Thread Tools Search this Thread Rating: Thread Rating: 648 votes, 4.95 average. Display Modes
Old 10-28-2011, 11:59 AM   #21
330ciandr6
My Ride: .
Send a message via AIM to 330ciandr6 Send a message via Yahoo to 330ciandr6
Originally Posted by Nervous View Post
Disagree with what? Actually you agreed I had a very similar drops issue and oil pan gasket fixed it.
Yes, but it's not the oil pan most of the time. The rear main seal actually leaks pretty often on these cars. I know the oil pan does as well. But I posted the picture to show what a leaking rear main seal can look like. That may not be what's leaking in that picture, but that's what it looks like when one does leak.
Have a oil or coolant leak? Click here!:http://forum.e46fanatics.com/showthr...732&highlight=
ABS/DSC/Brake/Airbag light on?? Click here!:http://forum.e46fanatics.com/showthr...648&highlight=
330ciandr6 is offline   Reply With Quote
Old 10-28-2011, 01:01 PM   #22
330ciandr6
My Ride: .
A couple of my pics related to the topic.
Did you lower the subframe in your garage without a lift to get to the oil pan? I hate dropping subframes without a lift...
Old 10-28-2011, 01:12 PM   #23
Nervous
My Ride: 01 330CI 6MT ZSP EU3
No need lift:
This is an engine support bar from Harbor Freight, $60.
No need to completely remove subframe either, just need to lower it enough to remove/install the oil pan:
Nervous is offline   Reply With Quote
Old 10-28-2011, 01:26 PM   #24
330ciandr6
My Ride: .
yeah, thats what I said, lower it. Hmmm, didn't realize the engine support was that cheap. I got my engine stand from there, might end up getting that support. I'll do my oil pan and rear main at work on the lift, but I think I'll buy the support just to have it.
Old 10-28-2011, 01:38 PM   #25
Nervous
Coming back to rear main seal - if you don't have transmission off yet you can't say for sure it is leaking. I'd recommend to replace the oil pan gasket and test it first.
Old 10-28-2011, 01:47 PM   #26
330ciandr6
My Ride: .
I've done enough of them, I know they leak. Mine very well could be the oil pan. I'll inspect it more when I eventually take the oil pan off. But mine barely leaks so I'm not all that worried about it right now
Old 10-28-2011, 03:05 PM   #27
330ciandr6
My Ride: .
Originally Posted by neil1138 View Post
The E46 is leaking oil pretty badly right now. I know it's the oil filter housing gasket, just need time to replace it.
Come on now, that is pretty easy to replace!
Old 10-28-2011, 04:40 PM   #28
Blocked Out
My Ride: Imola 330i M-Sport
Thank you for a good write up.
If you can add Transmission shifter selector shaft seal for manual trans would be great.
Original BMW Teile ///
IMG_1725
Old 10-28-2011, 04:56 PM   #29
330ciandr6
My Ride: .
Yup. Will work on adding tomorrow morning.
Old 10-28-2011, 04:57 PM   #30
Zell
Zell's Avatar
My Ride: so turbo wow
It's good to know that if you have any one of these leaks, you definitely know it. I keep my engine bay very clean, so I believe I'd notice any of these fairly quickly. The leaks look like they will leave a lot of residue should it happen.
Old 10-28-2011, 06:34 PM   #31
330ciandr6
My Ride: .
Yeah they are fairly simple and easy to spot
Old 10-28-2011, 07:28 PM   #32
Miko_10
My Ride: 330i 5 Spd
No need lift:
so thats how that thing sets up, was looking at that on the site and was trying to figure out how it mounts.
This thread needs a sticky...
FS(PM me if interested, MID Atlantic Area, 22307 zip)
- 2 M68 fronts w/ winter tires, local pick up preferred,
- OEM Pre face Sedan Clears.
Miko_10 is offline   Reply With Quote
Old 10-28-2011, 08:36 PM   #33
330ciandr6
My Ride: .
Old 10-29-2011, 08:50 AM   #34
330ciandr6
My Ride: .
Trans pan leak added. Couldn't find decent pics for it...if anyone has a pic or 2, let me know.
Old 10-29-2011, 09:29 AM   #35
330ciandr6
My Ride: .
diff output seals added.
Old 10-29-2011, 11:09 AM   #36
330ciandr6
My Ride: .
updated
Old 10-31-2011, 09:39 AM   #37
330ciandr6
My Ride: .
Diff cover added
Old 10-31-2011, 11:41 AM   #38
SilverSurfer86
My Ride: 2001 330ci Silver
Awesome post op!! Learned alot
SilverSurfer86 is offline   Reply With Quote
Old 10-31-2011, 11:56 AM   #39
328ci906
My Ride: 2003 M3
Awesome thread, I think two of the pics in the OP's original post are from threads of my leaky E46 lol! My car has come a long way from those days, it's threads like this that really help newbies to solve problems on their own. Nice Work!!
-2000 E46 328i
-2006 E60 M5
328ci906 is offline   Reply With Quote
Old 10-31-2011, 12:06 PM   #40
Drew@Swift Motorworks
Past Site Sponsor
My Ride: Scooty Puff Jr
Originally Posted by jasonbimmer View Post
FYI, the PS reservoir has an o-ring on the cap and it become leaky when old.
if your reservoir is coated in PS fluid, replace the o-ring.
PN: 32411128333
Ive never seen a clean one so I always assumed that was normal
Drew@Swift Motorworks is offline   Reply With Quote
