Rating:
Display Modes |
#321 |
I was actually wanting to know what we should be using b/c I will be doing my VCG soon. I looked through this thread, but just see alot of discussion about it and never any definitive "use this stuff or your car will blow up".
#322 |
My friend's a BMW Master Tech at a local dealer. They use RTV on the the 90 degree half-moon (front and rear) and where the VANOS meets the head.
I followed this guidance and have since put 7K on my VCG with no leaks.
All truth passes through three stages. First, it is ridiculed. Second, it is violently opposed. Third, it is accepted as being self-evident. - Arthur Schopenhauer
#323 |
I used to be a tech. I have never had ANY trouble sealing a valve cover until now. I have been using silicone; and I have also used trim adhesive (not on this car). I'm going to redo mine with the Permatex rubber gasket product.
#324 | |
My Ride: 08/2000 330Cic x2
Engineering's in the details, which is why I posted a link to the actual product from the mfg.'s site. Schnell |
#325 | |
I don't think there ever is any definitive answer, because materials testing (and a damn lot of it) is going on right now. Especially since my wife's at work. ![]() The entire goal is to make things the most durable for the right cost. At some point, a lab tech will come up with an entirely different formula for the rubber gasket goop so it will never get brittle, after which it will never be used because cars will be outlawed for electric hovercraft. Look at ethanol additive to gas. They've now found a bacteria that lives with ethanol and eats steel. The entire national pipe grid that transports gas to local tanker filling stations is starting to show microfractures, and will likely fail within two years. This is what you get when Congress thinks they're engineering gods. So..... just change the VCG every two years as routine maintenance and never have an oil leak? Put RTV on the half moons to keep it tight for four years? Or use the Grey dressing and have the gasket last for ten years? ![]() As for me dear horatio, I'll let you know how the grey goop holds up. |
#326 | |
What is the grey goop you are referring to? I know there are 1,000 different options, but right now what is accepted as the *best* option for helping seal our VCG's? *Sidenote- You should post up that steel eating bacteria tidbit in the science thread in the OT forum! I'd love to read more about that. |
#327 |
Simmer down, y'all. You guys are seriously splitting hairs.
-BMW has their procedure of putting Drei Bond 1209 in a thin layer around the sharp edges around the end of the cams as shown here: http://tis.spaghetticoder.org/s/view.pl?1/06/04/49 -If you are doing anything different, than it is entirely up to you what you choose, and also your own risk. If you want to use anything other than BMW's recommendation, you should do your own research to find what you deem "best." -I'm personally not just a big fan of putting anything on gaskets, as I do not like the associated mess, nor have I had any problems with leaks. If you want a safe general purpose sealant, I highly recommend Loctite 598 Black RTV which will work for just about any automotive gasketing situation: https://tds.us.henkel.com//NA/UT/HNAUTTDS.nsf/web/1C4CD3E8A695CF24882571870000D84D/$File/598HB-EN.pdf
#328 | ||||
#329 | |||
My original post that gives the link to the BavAuto DIY that uses the Permatex grey goop is here: http://forum.e46fanatics.com/showpos...&postcount=309 Grey goop mfg. link http://www.permatex.com/products/aut...t_Dressing.htm Quote:
http://www.asminternational.org/port...00621e010aRCRD Mach Hmmm.. one more bit of trivia drooling from my mind - the largest life form on the planet (in terms of total biomass) is iron eating bacteria found under the crust. |
#330 | |||
My entire point is that the 10 year old BMW recommendation of Drei Bond 1209 is, well, 10 years old. A lot of research in sealants has occurred in that time which can be of great benefit to your car. And I vaguely recall this stuff no longer being available from BMW. Even your own post recommends a non-BMW product (Loctite) so what gives with the 'anything other than BMW at your own risk' hysteria? I think you're doing a grave disservice to the community running around like chicken little and flapping your arms like the Lost In Space Robot - "Warning Will Robinson, not approved by BMW." Or is the BMW engineering god so good that Raj is Satan and we transgress in your eyes to use the besian seals in the VANOS unit? That stuff is most certainly Not recommended by BMW. Quote:
Hey, my wife gets 120 grand a year to split hairs, so somebody must think it's worthwhile. Quote:
And Henkel's a good company, so do you think they're splitting hairs by having more than one RTV product to be used on everything? 5020; 5040; 5045; 5060; 5140; 5145; 5210; 5211; 5362; 5366; 5367; oh go read the list yourself http://tds.loctite.com/tds5/search.a...499&Q_PROP22=0 Schnell PS: Your link doesn't work by the way. It has a typo, so here's a working one: http://tds.loctite.com/tds5/docs/598HB-EN.PDF PPS: Interesting to note 598 doesn't show on the Loctite Consumer Product line website, only the Blue and Red. |
#331 | |
.......... (in my best Darth Vader Voice) |
#332 |
Schnell,
Are you a little worked up for some reason? Or are you just trying to start a fight over RTV? -BMW has credibility, that is why I recommend following their advice above all else on their products. I haven't shown anything to prove my credibility either, and that's why I still recommend BMW's procedure over mine, in addition to not wanting any liability. You haven't shown anything to prove your credibility either. -The CCV has nothing to do with the valve cover gasket, so that information is null. -If you want to me elaborate on my preference to not adding anything to gaskets, I don't like to put anything on paper, rubber, or metal gaskets most of the time, and this is usually the manufacturer's suggested procedure. On some cases, like on my BMW M54 I chose not to use any additional product on the valve cover gasket. In the case of my Mercedes-Benz M102 I chose to use an RTV sealant on the normally bare seal between the iron block and the aluminum timing cover. I'm not really sure why your wife's salary needed to be involved in this conversation? -I gave a recommendation for a good general purpose gasket maker, that is all, and you can reread what I wrote if you don't believe me. I never said to put it on a gasket, but you argue not to put it on a gasket, for the same reasons I personally don't like to put it on a gasket but did not state. Similarly, I never said anything even implying it should be used for all situations and that every other Loctite formulation is unnecessary. -Lastly, my link doesn't have a typo, it simply wasn't automatically hyperlinked by the forum.
#333 |
My car came with some form of RTV from the factory. This is certain. Im the only owner and when I changed my VCG for the first time there was clearly evidence of some form of clear-like RTV. Whether it is the elusive Drei-bond or something else, BMW absolutely applies RTV at the factory.
#334 | |
#335 |
What do you mean by this comment?
#336 | |
Thanks! Exactly what I was looking for.
To the other naysayers, i'd have to say I agree with Mach's view on NOT creating a gasket, or using a gasket maker. All of my experience with gaskets has been of the paper/cardboard(not sure of the exact material) and I believe those could use a thin layer of RTV. I also had another application that used MLS(multi-layered steel) gaskets, and the preferred and proven brand of them actually comes with a layer of rubber rtv already applied around them. But in the BMW's case it is using a rubber gasket, therefore applying more rubber does not make sense to me. Quote:
#337 |
It appears he is implying that BMW's from the factory have a faulty application and therefore their VCG's fail prematurely.
But realistically the majority of VCG's have lived a reasonable life expectency of 8-10 years with the factory's application. |
#338 | |
He may also not realize that leaks from age are not related to the RTV usage, but rather time and heat which begins to shrink the gasket making it brittle and creating small gaps. RTV or not, youre still going to get leakage after some time and heat. Keep in mind the reason for RTV usage is to cover areas where the gasket does not sit flush along the perimeter of the head. THIS is why RTV is used. When the gasket is unable to conform tightly to the surface RTV is used to close any tiny gaps. These microscopic gaps are found along uneven surfaces where the head meets the VANOS and where the flat VANOS surface curves down into a half moon at apporximately a 90 degree angle. The gasket itself does a good job of sealing along the perimeter except for the uneven surfaces. THAT is where RTV comes into play. Its not meant to be applied along the entire surface. Good god no!
#339 |
#340 | |
If its coming off for maintenance (valves, VANOS, etc.), regardless of mileage, I'm replacing it with a new one. I would never resuse a VCG. We all have our own standards of what is acceptable and good practice. VCG leaks are not the sole domain of RTV. Re-using a VCG will drastically reduce its life compared to never removing it at all. One must also ensure BOTH mating surfaces are clean and free of any debris. Replacing the rubber grommets and bolts. Not only torquing to the correct value, but torquing it in the proper pattern (inward to outward in a star pattern). Even a failing CCV can blow out your new VCG. So lets all not hang leaks on whether one applies RTV or not. There are many other factors contributing to leaks.
