Vendors General E46 Forum The Tire Rack's Tire Wheel Forum Forced Induction Forum The Off-Topic The E46 BMW Showroom For Sale, For Trade or Wanting to Buy
Old 08-01-2011, 05:33 PM   #1
Pwn Shop
My Ride: 2003 325CI
2003 325Ci has decided it wants me to be an unhappy person in general. I was driving it on the freeway a week ago, suddenly the car felt like it was gear hunting for a minute, then threw itself into tranny limp mode (red cog of death) and I had to flip it around and go back home. Since that time it has consistently gone into limp mode after about 20 min of driving (right about when the trans gets to running temp?) but beforehand, everything is hunkey dorey. Threw engine codes P0700 and P0734 (trans control unit and 4th gear ratio incorrect). I have replaced the battery to no avail, and the alternator is good too. Any advice would be greatly appreciated, thanks!
Pwn Shop is offline   Reply With Quote
Old 08-01-2011, 05:49 PM   #2
lilcdkey
My Ride: E46 M3 Sedan
happened to me right when I bought my car, changed the battery and it was all good. hopefully you find a fix soon!
-Zaid
ZHP Mafia Car of the Month for September 2011
2005 330ci|Jet Black|Black Leather|Black Cube|ZHP|ZPP|ZCW
18'' E46 M3 Wheels|15mm Spacers|BMW Performance Grills|CF Splitters|Painted Reflectors|Euro Plate|Debadge|20% Tint|Apexcone 6000k HIDs|LED Fogs|LED License Plate Bulbs|OEM Homelink|Concealed Escort 8500
lilcdkey is offline   Reply With Quote
Old 08-01-2011, 06:21 PM   #3
shadow 2
My Ride: 07 328i
Why would you make expensive repairs without knowing the cause of the problem? Have you consulted with a BMW specialist?
shadow 2 is offline   Reply With Quote
Old 08-01-2011, 06:29 PM   #4
Pwn Shop
My Ride: 2003 325CI
The battery wasn't that expensive of a repair, that is all i have done so far. Also I took it to autozone and it tested bad before I replaced it.
Old 08-01-2011, 07:24 PM   #5
shadow 2
My Ride: 07 328i
Misread and thought you replaced the alternator. I would still get it checked out by an independent BMW mechanic. Good luck.
Old 08-01-2011, 07:45 PM   #6
cityjohn
My Ride: 2001 M3
My buddy's Accord was doing this same thing. Turns out this is what was happening:
  • Car would drive great until warm.
  • Once it was warm it wouldn't shift (you'd come to a red light and couldn't take off after that).
  • Diagnosis was small bits of worn clutches in torque converter clogging the filter.
  • After the car sat for 10 minutes, the particles settled and the trans would operate normally until they got stirred up again enough to shut it down.
Ended up rebuilding the transmission.
cityjohn is offline   Reply With Quote
Old 08-02-2011, 11:31 AM   #7
Pwn Shop
My Ride: 2003 325CI
Update: Last night after work got home and dropped the pan, mostly because i wanted to check out the magnets. They were dome-shaped with how much sludge they had picked up. Changed the trans filter and replaced the fluid with Castrol multi-vehicle synthetic and so far, so good. Took it on a 30 min test drive and she did well. Hopefully this has fixed it! Thanks for the input, and it's definitely off to a bmw shop if it acts up any more.
Old 08-02-2011, 11:53 AM   #8
FastHackem
My Ride: E60 M5
Just wondering, how many miles on your vehicle when you changed the fluid?
The Mind Is A Terrible Thing.
2006 M5
2005 Impreza WRX
2002 330i
1983 944
FastHackem is offline   Reply With Quote
Old 08-03-2011, 06:24 PM   #9
Pwn Shop
My Ride: 2003 325CI
99,315 . . . So close
limp mode, p0700, transmission
