Thread Tools Search this Thread Rating: Thread Rating: 173 votes, 4.93 average.
Old 10-19-2011, 06:51 PM   #241
Solidjake
Zero. Leaks.
Solidjake's Avatar
My Ride: '02 330i 6MT
To those that have done the retrofit PLEASE post up pics of the cutoff/light output at night.
Old 10-19-2011, 08:42 PM   #242
domcreates
Banned User
My Ride: Jet Black 1999 323i
Originally Posted by solidjake View Post
to those that have done the retrofit please post up pics of the cutoff/light output at night.
+1
domcreates is offline   Reply With Quote
Old 10-19-2011, 10:39 PM   #243
RevitupM3
My Ride: 04 M3
got a set of headlights in the FS you can use the guts in yours
RevitupM3 is offline   Reply With Quote
Old 10-20-2011, 12:04 AM   #244
a325h
My Ride: '13 2.5SEL Jetta 5MT
Here are mine from earlier in the thread:
TRS 5000K XB Bi-Xenons | ümmitza 6000K Opaque AEs | Metallic Tinting | LED Interior Lights
^2001 E46 325i^ SOLD
Current: 2013 SEL 2.5 Jetta 5MT
2010 E90 335i M Sport in Le Mans Blue
a325h is offline   Reply With Quote
Old 10-20-2011, 07:36 PM   #245
silp3
My Ride: 02 325
So I installed my set. they xenons look great!
I am having issues with leveling, however. The two headlights look like an X they way the pattern is coming off, rather than a straight line. Any one have insight?
Here is a picture:
silp3 is offline   Reply With Quote
Old 10-20-2011, 10:22 PM   #246
silp3
My Ride: 02 325
Here is a picture:
All fixed guys! I am happy with it. Though, I will be doing some tweaking left and right.
Quick question: I noticed the light output doesnt go out very far left or right on the side of the road. Is this simply due to the size of the MH1s? If i went FX-R would the pattern be larger and more broad?
Pics of the current:
Old 10-20-2011, 11:10 PM   #247
trj
My Ride: 325Ci
Question to those who have done this retro-fit and have angel eyes installed.
I am looking at orion lites by umnitza :
http://www.umnitza.com/index.php?mai...oducts_id=5686
I am going to get the angel eyes first and go for the retro fit with h1s.
Which ones should I order? angel eyes for halogens or xenon/bi-xenon?
I drive 01 325CI if that matters.
Old 10-21-2011, 01:16 AM   #248
xxilikericexx
My Ride: E36 M3, E46 325i
Anyone running a 55w ballast setup with this retro into the halogen housings?
xxilikericexx is offline   Reply With Quote
Old 10-21-2011, 04:48 AM   #249
Saintluk2
My Ride: 2000 323i sedan
Saw a thread on hidplanet about 55watt eBay ballasts being used in the mini h1and the OP claims they are the cause for reflecting material peeling off inside the projector.
Saintluk2 is offline   Reply With Quote
Old 10-21-2011, 03:02 PM   #250
M325er22
My Ride: 2001 325i
Just bought a kit earlier today! It was this or a swap from an M3 but i wanted spend less and get my hands dirty a lil bit! ill post pics when i finish!
Sent from my LG-P509 using Bimmer
M325er22 is offline   Reply With Quote
Old 10-21-2011, 05:47 PM   #251
KohbraxE46
My Ride: E46 328i
Projectors are amazing
Although I had trouble putting on the shrouds. Great DIY .
Also I did not have to take apart my headlight to mount my projectors. !
Quick question.
Why does the light flicker ?
Is it the bulbs or ballast ?
KohbraxE46 is offline   Reply With Quote
Old 10-21-2011, 05:53 PM   #252
KohbraxE46
My Ride: E46 328i
You want halogen halos because your housing and bowls are halogen.
They fit perfect.
Old 10-21-2011, 06:41 PM   #253
trj
My Ride: 325Ci
Thanks kohbraxe46
will order a set now
Old 10-22-2011, 06:20 AM   #254
KohbraxE46
My Ride: E46 328i
Thanks kohbraxe46
PICSSSS
Old 10-22-2011, 06:47 AM   #255
KohbraxE46
My Ride: E46 328i
So beautiful .
The best cut off I've ever seen.
And I drive alot of nice cars
( due to work )
Beautiful bright white
Great light out put!
An the white matches my ccfls
The closest I've seen to these cut off and out put
Is the new Audi A7
ID:	421963   Click image for larger version
Old 10-22-2011, 01:28 PM   #256
trj
My Ride: 325Ci
Got the AEs ordered. Will take the pictures once I get them installed. Going to be AE plus projectors retrofit soon.
Will order the projectors next month. Spent too much this month on the car
Old 10-25-2011, 12:33 PM   #257
a325h
After about a month with this setup I am noticing that I am getting a lot of flickering while the car is running, but when the lights are on and the car is off there is no flickering at all.
Also, my right side cutoff is turning yellow rather than the nice blue it has been before. (See pictures above)
Whats going on here? I have a relay installed (the 9006 from TRS) and it still flickers. It also tells me I have a bulb out on the side the relay IS hooked up to. Ill get some pictures of the new cutoff tonight.
Old 10-26-2011, 05:51 PM   #258
coby1
Just Road Miles
coby1's Avatar
My Ride: 325i sport pkg
I need to do this i have the whole kit with fogs that have been sitting in a box for like 6 months lol.
Edit maybe i will try to swap over oem xenons to the good holders and put my kit projectors into the high beam side// the oem's might not look too pretty but i plugged them in and they worked and only cost me 20.00ea at the junkyard that i go to lol.
<a href=http://img211.imageshack.us/my.php?image=coby112ef1.jpg target=_blank>[img=http://img211.imageshack.us/img211/3589/coby112ef1.th.jpg]</a>
coby1 is offline   Reply With Quote
Old 10-26-2011, 09:37 PM   #259
Mpowwahh
My Ride: 02 325ci
Thinking about doing this! Great thread. I've been doing some research and found that the XB35 bulb sold by TRS has the best light output out of all the H1 bulbs currently available, It's light output was tested to be the same if not better than the Philips D2S, which is commonly used as an OEM bulb. The only drawback being that it puts off more UV radiation which can arguably cause damage to headlight components, e.g. projector bowls, lenses, etc...Has anyone used this bulb? If so have you noticed any degradation of headlight/projector parts? I'm leaning towards this bulb but don't want to pay $70 just to find out it is going to ruin my headlight setup in the long term.
Mpowwahh is offline   Reply With Quote
Old 10-27-2011, 12:14 PM   #260
silp3
My Ride: 02 325
I am using the TRS H1 bulbs and ballast. I havent noticed anything significant for the past week and I drive with my headlights on every time i step foot in my car. Besides, I don't think I will be keeping my car long enough to worry about the long term issues. I have been keeping a close eye, though
Rate This Thread
