Car Care & Detailing
Get detailing answers and tips here |
Rating:
#3181 | |
Any decent polish with good arm pressure or a buffer would remove the old sealant or wax so I doubt that was the cause. I would try to polish the area again. Also what products (polish, pad, buffer vs hand) are you using? The M205 and a white pad should be able to remove a lot of the buffer trails and is one of my go to combinations. If that doesn't do it or if that combination leaves too much behind try using the ultra light finishing polish Menzerna Micro Polish SF 4500 (PO85RD) with a black pad afterward. I'm surprised to hear the M105 and M205 didn't remove the majority of swirls. I typically use at least two orange pads with the M105 and two white pads with the M205 afterward. Use about 10lbs of pressure and turn the PC up to speed 6, move slow and steady for best results. if you need more power try the Surbuf R Series MicroFingers Buffing Pads and the M105 that should do it! Greg @ DI
#3182 | |
Greg @ DI
#3183 | |
#3184 | |
Greg @ DI
#3185 | |
![]() 330i ZHP 6MT | H&R Sport Cup | BMW Performance Intake & SSK | OEM Clears | WeissLicht Angel Eyes | Coby Wheel |
#3186 | |
Greg,
Can you PM me a phone number where you can be reached? I also sent an inquiry via your site
![]() Quote:
#3187 | |
As for the cause the pad may have been a bit dry or too much pressure. When a pad is brand new use a little extra polish so the pad doesn't have dry spots. Another solution some like is spraying a tiny mist of quick detailer (i.e. Poorboy's World Spray and Wipe) on the pad before hand. Hopefully this helps! Greg @ DI
#3188 |
Sending you a PM now!
#3189 | |
#3190 |
Glad the info helped, don't hesitate to ask any other questions we're here to help whenever we can.
Greg @ DI
#3191 |
Greg,
I had a little mishap using some acrylic lacquer touch up paint on my newly resprayed car. Long story short, a blob cured over my urethane clear coat. I've heard these 2 chemicals don't play nice but so far there is no wrinkling or lifting of my existing finish. Is there anything in your experience that can remove touch up paint without harming the existing finish? |
#3192 | |
Greg @ DI
#3193 |
Quick question. My front windshield is pitted with various chips a debre. Anything I can do, besides replacing the whole glass.
#3194 |
Got my car back from the dealer after a detail. It had swirls on the hood when I gave it to them, they're gone but now I see some oxidation marks on the hood. Isn't that something a detail would remove instead of uncover?
#3195 | |
#3196 | |
Greg @ DI
#3197 | |
Greg @ DI
#3198 |
Water/pollen spots
(deleted)
#3199 |
makita rotary buffer ????
Hi Greg,
I restore glass professionally, and I use a water-fed makita rotary buffer. It has a variable speed of 2000-4000 rpm. I am very skilled in polishing glass, I understand how to move the buffer and maintain enough polish to avoid burning the glass. Is this rpm range safe for polishing car paint? -or should I pick up a PC DA. I have an old truck I can practice on before I take it to the BMW, but I figure you would know best. Thanks for your expertise! |
#3200 | |
In general we recommend people new to polishing start around 900 RPMs to be safe. As they become more experienced 1200 - 1500 RPMs is a more normal range. Even though you have plenty of experience with the buffer I'd still recommend starting somewhere closer to 900 - 1200. If you leave the buffer in one spot for just a few seconds it's possible to burn the paint easily. Check out our polishing section of detailing guide to read more about using a rotary buffer. Lastly I would recommend getting a 5.5" pad with a 5" backing plate instead of such a large pad, for more control and safety. Let me know if you have any other questions and I'll be happy to help. Greg @ DI
| Rate This Thread | |
