Polls & Surveys - Please Participate!
This forum contains "official" polls and surveys |
| View Poll Results: Vote: Do you believe in preventative maintenance? | |||
| Preventative maintenance is key to good vehicle health |
313 | 83.24% |
| Preventative maintenance is a waste of money. If it ain't broken, don't fix it! |
63 | 16.76% |
| Voters: 376. You may not vote on this poll | |||
Rating:
Display Modes |
#81 | |
Just Nuts
#82 |
Not looking to do that, I just wanted to answer the question of why I voted no. Don't know why the 20 others did. Maybe they all were aware of the other thread too, and saw this poll for what it is.
#83 |
My Ride: cars older than you
now that i read some of them i do kind of understand your logic. I do Preventative maint... not Pre-Preventative maint. My belt is starting to get dried out so i'll get a new one soon but at the same time get underdrive pulleys, fix and upgrade at the same time. I have the VANOS kit in my garage right now because i have what i call an idle hiccup sometimes but just havent had time to do it yet. I kinda think I wanna do both together since i'll have everything apart.
But ET... not happeneing any time soon, mine is perfectly fine still and no leaks (only 65K, gonna be a while before I even think about it)
![]() Respect Your Elders Last edited by Hermes; 10-12-2011 at 04:09 AM. |
#84 | |
#85 | |
"hey when we are in there replacing your water pump, even though none of them are bad yet, do you want us to replace your tstat, hoses, and expansion tank?" Oh and I voted no.
![]() Have a oil or coolant leak? Click here!:http://forum.e46fanatics.com/showthr...732&highlight= ABS/DSC/Brake/Airbag light on?? Click here!:http://forum.e46fanatics.com/showthr...648&highlight= |
#86 | |
I'm for!! (when i have money)
2. 2 brand new Bosch post cat oxygen sensors |
#87 |
My Ride: Touring, and others
We came up to the mountain home yesterday. Brought 3 of the vehicles. Not a speck of trouble, thanks to preventative maintenance.
[/SIGPIC]I'm fluent in 3 languages:
English Sarcasm Profanity |
#88 | |
Makes Sense
Because you'll get a new longer belt to use with the under-drive pulleys. And I travel with a spare one of those because no one would know what size to replace it with at a dealer or parts house. Got it for $15 on eBay or Amazon.
And when I did the vanos seals, it stopped a regular hiccup I had at idle. And by the way, on my '04 with 80K miles I took apart the valve cover gasket and the old one was just as flexible and soft as the new one. This in contrast to many who have said that their old gasket was dried and brittle and crumbled. Mine peeled off perfectly. Of course I put a new one on for the $24 for the new part. Quote:
#89 | |
My Ride: 1999 323i 5-SPD
MODS P46 Projectors + FX-R Retrofit + 6k D2S / 60 LED AE's / Smoked LED Tails / Smoked Turn and Side Markers / BSW 10" Sub /ZHP Knob / Matte Black Grills / DICE / Parrot + Connects2 / OEM Alternative Alarm Mod / Clutch Switch Delay Mod / M3 Rep Front Bumper / 3M Black CF Di-Noc Wrap / K&N Intake / 35% Tint All Around / Black Short Eurotray / 545i Shifter |
#90 | |
Cars need both preventive maintenance and repair. Taking things to either extreme is ridiculous. For example replacing each and every part by a certain date or mileage, regardless of their condition is not practical, if not absurd. OTOH, only fixing after something breaks is asking for trouble. For example, for cars that have a timing chain, waiting for it to fail first is going to cost you a whole new engine. So, what to replace under prevention and what not? The designers and makers of your cars know best. They've collected that information in your manuals, under maintenance schedule. They list the items that should be replaced by age or mileage. They also list the items that should be only inspected and replaced only if needed. This poll is a fail. |
#91 | |
Platinum Plus Quality
At the end of the day, those cars are more likely to break down. A lot more likely.
![]() Cooling | Maintenance | Vacuum | Suspension | Costs "Be a yardstick of quality. Some people aren't used to an environment where excellence is expected." -Steve Jobs |
#92 | |
#93 | |
Well 6 now. |
#94 |
Underdrive pulleys are larger than stock
So a longer belt is used in order to not move the tensioner pulley to a different position.
My underdrive pulley kit included two pulleys along with a new drive belt. Where are you buying yours from? |
#95 |
I havent decided. Didn't know the belts would be different. All sites I have checked out, didn't mentioned anything about replacing the belts. Will the belt typically be included? Where did you get yours from?
#96 | |
#97 |
First of all, it's belt, not belts
You do not want to underdrive your A/C, so nothing changes there.
I got mine at UUC a few years ago. The new supplied belt is mentioned on their kit: http://www.uucmotorwerks.com/udp/ But be leary of ordering from UUC lately as you may unfortunately have the experience I had recently when I had to cancel my order after more than one month of no action to ship: http://forum.e46fanatics.com/showthr...one+bad&page=2 |
#98 |
Again, I'm glad all two of you agree.
#99 | |
#100 |
Fluids, filters and other wearable items (spark plugs, belts etc) I replace as preventive maintenance. Also parts that are well know to fail - water pump, etc if I'm already working in the general area. Anything else I wait to fail.
