Rating:
Display Modes |
#21 | |
![]() *F-BOMBS IN SIGS*Bilstein HD's | E30 M3 FCAB's | H&R OE Sports | FR strut bars | Self tuned 027 chip | KoseiK1's on R888's | +crazy OCD things Last edited by new//M3fan; 07-21-2011 at 10:00 AM. |
#22 |
No difference on mine maybe takes a few days great when car isn't warmed up though.
#23 |
Just a word of caution to those attempting to snug up the contacts: if you snug them up too much, the male pins in the solenoids will actually push the female pins out the back of the connector such that there is no connection at all. Result: SES with P0010 and P0013 codes.
#24 |
What an amazing find. I haven't done it yet but I'm excited about it. I had contemplate getting a vanos seal kit (which I will still do), but I'm definitely going to try this first. Thanks man. Awesome find and thanks for sharing.
#25 |
Add me to the list, I think.
I haven't experienced what I would call low-end power loss, but I've noticed a "bump" around 3,000 RPM, where things would get suddenly stronger, so I suspected something was going wrong on the low end, just not bad enough to notice, without the abrupt feeling transition. I snugged up the connectors on the intake side (couldn't immediately spot the exhaust connector, so I thought I'd try the intake connector and see if it made any difference), and things feel much smoother as the engine revs from low RPM to high. No more "bump." I'll drive it a bit more to confirm, but it was easily repeatable before tonight, and now it is not. Thanks!
Because... Grocery Getter. |
#26 |
I gotta try this out... maybe tomorrow
#27 |
Interesting
mujjuman
![]() 2003 325xi 5MT Jet Black, ZSP, ZPP, ZCW, OEM Xenon ^^RIP sig by Solidjake |
#28 |
I installed the Besian seals about 10k miles ago, and I still get the 2800 rpm 'hickup'. No codes. Engine is in great shape, so I've always wondered what was going on. I've cleaned the connectors multiple times.
I'll try this tonight and see what happens.
For Sale: Auto Trans E-fan - http://forum.e46fanatics.com/showthr...3#post12840603 23.5mm Front Sway Bar - http://forum.e46fanatics.com/showthr...0#post13054250 18mm Rear Sway Bar - http://forum.e46fanatics.com/showthr...8#post13054258 |
#29 |
My car still runs great, AND I just used the same process to clear a P0597 code (thermostat). Great info.
#30 |
My car has new disa, new beisan seals, all new intake boots, etc everything checks out and everything is new and good. I cleaned the maf and everything that I could clean over the period of 3-5 months. I updated and reflashed the ECU , But I STILL have a little bit of hesitation right before 2800rpm in EVERY gear under load. Its not noticeable unless the car is under load and only at 2800rpm.
I just went to my car and did the procedure described here and went for a test drive. I was about to sh!t myself because the hesitation is GONE and I only drove for like 20min. I only did this procedure on the intake and exhaust Vanos solenoids and there is no more hesitation. there seems to be bit in 6th gear but that just might be the uneven road. Other gears are clear. I will do this on other connectors later on. Thank you very much for this info.
#31 |
Fixed the code by crimping the connectors?
![]() *F-BOMBS IN SIGS*Bilstein HD's | E30 M3 FCAB's | H&R OE Sports | FR strut bars | Self tuned 027 chip | KoseiK1's on R888's | +crazy OCD things |
#32 | |
#33 |
Yep. On the thermostat connector. Thanks for the great idea!
#34 |
I am going to try this when my wife gets back tonight with the car.
Is there any special cleaner that I should buy from the auto parts store or electrical grease that I should get. Thanks Last edited by bwallace530; 08-07-2011 at 11:54 PM. |
#35 |
So i tried it and my MAF conection was fine the VANOS one which I hope was the Vanos one looked fine also I am going to go for a test run real quick and see if it changed anything.
#36 |
My Ride: 99 328i. ZSP, ZPP,
Going to try this too.
![]() 1999 328i Sport Package, Premium Package, 5 speed, Alpine white. |
#37 |
Mine wasn't messing up but I thought I would try it anyway really nothing has changed so I guess it didn't work for me lol. But my pins looked brand new so maybe that is why
Sent from my PC36100 using Bimmer App |
#38 |
Gotta say, George...This has really improved my engine! Thanks for doing it!
#39 | |
We have to get together again and re-flash your DME again!
#40 |
I need mine flashed
Sent from my PC36100 using Bimmer |
