Thread Tools Search this Thread Rating: Thread Rating: 14 votes, 4.86 average. Display Modes
Old 08-08-2011, 02:33 AM   #1
paraklas
My Ride: ESS TS2 320ci
Official DIY: Bilstein Suspension Install + Caliper Rebuilt + Front Endlink Rebuilt
After 170000km, a leaking strut, weird noises when going over bumps, torn endlink boots and a possibly sticking brake caliper, I decided that it was time to address those problems, at once. Why at once? Because there are a lot of things that are common among those components, so it made sense to disassemble once and do all 3 of the issues together. Therefore I went on and ordered all of the required components plus new bolts as per BMW TIS instructions in order to perform a proper and safe repair.
Initial notes:
I chose to have my mechanic compress the springs in order to remove old struts and install new, due to the fact that he had a hydraulic spring compressor and made the job a 5-minute task. No need to struggle compressing springs using manual clamps if you have access to a hydraulic compressor.
I am not listing part numbers because not everything is the same on the E46, specially braking and suspension components. I recommend going to http://bmwfans.info, put your VIN and get vehicle-specific components.
I used a calibrated torque wrench to tighten all bolts and I'm encouraging everybody to do this.
Brands / Suppliers:
- Bilstein Sport Suspension - Turner Motorsport
- OEM spring pads, Sachs strut mounts/bearings - Turner Motorsport
- Hotchkis front endlinks rubber boots - ultimateboots.co.uk
- BMW Brake caliper repair kit - Pelican Parts
- Various bolts/nuts - BMW Dealership
Tools:
- 450Nm Impact Wrench (mine's electric)
- 20-100Nm Torque Wrench
- 1/2" Wrench with 13mm, 17mm, 18mm, 22mm sockets
- Open wrench 10mm, 13mm
- Pliers, WD40, rags, compatible brake fluid, grease and safety gloves/glasses.
Official BMW TIS Torque Values as - Download
Official BMW TIS Instructions for Strut removal - Download
Official BMW TIS Instructions for brake caliper removal + rebuilt - Download
Instructions for brake bleeding - Link
Lets start. Part I - Suspension Removal
Remove (if installed) upper strut bar and re-install the removed nuts, do not tighten.
Loosen wheel lugs and place the car on jack stands. Personally the way I did was to drive the car on ramps, use a hydraulic jack to lift the car from the front center jack point, slide the ramps away, place jack stands at each jack point and carefully lower the hydraulic jack until car recess on the jack stands.
Remove wheels and place under car for additional safety measures. You can never be sure with only 2 jack stands holding the vehicle. I also used 2 hydraulic jacks under each frame rail for triple protection.
One of the most useful tools. The strut to steering knuckle 18mm bolt was impossible to remove without this tool. Honestly I'd have taken the car to a mechanic if I didn't have the impact wrench. At 450Nm max torque it still took me a while to get that bolt out.
The night before, sprayed a generous amount of WD40 on all bolts to be removed and let it soak.
Top endlink nut
Remove 13mm endlink nut. If the stud turns with the nut, use an open wrench to hold it from the other side. Since aftermarket endlinks, sizing may not be the same as BMW.
Place hydraulic jack under control arm, just to touch it. This will help dropping the suspension slowly.
Fun time:
Bolts were discarded afterwards and used new ones. Figure out why, the previous mechanic must have used over 500Nm of torque (suggested is 81Nm)
Once the lower 18mm bolt is removed, with the help of WD40, the strut is able to freely twist. The only thing holding it are the 3x13mm nuts located on the upper strut mount that you previously didn't tighten completely. Slowly lower the hydraulic jack until the strut breaks loose from the steering knuckle, tilt the strut a bit to facilitate movement. Once completely free, grab the strut with your strong hand and one by one, remove the 3x13mm nuts. Once removed you can maneuver the strut away from the car. Pretty intuitive once there.
Using rubber band, thick wire, whatever, secure the front wheel brake/bearing/knuckle assembly so that it doesn't tilt when you remove the strut. It IS pretty heavy and you don't want to stress the brake lines with its weight.
Blown suspension (will show later why)
Picture of what car looked like after temporary stop for sleeping (yes I was doing this after work so it was pretty late). Wheels stored in safe place
Did the other side too: Same process
Now, time to get the endlinks away. With the upper nut already removed it was only the lower one still attached. Although thicker and supposedly better than OEM the Hotchkis front endlinks suffered from torn boots in notime. Therefore to prevent damage to the ball joints I had to replace them. The current boots are not their originals but a temporary replacement from energy suspension. Didn't to much though, they were out of grease and full of dust.
New boots and their assorted lock rings.
Removed ball joint from rod and thoroughly cleaned
Packed with grease:
...and slid the new rubber boot.
Screwing the ball joints on the endlink rod. I also used loctite so that nothing gets unscrewed accidentally.
Once the endlinks were done, I resumed the suspension. A visit to the mechanic and 30 minutes later resulted this:
Eibach Pro-Kit on Bilstein Sport shocks with new rubber pads and Sachs upper strut mounts/bearings. I also went ahead and ordered front strut tower reinforcement plates as seen below to cope with the crappy roads we have.
Reinforcement plate in place:
Installing the new strut is the reverse procedure. Maneuver it in place while paying attention to get the top alignment pin in place. Unlike the OEM Sachs, the Bilstein struts do NOT go below the steering knuckle. This is normal, as there is a stop at the bottom of the knuckle preventing further movement. New bolt also in place and torqued to 81Nm. Top 13mm nuts also placed and torqued to 34Nm. Repeat same process for other side.
Part II: Brake caliper rebuilt.
Remove caliper and disconnect brake line from upper end where it meets with the steel hose. I used a plastic bag to grab leaking brake fluid.
New caliper guides to be installed along with new piston boot and seal. I used some high-temp silicon based grease for the rubber bushings/guides.
I thought they were exaggerating.. They did not. Blowing with compressed air through the brake line will literally launch the piston out of the caliper at light-speed. Be ready to stop it using a piece of wood (NOT YOUR HAND) and to use the rags to clean the remaining brake fluid within the caliper and brake line.
Piston had slight rust that had penetrated just a bit after the cover, but not a big deal. Rest of the piston and bore where perfect.
I used a plastic rod to remove the piston seal, clean the cylinder and installed the new seal along with the new guides. Used some brake fluid as lubricating agent I slowly pushed the piston back in place using a wooden rod. Getting the protective boot back on the caliper proved to be the most time consuming task, since it needs to slide evenly to make a good seal. I didn't take pictures, sorry, I was sweat, swearing, and very dirty with brake fluid. The process is the same for all 4 calipers, with the difference that the rear ones have smaller components. You MUST perform brake bleeding after installation.
Part III: Rear suspension
Place car on ramps and remove 2x13mm nuts on each side of the rear shock tower. Need to (obviously) take the covers out before seeing the 2 nuts.
18mm bolt to be removed holding the rear shock
Comparison:
The Bilstein shocks were simply uncompressible unless you were some dude on steroids. On the other hand, the OEM Sachs's piston was dropping within the shock by its own weight. It was like having no rear shocks from what I figured out.
Removed the stock nut on the OEM shock in order to reuse the rear shock mounts, bump stops and covers.
I had to use a hydraulic jack to push the rear shock in order to align with the mounting position. Bilstein includes a washer for that bolt.
Old stuff ready for recycling
Finished!
Results:
No more brake caliper sticking
Quieter ride, no more weird noises, car feels SOLID again!
Added a couple more years of life to endlinks
Old 08-09-2011, 02:53 PM   #2
kraimer
My Ride: 04 330Ci, 00 323it
Send a message via AIM to kraimer
Great write-up!! How difficult was it to push the caliper piston back in? I hear its a PITA...
kraimer is offline   Reply With Quote
Old 08-09-2011, 05:10 PM   #3
AMCINK
My Ride: 2000 323CI
Very Nice - Thank you for the write up - It will help many people here
AMCINK is offline   Reply With Quote
Old 08-09-2011, 07:39 PM   #4
djnekkon
My Ride: MB3ci & z33 HR
2 from 1 to 10 (10 Hard)
Old 08-10-2011, 05:55 AM   #5
paraklas
Wasn't too bad to push the piston back, just need to have it aligned to avoid damage to the seal and bore. I had tough time getting the piston rubber cover back on other than that very easy job.
Old 08-18-2011, 01:22 AM   #6
mynewe45ride
My Ride: E46/328i/199k
Great DIY for bilstein install. I just finished driver side and now need to tackle passenger side. Thanks OP for your help..
My ride - 99/328i, Manual
2011 - window regulator, vcg, vanos seals, fuel filter, PS hoses+resorvoir, water pump, wp pulley, belts, thermostat, spark plugs, springs, FCAB & RCAB
2012 - Driver & Passenger Seat Belt Tensioner
2013 - Rear Diff & subframe bushing, Shocks & Struts, Wheels
2014 - Belts, Pulleys
2015 - Brake Pads/Rotor Front-Back
2016 - Fuel Pump
2017 - Upper & lower intake boot
mynewe45ride is offline   Reply With Quote
Old 12-16-2012, 07:16 PM   #7
JokerElite
My Ride: 95 M3, 04 M3, 09 328
How did you get the piston out using the air compressor? Looks like a homemade attachment?
1995 BMW M3 - Avus Blue | 2004 BMW M3 - Jet Black | 2009 328xi - Alpine White
JokerElite is offline   Reply With Quote
Old 12-17-2012, 06:12 AM   #8
paraklas
not really any attachment. Just secured the brake line somewhere, then I used the hand-gun from the air compressor to blow regulated compressed air to the caliper through the brake line. Once pressure starts to build inside the caliper, the piston will start to slide out until it reaches the end of the cylinder, where it will literally fly out, therefore the need to have something like a piece of wood to stop it from hitting the cast caliper.
Old 12-17-2012, 10:28 AM   #9
JokerElite
That's what I'm trying to do but I need a way to connect the hose form the compressor to the hose of the caliper. I might go to the store and see if they have some sort of adapter that fits both ends.
I hope it will still work even though I have a little rust holding the piston coming out. How much pressure did you use?
Old 12-17-2012, 02:10 PM   #10
paraklas
I use this
Just stick it to the brake hose no need to modify anything
Old 12-17-2012, 02:54 PM   #11
JokerElite
I use this
My uncle should have that, I'll try it.
Old 12-18-2012, 10:44 PM   #12
JokerElite
My uncle managed to get it out at the Auto-Body shop he works at. Thanks!
Old 02-03-2013, 10:18 AM   #13
Dave1027
My Ride: '06 IR zhp coupe
Thanks for the front strut DIY. I'm replacing my strut mounts and installing reinforcement plates (PO did a crappy fix resulting in uneven front suspension).
Old 05-04-2013, 08:06 AM   #14
TeeTime4One
My Ride: 2002 330cic
Nice write up. Doing it all today. Thanks!
2002 e46 330cic Sport w/cold weather package
STOCK
1995 e36/5 318ti Active
NOT STOCK
TeeTime4One is offline   Reply With Quote
Old 05-10-2013, 07:42 PM   #15
swordsman11868
My Ride: 2003 325i
OP-
I didn't know the endlinks are rebuildable! Otherwise I wouldn't have bought new ones when I put my Bilsteins in.
Is there a procedure that you followed or care to share one? Also, is there a kit for the rubber boots? Mine were torn.
TIA!
Dan
I'm just here to change the world.
BMW Wiki: http://www.bimmerfest.com/wiki/index.php
E46Fanatics inspiration Robolop: http://forum.e46fanatics.com/showthr...87566&page=101
2016 Beheadings in Saudi Arabia: 92.
swordsman11868 is online now   Reply With Quote
Old 05-13-2013, 01:36 AM   #16
paraklas
Originally Posted by swordsman11868 View Post
OP-
TIA!
Dan
The OEM are not rebuildable. The ones I have are from hotchkis, they're supposed to be stiffer with a better balljoint, unfortunately crap rubber boot, which I had to replace to avoid damaging the ball joint. I bought the boots based on the 2 diameters of the existing boots, I assume you can do the same with the OEM. The only thing noting down when changing end-links, is to do install/tighten the lower nut when with the suspension loaded; install the top nuts, put wheels, drive car on ramps, then install the lower.
Old 10-30-2013, 04:41 PM   #17
trj
My Ride: 325Ci
OP, Did you remove the rear shocks while the wheels were resting on the ramps?
I have coil overs and I always remove the wheels and then the lower shock bolt to adjust the coils. (the coil overs I have needs removal of the shock bolt and lower the rear control arm, remove the springs to get to the adjuster).
If it could be done without having to remove the wheels, it would save me some time.
I plan on having the rear on the jackstands so the weight of the car will not be on the wheels, that should allow me to lower the control arms.
Only thing I am worried about is the removal of the wheel. If it can be done without removing the wheel, that would save me a lot of time.
Old 10-31-2013, 01:39 AM   #18
paraklas
Yes, removed the shocks while on ramps, but bear in mind, I'm working with OEM setup, not coilovers
Old 11-09-2013, 01:25 PM   #19
DOTC
My Ride: 2001 325i
I'm about to jump off a building trying to get my new Bilstein Touring struts in. To get the old crap Monroe struts out I had to compress the spring to finally get room to wiggle them out.. my control arms will not drop far enough down. Now looking at the new ones, they are at least 3 inches taller than the Monroe's. I'm thinking the only thing I can do is remove the scratch plate and drop the inner control arms to drop the whole wheel assembly. Anyone else ever come across this? I called OEM Bimmer to see if anyone else has called in about it..and googled my butt off. No help anywhere.. just seems crazy that I'm the only one who cant just drop the struts out and plop the news ones in like it no big deal. :-(
DOTC is offline   Reply With Quote
