Angel Eyes, DDEs, lighted rings, Clear Turn Signals, LEDs, Xenon, HID, or Bi-Xenon. If it lights up and you want to discuss it, post here! |
Rating:
Display Modes |
#81 | |
Recall work depends on the dealer, they demand the deluxe guarentee but WONT pay you if the car is returned, because they pressured the greenhorn tech to finish the job in 30 minutes. I guess it may just depends on where you work, I never worked at BMW but I can assume its the same as everyone else...FLAT RATE pay. I went to check to see if my BMW had already been serviced by the recall and it looks like they just cut the brown ground apart, attached a 2 prong clip and ran dual grounds, one to the original plug and one to the bulb grounds. Nothing different than thats already been explained DIY on here except there is a union clip joining the two wires rather than wraping them together. Regardless, both are great fixes and I would recommend either. (7yr experience Electrical Engineering tech and Automotive repair) Last edited by Loaded325i; 09-03-2011 at 03:15 AM. |
#82 |
I was a tech for about 8 years
![]() And yes, I hated it cause you can get screwed too easily. That is why I work in parts now. But, I would like to know what car company makes a tech do a recall for free? Never seen that at all the numerous different car companies I have worked for. 90% of the dealers I have worked for , the techs didn't make much money (which is why I got out if it), but I'll say most of the BMW techs are making decent money at the dealer I work at now. Oh and just so everyone knows the recall they put out is ONLY on sedans.
![]() Have a oil or coolant leak? Click here!:http://forum.e46fanatics.com/showthr...732&highlight= ABS/DSC/Brake/Airbag light on?? Click here!:http://forum.e46fanatics.com/showthr...648&highlight= |
#83 |
My Ride: 2003 325xi
It depends on the dealer/manufacture agreements. Most companies pay their dealers fixed shop reimbursement rates for any recall type work. No real dealer on the planet would absorb that hit. Now, the fixed reimbursement may be even to or below actual time for the scope of work. In this case, quality of work may be questioned where the tech is rushed to not lose money. Been there - done that.
Anything made can be made Better ![]() |
#84 |
My Ride: E30 325ic & E46 M3
I know it doesnt say any E46 M3s are affected.......
Wonder if they are. Is this for NON LED Tails only?
#85 |
I had precisely the same problem. Mine is a 2001 330ci (Coupe). I paid to have mine fixed also.
#86 |
My Ride: 02 330i Sport Pkg.
Guess ill be putting my old red/yellow/red stock tail lights back on and going to the dealer for the fix. Never have seen a problem with my tails yet but better safe than sorry
#87 |
Only on sedans as of right now
#88 | |
#89 |
My Ride: 2003 325i
I bought my 2003 exactly three years ago and it had the rear light out indicator glowing at the time.
A little bit o' searching on this website & bingo. Problem solved. Who needs the dealer ???
#90 |
i'm calling BMW in Canada here to see if they are aware of the recall yet as my tail light situation has got worse.
it went from not recognizing the bulb i had replaced even though it still lit up to all them not lighting up except turn signal ![]() when originally getting the light out bulb i checked for any melting and did not see or smell any like i did on the driver side when i added the additional ground wire. will check that today to see if it's finally melted or not. Last edited by Mr_325; 09-04-2011 at 12:45 PM. |
#91 |
This is probably a stupid question but is this why you see a lot of e46s where some of the tail light bulbs are dimmer than others? Because of poor grounding?
#92 |
Do you think they'll be that rough about it? I mean it should only be the assemblies they're concerned about right? Or will they be finding any excuse to not warranty it...
#93 |
My Ride: '03 Orient Blue 325i
Can you find out what the mechs/dealers will do about already "repaired" vehicles to fix the grounding problem? I did the spade connector repair for the ground to the ground side bar on the lighting housing done on here and am wondering if/what will arise when I bring that into a dealer.
P.S. I'm a tech and our foreman helped with the job, he thought it was a good repair. I'd take the BMW repair if I can, but am confident in what I have now. P.P.S. I only did the driver's side, passenger still looks fine, would they do only 1 side? |
#94 | |
#95 |
Again, nice and simple: does this defect affect e46s with factory LED tails?
#96 |
No, only sedans. Read.
#97 |
Mines fix I am not taking my car to the dealer at all. I can not stand them and do not want them touching my car. I swear when I ask them simple questions about the engine or performance type things that they should Know they either say well with only deal with DINAN or We Can Give Any Information on that. Stupid they couldnt even Flash my car to EU2 Software they never even knew they could! Pretty dumb.
#98 | |
![]() *F-BOMBS IN SIGS*Bilstein HD's | E30 M3 FCAB's | H&R OE Sports | FR strut bars | Self tuned 027 chip | KoseiK1's on R888's | +crazy OCD things Last edited by new//M3fan; 09-05-2011 at 01:40 AM. |
#99 | |
![]() *F-BOMBS IN SIGS*Bilstein HD's | E30 M3 FCAB's | H&R OE Sports | FR strut bars | Self tuned 027 chip | KoseiK1's on R888's | +crazy OCD things |
#100 | |
| Tags |
| e46, recall, tailights |
