Old 11-01-2011, 05:08 PM   #1
Zanderini
My Ride: United States
Washer pump
Installed a new pump from pelican and ca hear it pump but no water comes out? Any ideas?
Zanderini is offline   Reply With Quote
Old 11-01-2011, 05:15 PM   #2
GoingNuts
Just Nuts
My Ride: 2004 330Ci
Just keep pumping every time you drive. After a while, it might get fixed by itself when the air bubbles work their way out from the car's vibration and motion.
GoingNuts is offline   Reply With Quote
Old 11-01-2011, 05:46 PM   #3
Zanderini
How long does anyone think it will take for it to get the air out
Old 11-01-2011, 06:02 PM   #4
GoingNuts
Just Nuts
My Ride: 2004 330Ci
It took mine a few weeks. But I didn't drive much. I thought it was a gonna and didn't try that hard to fix it. I just gave it an occasional pump to see if it's started working again. Suddenly, it did.
Old 11-01-2011, 06:15 PM   #5
Zanderini
interesting. from what ive heard from pelican and my indy it should work just right away out of the box. how many weeks did it take?
Old 11-01-2011, 06:23 PM   #6
GoingNuts
Just Nuts
My Ride: 2004 330Ci
But it does work out of the box. You said you could hear it pumping.
I can't remember how long it took. It wasn't something that would strand me in the middle of nowhere in complete darkness while it's raining. So I didn't pay attention. I can suggest you live with it for a while rather than start tampering with the hoses. If they are old, they could well break. Then you will have plenty more broken stuff to play with.
Old 11-01-2011, 06:29 PM   #7
Zanderini
anything else that could be blocking up the line? I understand that i shouldnt worry but it doesnt work right. Id rather spend my time doing the plugs and ignition coils thean mess with that pumper
Old 11-01-2011, 06:41 PM   #8
GoingNuts
Just Nuts
My Ride: 2004 330Ci
Unless you are infected with a washer virus by a shop like I did, there would unlikely to be anything but air bubbles in the line.
Old 11-01-2011, 08:43 PM   #9
Zanderini
anyone else?
Old 11-01-2011, 09:34 PM   #10
briangl92
My Ride: A08 ZSP ZPP SULEV
I replaced mine. Worked immediately. Shouldn't really be a whole lot of air, it's not as if you drained all the hose. Did you drain the reservoir when you replaced it? Gunk builds up in the bottom and can clog the pump. When I replaced mine I drained the tank and the last couple ounces had yellow sludge in it from the washer fluid. If all the electrical connections and hoses look fine, it might be a defective part.
briangl92 is offline   Reply With Quote
Old 11-01-2011, 10:04 PM   #11
Geo31
Ironman
My Ride: 00 328i, 98 M Roadie
Either sludge or a leak somewhere. It should work right away.
George Roffe
Swim: 2.4 Miles
Bike: 112 Miles
Run: 26.2 Miles
Brag: For the rest of your life
Geo31 is offline   Reply With Quote
Old 11-02-2011, 01:22 AM   #12
Zanderini
hey guys thanks for the replies. the issue was fixed upon driving down a huge hill. all of a sudden it jumped back to life and water squirted out. So I must have had air in the line
Old 11-02-2011, 01:26 AM   #13
briangl92
Glad it worked out
Old 11-02-2011, 01:35 AM   #14
blarf
My Ride: '00 323i
Something was clogged or you've got a failed check valve. You shouldn't have to bleed the washer system.
Protip: ignore GoingNuts.
Originally Posted by howie View Post
do you park near poodles?
blarf is offline   Reply With Quote
Old 11-02-2011, 06:51 AM   #15
GoingNuts
Just Nuts
My Ride: 2004 330Ci
Luckily he didn't or he would be replacing the pump and hoses just now. It goes to show random internet voting on diagnoses and fixes by a bunch of clueless people doesn't work.
