Old 01-09-2010, 12:52 PM   #21
Zero2_2005
My Ride: 328i
Thank You!! Just got new battery!! A Duralast 49 DL at autozone!!
The guy that helped me said that he had the same one in his 330ci. He told me I made a very good choice and couldn't believe me that I used a 600 CCA battery compared to the new one that had 800+ CCA!! I now officially feel stupid when it comes to hard starts that it is usually a bad battery. I will now use the method above for future use. Thanks all for your time to help!!!
Zero2_2005 is offline   Reply With Quote
Old 01-09-2010, 12:57 PM   #22
Zero2_2005
My Ride: 328i
I also got some battery terminal cleaner with some soft cushion to put on the terminal before connecting the cables too.
Old 01-09-2010, 01:08 PM   #23
taibinhvuong
My Ride: E46 99' 328i
Good, glad that you made it right! try to keep the battery terminals clean and tight at all time, this will help prolong your battery life as well.
taibinhvuong is offline   Reply With Quote
Old 01-09-2010, 01:17 PM   #24
taibinhvuong
The guy at Advance auto is at fault, because he charged and tested out your battery and said it's good. He should have known how to test a battery.
Old 01-09-2010, 01:23 PM   #25
jfoj
My Ride: 330CiC, M5, X5, E93
Would recommend you still check out the car further after installing the new battery just to eliminate any other problems.
Is this car a daily driver or does is sit for more that 3-4 days at a time?
If the car sits, would recommend getting a Battery Tender for keeping the battery topped off, especially in the cold months.
jfoj
Old 10-17-2011, 07:19 PM   #26
gramps05ZHP
My Ride: 2005 330i ZHP
I have been having trouble with excessive current draw draining my battery. Early this summer, I thought it was my aging battery, so I replaced it. No Help. I have been troubleshooting this for a while now. I have purchase software and OBD II pigtails to assist with this. What I have found is that once I leave the car, it takes 16 minutes for it to go into sleep mode, until then it has an excessive amount of draw of about 3 amps. Once it sleeps it will go to about 1.2 amps, but something keeps activating to boost the amp draw again and again. I am unable to locate it just yet, but I will, I have it narrow down to the GM5 or the Radio.
I have done searches on this site and have not found too much, but looking at X5 forums and doing a search for a "closed-circuit current measurement adapter" I came across some good info. For those that have legit battery problems, get a new one, but for those of us that don't, take a look at the inside of your car not sleeping very well.
Good Luck.
gramps05ZHP is offline   Reply With Quote
