The Showroom
Thread Tools Search this Thread Rating: Thread Rating: 39 votes, 5.00 average. Display Modes
Old 09-26-2011, 08:26 PM   #61
travisn
My Ride: Nothing
in for electronics logistics...
and I wouldn't worry about that header. They are damn expensive and you will be going FI eventually. a little dent wont hurt anything.
travisn is offline   Reply With Quote
Old 09-26-2011, 08:45 PM   #62
BDUB328I
My Ride: bmw 328i S54 sedan (
Originally Posted by 323tom View Post
sick project! hey what about me I have a HPF s54 323 soon to be wide body
Yours is coup, (I'm not impressed).
What did u do with ur wiring?
BDUB328I is offline   Reply With Quote
Old 09-26-2011, 08:48 PM   #63
BDUB328I
Thanks for the info
And don't worrie, I let everyone in on the wiring info once I figure it out
Old 09-27-2011, 11:49 AM   #64
dhbamby
My Ride: 02 PPGd DOM4 Bugeye
any plans for the interior?
dhbamby is offline   Reply With Quote
Old 09-27-2011, 12:09 PM   #65
Kwando
My Ride: rolls Volks TE-37SL
Good luck on the project! I wish I had the mechanical skills to undertake something like this
Kwando is offline   Reply With Quote
Old 09-27-2011, 12:57 PM   #66
Krystian_E46
My Ride: E46 M3,AA3 ZHP,S544D
Send a message via AIM to Krystian_E46
Your doing the same swap I am goodluck mine is going to be a little more unique
- Krystian
http://www.facebook.com/kgawlak
Instagram : Krystian_E46
Owner of many E46's :)
[Currently own 2004 M3, 2004 ZHP HARD MOTORSPORT Flares & Centerlocks, 2005 AA 2.5 Kit ZHP(SOLD), S54 Sedan, 01 330ci and 1 Coupe 1 Sedan 1 E46 M3 parts cars]
Krystian_E46 is offline   Reply With Quote
Old 09-27-2011, 01:20 PM   #67
BDUB328I
what are you doing that is making it more unique? i see your sig says something about 2008 conversion? you plan on putting e90 body pieces on it? also what are you doing with the wiring??
Old 09-27-2011, 01:22 PM   #68
BDUB328I
do it bro! its not that bad, everyone makes it seem like rocket science when really its just greese monkey stuff. anyone can turn wrenches
Old 09-27-2011, 02:11 PM   #69
Krystian_E46
No the black one was my old Sedan sold that, my current project is the silver one you see in my sig, that's getting a full m3 swap, plus m3 body parts such as quarters and then suspension too, debating on coils or bags, its pretty much going to be something lile jeppej just not as crazy cutting cars in half, but yeah got a good a good deal on a whole bearly hit m3 so much easier for me to finish this project
- Krystian
Old 09-27-2011, 02:21 PM   #70
BDUB328I
yea thats basicly what im doing but instead of trying to fit m3 body pieces im just gunna weld on some wide fenders....
did you figure out what your doing with the wiring??
this has been my bigest concern and i havnt had anyone give me a deffinate solution...
Old 09-27-2011, 02:30 PM   #71
Krystian_E46
Planning on either running the old or actually ripping everything out the m3 and putting it in the sedan
- Krystian
Old 09-27-2011, 02:33 PM   #72
BDUB328I
but if you rip everything out what will you do with the rear doors? im thinking im gunna use the stock body harness and me m3 engine harness, however im not sure if they will plug and play together nicely
Old 09-28-2011, 08:18 AM   #73
BDUB328I
started taking connections off the engine yesterday, took me about an hour to get two connections off (one being the throttle cable) then after finnaly getting thoes two off i gave up for the day... just wasnt feeling it
Old 09-28-2011, 03:25 PM   #74
BDUB328I
Can someone please give me some advice on things i should replace or mod while my car is completely appart...
what i mean is what am i going to want to end up doing down the road that will be 10x harder once the parts are in the car?
i plan on replacing most of the suspension bushings, SS brake and clutch lines, reinforcing the subfame. but what else should i do while everthing is easy to get to??
also if you could suggest a company to get these items from it would be great.. thanks in advance
Old 09-28-2011, 03:30 PM   #75
0-60motorsports
My Ride: E30 325ic & E46 M3
Send a message via MSN to 0-60motorsports Send a message via Yahoo to 0-60motorsports
Also dont forget to replace the Guibo and center bearing and diff cover with bushings and the new diff bolts. You can get all OEM parts from getbmwparts.com or thebmwpartstore.com
EURO 04 M3: GC Coils, Eibach Sways, PF RTABs, RE RCAs, INTRAVEE II, Black Roundels, ///MFEST Badges, Depo's, VCSL Bumper + Race Lip + CF Trunk + CF Rear Diffusor + CSL center console, DIETZ TV in Motion, SS Stepped Headers, SS Catless S & Res X-pipe, SS Race, Z8 Starter Button, Lamin-X, OEM CSL Steering + CSL interior, OEM CSL Intake, EVOLVE Alpha-N Tune, BBS CH's, FX-R 3.0's, ST40's, DINAN Rear Strut Brace, BW Oil Cooler, 3.91 gears
0-60motorsports is offline   Reply With Quote
Old 09-28-2011, 03:37 PM   #76
BDUB328I
the center bearing in the guibo? also replace the diff cover?? really?? i didnt know they were prone to failure. or are you saying replace the diff bushings?
im confused....
also i will be replacing every bolt in the suspension. my m3 parts are completely seperate, the guy a got them from had them completely appart. and did not give me any of the bolts.
Old 09-28-2011, 03:45 PM   #77
0-60motorsports
im confused....
Drive shaft coupling 26 11 2 226 527, Drive shaft Center bearing 26 12 2 282 495, The M3s diff bushing do not come separate, they come as a full cover with bushes 33 11 2 282 482, replace it if the bushings are worn. Upgraded diff bolts 23 00 1 222 891 x 2 and 33 17 7 840 535 x 1.
Look at www.realoem.com for more info Bro
Old 09-28-2011, 07:56 PM   #78
JohnBlaze
My Ride: Black Sunshine
I don't remember reading about you doing the front M3 suspension, but even if you stay non M fitament up front I'm pretty sure you can get the M3 front stingray underpan and M3 FCAB carriers with non-M bushings. It should all bolt right up to your front suspension and create more structural ridgity replacing that tubular triangle in your picture on page 1. That or even get the non-M stingray pan.
If your front control arms are loose replace those and do the inner and outer tierods. Could do the steering guibo too.
05 ZHP w/Epic tuned s54, Euro headers&Sect.1, Dinan 3.91 and a lot of other things built by Road Race Technologies
JohnBlaze is offline   Reply With Quote
Old 09-28-2011, 08:08 PM   #79
BDUB328I
Thanks for the great responses!
Also I'm doing full m3 front suspension and steering
Old 09-28-2011, 10:20 PM   #80
BDUB328I
and thank you very much sir! this is exzactly the info im looking for!
one question with the drive shaft center bearing, are you talking about number 7 or number 8 here? because the bearing is number 7 but the pn you gave is number 8... should i just get both?
http://www.realoem.com/bmw/showparts...97&hg=26&fg=10
so far the parts you listed will cost me 200$ not to bad..
