Old 08-07-2011, 12:40 AM   #1
Dandoe
My Ride: 03' 325i
Exclamation Rear drivers side window........
OK, so I searched through the forums for this and found noting like it, My rear window is giving me issues, It will go down but when it tries to go back up it doesnt move and makes a sound like gears going through sand or something. I took the door panel off and moved the window back up. But didn't get to take a look at it yet on the inside, seeing this happened at 10:30pm. I need to fix this asap and need to know if it's just the regulator or something else. She's parked in a unsecure parking area and I don't really trust my neighbors, Please let me know any helpful info asap. Thank you.
Dandoe is offline   Reply With Quote
Old 08-07-2011, 01:18 AM   #2
BMW_SSG
BMW_SSG's Avatar
My Ride: '02 325i|'11 GT500
Send a message via Yahoo to BMW_SSG
Sorry to hear you are having problems with your window. I too am having issues with my window regulator (that is what the problem is). This is not the first time for me, it is my 3rd, I drive an '02 325i. For some reason it is very common in out cars. Use this link: http://www.theeurodepot.com/quick_se...ulator&x=0&y=0
or search other websites, but this will answer the mail for sure. They are pretty easy to replace, just need patience. The gears grinding is a tell-tale sign of them going out. In the mean time, push your window all the way up, you might need to toy with the window switch to release some of the cable, then once you have it all the way up shove a CD or two in between the window and the window guard (on the inside of the car) to keep the window up.
What ever you do, don't use tape on the window, inside or out. It is a BMW for crying out loud, they are not meant to look ghetto-fabulous.
I hope this helps.
BMW_SSG is offline   Reply With Quote
Old 08-07-2011, 01:42 AM   #3
Dandoe
My Ride: 03' 325i
Thank you, for your help. I got the window back up, I put a couple of hardwood floor " gappers" in there to keep it up for now. Happen to know the going rate for a new regulator? I looked at a couple local stores and they seem to be about $80. Just seems a little high. I've heard that they were less. The DIY looks pretty simple.
Old 08-07-2011, 01:44 AM   #4
BMW_SSG
BMW_SSG's Avatar
I have bought mine from the link I provided in the original post. if you can get them for $80, that's a steel, get 'em!
Old 08-07-2011, 10:09 AM   #5
nick330xi
My Ride: 2001 330xi
i got my regulators from discountbodyparts.com and at first it seemed to cheap to beleive, but they really are good!
nick330xi is offline   Reply With Quote
Old 08-07-2011, 10:16 AM   #6
BMW_SSG
BMW_SSG's Avatar
Yup ,they are only $46.00 there. I am getting one from them right now...
Old 08-07-2011, 12:56 PM   #7
Dandoe
My Ride: 03' 325i
NICE! Im going to check both places out right now. Thanks.
Old 08-07-2011, 09:37 PM   #8
2002E46NH
My Ride: 2002 325i
Definitely the regulator. I bought mine off of eBay for around $50. Easy to install with all the DIYs on here.
I had the stealership asking for ~$500 to fix it. One of them I was able to fix with a zip-tie. But when it is grinding like that just replace it.
2002E46NH is offline   Reply With Quote
Old 08-07-2011, 09:58 PM   #9
Dandoe
My Ride: 03' 325i
After I checked out those sites and punched myself in the nuts for not have a garage to park in and having to spend more then what was needed. I went down and replaced the old regulator. Apparently the cable snapped on the top half and gOT caught around the pulley in the middle. I have a pic but my phone won't let me share it. That's a easy DIY, I watched the vid on here. Made it easy. Thanks for the help everyone. Now back to the original DIY of the week, brakes and rotors.
