Driveline, Engine & DME Tuning
Talk about driveline improvements, NA tuning and DME tuning your E46 BMW here. This includes diffs, intakes, exhausts, chips, software and OBD tuning. |
#41 |
I compared the euro2 to euro3 files, and I can see where the euro3 has deleted past cat 02 sensor monitoring. But if I compare the euro tunes to US tunes the data is too much different to the point that you can't see much similarities.
As for the 60kb file size, only thing it needs is rest of the bin file to be filled with FF values until it reaches 64kb size and should be flashable with galletto1260 tool. TerraPhantm can you tell me what cable works so I can buy it on ebay? |
#42 |
Hey guys could you just please give me one pointer. What software do I need to flash a eu2 tune to my car??
Thanks Sent from my PC36100 using Bimmer |
#43 | |
![]() *F-BOMBS IN SIGS*Bilstein HD's | E30 M3 FCAB's | H&R OE Sports | FR strut bars | Self tuned 027 chip | KoseiK1's on R888's | +crazy OCD things |
#44 | |
Euro 2 is the sw that deletes post car 02 sensors. Euro 3 deletes secondary air pump monitors. Interesting to Note that you discovered no similarities between an us tune and euro. http://cgi.ebay.com/ebaymotors/BMW-S...#ht_2647wt_948 That the interface I use. It is strictly for 99-2006 BMW iirc. Terra might know If the k+dcan interfaces can be used to flash e46 DME. However the interface I posted is the cheapest of them all.
#45 |
Also,
It would be worth a shot to edit the .0da files with the modified tuner pro hex code an try to code it through winkfp. It might work and may allow for custom tunning without the need of a bench flash. What could we alter to test that it worked? Perhaps modify the vanos timing so that fully advances at a certian rpm. Or set the rev limiter to 5k rpm. Hmmm
#46 | |
And yes K+DCAN interfaces work fine w/ the E46. That's what I've been using this whole time. Last edited by TerraPhantm; 08-26-2011 at 11:56 PM. |
#47 | |
Which us tune is he comparing the euro ones to? Winkfp or the hakken Tt us tune dumps? I'll got do it right now since I can't sleep. Laptop died. Left it in the car.
![]() *F-BOMBS IN SIGS*Bilstein HD's | E30 M3 FCAB's | H&R OE Sports | FR strut bars | Self tuned 027 chip | KoseiK1's on R888's | +crazy OCD things Last edited by new//M3fan; 08-27-2011 at 12:13 AM. |
#48 | |
So euro2 deletes post 02 sensors but secondary pump is on? And euro3 deletes secondary air pump but keeps the post cat 02 sensors on? But I heard that this will make the OBD2 monitoring go into "system not ready" at Arizona state emissions testing? I would be interested in something like removing cats and air pump and still pass emissions testing. |
#49 | |
Euro2 deletes all emissions and you can set the idle mixture manually through dis.
#50 | |
Euro 2 = No cat monitors, no SAP, and probably no other emissions stuff. Basically the equivalent of our "OBDI" Unlike aftermarket tunes, the Euro 3 and Euro2 tunes don't set the monitors to "not ready"; they set them to "not applicable" (much like the EGR monitor on stock E46s; it'll look like those components weren't fitted from the factory). Most states books say that a monitor that says "not applicable" doesn't cause failure, BUT the catalytic converters showing as n/a might raise a few red flags. One issue with the Euro 2 tune for US purposes is that it disables the Key-on-Engine-off CEL, which is required in most (if not all) states to pass inspections. I would imagine someone who knows what they're doing can reenable that light though. Last edited by TerraPhantm; 08-27-2011 at 03:40 PM. |
#51 | |
I bought an extra MS43 ecu but it has a different hardware number on it so I don't know if it will work. I don't want to experiment with my stock ecu |
#52 | |
![]() *F-BOMBS IN SIGS*Bilstein HD's | E30 M3 FCAB's | H&R OE Sports | FR strut bars | Self tuned 027 chip | KoseiK1's on R888's | +crazy OCD things Last edited by new//M3fan; 08-27-2011 at 11:20 PM. |
#53 |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() guys keep it going, great work here
#54 |
#55 |
I'm not familiar with carsoft nor pa soft. Swap ecu should do it. If not look for a ews/DME alignment option.
#56 |
What cable do i need to get to be able to flash my car and read codes
02 325i Thanks |
#57 |
^there's a post about it above.
Sent from my SGH-T959V using Bimmer
#58 |
Thanks missed that post.
This is what I downloaded http://bmwcoders.com/forum/bmw-gt1-o...tool-winkfp-1/ Hope this will work? |
#59 | |
#60 |
My 330ci is automatic, how can I ID what software number is for what? Does it matter if its M/T or A/T?
