The Showroom
Thread Tools Search this Thread Rating: Thread Rating: 11 votes, 4.27 average. Display Modes
Old 09-04-2011, 10:11 AM   #1
bimminge46
My Ride: 323Ci, 89 325i ETA
Post your wheel stud conversions/fancy nuts!
Post pictures of your wheels with stud conversions with your fancy nuts. (75mm up to a 12mm spacer, 90mm above 12mm)
E30 in progress.
bimminge46 is offline   Reply With Quote
Old 09-04-2011, 05:55 PM   #2
southpaw
My Ride: E36 M3 and E36 318ti
I will not show you photos of my nuts.
-Brandon
239whp/227wtq @2700lbs
southpaw is offline   Reply With Quote
Old 09-04-2011, 05:56 PM   #3
@mir
My Ride: '04 ///M3
c0ckblock
(pause)
@mir is offline   Reply With Quote
Old 09-04-2011, 07:11 PM   #4
bimminge46
lol
E30 in progress.
Old 09-04-2011, 07:36 PM   #5
SkrApUNB
My Ride: 03 325i
End thread. And
Serious though. Id like to see some Stud conversions too.
-Brandon
SkrApUNB is offline   Reply With Quote
Old 09-04-2011, 07:50 PM   #6
330i ZHP
330i ZHP's Avatar
My Ride: have 5 doors and FI
check the threads on both of my cars - there are pics in there
/_________\
O==[][]==O
Old 09-04-2011, 08:47 PM   #7
omhl
My Ride: E46 M3 6MT
Send a message via AIM to omhl
my old car had them
omhl is offline   Reply With Quote
Old 09-05-2011, 01:16 AM   #8
loong
My Ride: loves speedbumps
75mm Vorshlag studs. Work RS lug nuts.
loong is offline   Reply With Quote
Old 09-05-2011, 01:28 PM   #9
bimminge46
looking good
E30 in progress.
Old 09-05-2011, 01:47 PM   #10
uhhhmeeer
My Ride: E36 M3
Old 09-05-2011, 02:07 PM   #11
///M3Turk
My Ride: M6 ,X5, R6, M5, M3
Send a message via AIM to ///M3Turk Send a message via MSN to ///M3Turk
Best wheels i had
And Nick (Ferrarix99)'s setup
Firat
///M3Turk is offline   Reply With Quote
Old 09-05-2011, 02:08 PM   #12
xaviman
My Ride: Supercharged
in for more pics!!!
Screen shot 2014-01-25 at 12.36.33 PM by xaviman, on Flickr
Instagram: xaviman
xaviman is offline   Reply With Quote
Old 09-05-2011, 04:08 PM   #13
southpaw
Mine are all go no show.
It tends to go with the theme of the car.
-Brandon
Old 09-05-2011, 04:25 PM   #14
bimminge46
you can track any bmw....doesn't have to be an m3
E30 in progress.
Old 09-05-2011, 04:26 PM   #15
SkrApUNB
My Ride: 03 325i
Whats the benefits of doing a stud conversion?
I think one reason its low on the list of things i want to do.. i've never heard of Lug bolts breaking. but i have heard of studs breaking. Im sure it won't happen very easily, if at all, but theres always that chance and I'm sure theres always that chance with my current lugs as well.
-Brandon
Old 09-05-2011, 04:31 PM   #16
Andy2108
My Ride: SpecE46 & E46 M3
I'm ordering the bimmerworld studs today
De gustibus non est disputandum.
Old 09-05-2011, 04:42 PM   #17
dreamdrivedrift
My Ride: 99 M3 & 95 325i
Send a message via AIM to dreamdrivedrift
Way easier to mount on wheels. I've heard of a LOT of extended lugs bolts breaking. I decided to go with studs because of the ease of use, plus if you get high quality studs such as the Vorshlag studs, and you don't overtorque them, it's very unlikely for them to break. That said, if you're putting it up to track conditions (a lot of extreme heat cycling), you should be replacing preventatively every few seasons.
Chris
dreamdrivedrift is offline   Reply With Quote
Old 09-05-2011, 04:44 PM   #18
bimminge46
easier to change wheels and spacers, better seating and balancing of the wheel, stronger. The main reason I am converting because I am running a few different spacers and I want a locking nut on my wheels. People with spacers cannot use a type of rad lock bolt with spacers. I also find it easier to switch spacers out. Tracking is next
E30 in progress.
Old 09-05-2011, 04:47 PM   #19
bimminge46
I ordered vorshlag studs. Do you know the torque spec on the studs and muteki's lugs by chance?
E30 in progress.
Old 09-05-2011, 04:54 PM   #20
smares21
My Ride: M3
Red loctite. 20-30 lb/ft on the studs. Then attach wheels and torque down lugs to 80 lb/ft. remove lugs/wheels and ensure stud tightness. Reattach wheels. Do it again after a few heat cycles.
Clarkson on the 1M: "There's a straight six engine at the front, a manual gearbox in the middle, and drive goes to the back. That's page 1, chapter 1 from the petrosexual handbook."
smares21 is offline   Reply With Quote
