Thread Tools Search this Thread Rating: Thread Rating: 173 votes, 4.93 average.
Old 08-11-2011, 09:57 AM   #101
shadow2132
My Ride: 330i ZHP
Originally Posted by Wassa2016 View Post
Completely forgot to post pictures up here >_< I'm just fixing my radiator, will post pics up in the next few days. Must say.. Mini really does hold up; seems brighter than OEM xenon lights haha, the 6000k bulbs add a nice purple flicker when driving, and lights up the road, with or without the bi-xenon function.
I'm really pleased with buying them and recommend TRS for future buys. Matt has great customer service skills.
If anyone else wants i can post more pictures up with installing the lights, if anything is missing
Hey I just had a question as to what ballasts and/or harness you used. I just picked these projectors off a friend but still need ballasts.
shadow2132 is offline   Reply With Quote
Old 08-12-2011, 01:54 AM   #102
Wassa2016
My Ride: 328i E46
Thanks for the PM, didnt see anyone replied to this thread. You'll want to get the 9006 harness, E46 use H7 bulbs but it uses the 9006 to H7 adapters.
Heres a pic of them attached
http://imageshack.us/photo/my-images/153/img04611u.jpg
I used 35 watt ballasats and 6000k HID bulbs. Reason was if you go any higher in the kalvin range for the bulbs, you will get a more purple color however the light intensity will drop. And 55w ballasats tend to overhead alot quicker and have a shorter life-span.
Cars:
2003 320i Sedan
1998 328i E46 Sedan
1997 E36 M3
Wassa2016 is offline   Reply With Quote
Old 08-13-2011, 12:55 AM   #103
no_metalgear
My Ride: E46 sedan 02
Send a message via MSN to no_metalgear Send a message via Yahoo to no_metalgear
Thanks alot for this super useful DIY .... Bump
no_metalgear is offline   Reply With Quote
Old 08-24-2011, 05:28 PM   #104
cobyK
My Ride: 2001 330i
about to tackle this diy, looks great. i'm sure i'll be thanking you later.
cobyK is offline   Reply With Quote
Old 08-25-2011, 08:21 PM   #105
drummr8
My Ride: '06 M5, 05 ZHP Coupe
Why has no one posted pictures of cutoff/output after doing this? lol... that is the most important part
drummr8 is offline   Reply With Quote
Old 09-02-2011, 01:35 PM   #106
shadow2132
My Ride: 330i ZHP
hey guys i just did these today and had a quick question, anyone have a problem with a very slight flicker? the bulb doesn't go out but it seems the light output isn't constant as if the power is not consistent.
any ideas?
Old 09-02-2011, 06:57 PM   #107
a325h
My Ride: '13 2.5SEL Jetta 5MT
Okay, I am FINALLY going to start this retrofit next weekend after it has been sitting in storage for 2 months!
Anyways, I have done some testing with the ballast and OEM connection and it works BUT, I cannot get the OEM H7 harness (or is it 9006) from the stock low beam to fully connect and stay with the ballast. It fits and lets the setup work, but like I said, its not plugged in all the way.
Now I can do some simple trimming, or should I just go with the 9006 relay harness from TRS?
TRS 5000K XB Bi-Xenons | ümmitza 6000K Opaque AEs | Metallic Tinting | LED Interior Lights
^2001 E46 325i^ SOLD
Current: 2013 SEL 2.5 Jetta 5MT
2010 E90 335i M Sport in Le Mans Blue
a325h is offline   Reply With Quote
Old 09-03-2011, 06:54 PM   #108
Lsportlex
My Ride: 2003andahalf E46 M3
any ideas?
a friend of mine is having the same problem, i thought it was a faulty bulb but guess not ...
E46 ///M3 Vert
Lsportlex is offline   Reply With Quote
Old 09-03-2011, 08:45 PM   #109
shadow2132
My Ride: 330i ZHP
I've dealt with DDM stuff before so me and a friend have a spare HID parts bin. I took Error code eliminators and put them on which so far has fixed the problem.
Dash looks fine and there's not even a slight color change. Start up is fine and they warm up to color as expected.
I'll keep you posted if this works thru the next few days but it seems to have fixed the problem. Now I need to figure out where to tie off the balasts.
Old 09-04-2011, 12:34 AM   #110
Lsportlex
thanks for the info, ill relay this message to help him out..
E46 ///M3 Vert
Old 09-06-2011, 06:31 PM   #111
shadow2132
My Ride: 330i ZHP
Ok so for any future people doing this retrofit if you go the route of DDM just order the error eliminators for $15 along with the bulbs and ballasts and you'll be all set
(H1 bulbs, 35w or 55w ballasts, and code eliminators) < I was somewhat confused at first of how it would all fit together but it really is plug and play.
Will post pics as soon as i get a clear night it's raining here in nyc ...to anyone doubting the cut-off i can say its beautiful
Old 09-06-2011, 06:44 PM   #112
bwallace530
My Ride: 325
Take some in the garage or out side even if it is raining. I really do want to do this just have never seen any pics of the cut off either.
bwallace530 is offline   Reply With Quote
Old 09-07-2011, 10:54 PM   #113
a325h
I finally finished this retrofit.
I will get an image of the cutoff tomorrow evening, and like shadow said, its quite beautiful.
Old 09-08-2011, 05:11 PM   #114
a325h
More pictures!
Name:	2011-09-08 17.32.10.jpg
ID:	416104   Click image for larger version
Name:	2011-09-08 17.32.19.jpg
ID:	416105   Click image for larger version
Name:	2011-09-08 17.32.27.jpg
Old 09-08-2011, 05:16 PM   #115
Solidjake
Zero. Leaks.
Solidjake's Avatar
My Ride: '02 330i 6MT
^ Nice!! Post some pics of the cutoff at night.
Old 09-08-2011, 05:17 PM   #116
bwallace530
My Ride: 325
Wow that looks great. How much did it all come out too $$
Old 09-08-2011, 05:31 PM   #117
a325h
Here is what I found:
(2x) 35w Ballasts and (2x) H1 bulbs --> $150.27 (From Retro-Solutions)
(2x) Morimoto Mini H1 projectors and E46 Shrouds --> $143.80 (From TRS)
So that totals out to be $294.07, but I also needed to buy a new Passenger Headlight (and the Drivers side was replaced for free). So that was an additional ~$250 for me.
I also have some "xenon" fog lights coming in to give it a more white/blue look when I turn them on, rather than the ugly Amber.
If anyone has a good idea of what clear/smoked corners I should get and where from, please let me know!
Old 09-08-2011, 07:53 PM   #118
a325h
Cutoff as requested! I think this is a beautiful blue cutoff myself.
Name:	2011-09-08 20.34.12.jpg
ID:	416118   Click image for larger version
Name:	2011-09-08 20.34.33.jpg
ID:	416119   Click image for larger version
Name:	2011-09-08 20.34.45.jpg
Old 09-08-2011, 08:56 PM   #119
Solidjake
Zero. Leaks.
Solidjake's Avatar
wtf that's better than my lights!
Old 09-08-2011, 09:22 PM   #120
a325h
Granted I was only about 15' away, so it may look better.
Also, does that adjustment look right? I cannot find a place that has a flat 25' then a wall. So I did it at 15' and aimed a bit higher and further spread.
Rate This Thread
