Old 11-07-2011, 09:17 PM   #21
flipm3
My Ride: 02 M3, 97 328i
Send a message via AIM to flipm3
Have you ever considered the Rogue Engineering Tranny Mounts? I have them in my E46 M3 and they are incredible. No add NVH, but much more durable than OEM.
The next time around, I may consider AKG Motorsports transmission mounts.
2002 E46 M3 6MT | Jet Black . Black Nappa | My Build Thread
Evolve Automotive CF Airbox & AlphaN . Supersprint V1 Stepped Headers & V1 SPipe
flipm3 is offline   Reply With Quote
Old 11-08-2011, 01:32 PM   #22
LivesNearCostco
My Ride: 2003 ZHP 6MT
Just did 2 track days with my BimmerWorld transmission mounts (solid poly with enforcer cups, but not bolt-through) and they felt wonderful on the track but were slightly annoying on the 3-hour freeway drive there and back. Upshifts and downshifts felt very precise compared to stock and probably a bit more precise than the UUC Black mounts without enforcer cups. (Note, I do not have a short-shift kit or DSSR.) On track I didn't notice any extra noise or vibration, but driving home I was running the radio a little louder than usual to mask the extra transmission noise.
I'd say these BimmerWorld mounts are perfect for a car that is >30% track/AutoX. My car is only 10% track/AutoX--as I count the driving to and from events as street driving, not track driving, and I daily drive the car 2 or 3 days a week. My exhaust and intake are stock and pretty quiet, so if you have a loud aftermarket exhaust (or catless headers), you might not notice the extra noise and vibration from these. I wonder if it's possible my driveshaft is slightly unbalanced or my CSB is failing, and that's transmissing extra vibrations to the transmission?
Am thinking of going back to the UUC black transmission mounts but adding the UUC enforcer cups, and keeping the BimmerWorld mounts for the dedicated E36/E46 track car I hope to have someday.
Originally Posted by TxZHP04 View Post
The transmission mounts can transmit quite a bit of vibration on their own, although most say it's best to match the stiffness of the engine and transmission mounts. I briefly ran UUC red poly mounts (non bolt through version) and there was too much vibration for me (and their red poly with enforcer cups caused insane levels of vibration) although at the time I had them paired with stock motor mounts. I ended up with the black UUC mounts with enforcer cups and then later upgraded from stock motor mounts to BimmerWorld's solid rubber motor mounts. This combination is pretty much perfect for me.
Lowering my car's resale value one track day at a time...
LivesNearCostco is offline   Reply With Quote
Old 11-08-2011, 06:35 PM   #23
mrshelley
My Ride: 2004 330i
If you are drag racing or cranking out 400hp at the crank, then OEM works just fine. As for money shift, OEM mounts and an OEM shifter is what I have found to keep this from happening. Also, if you run those stiff mounts and wreck your car be prepared for a broken engine block and tranny mount. Run OEM and the mounts shear off, thus save the block and tranny mount (not really important). As for the life of the mounts, I find that with a stock 330 running about 100 hours of race time, the OEM mounts need to be replaced. Go beyond that, the drivers side engine mount will fail first.
Old 11-08-2011, 06:48 PM   #24
wtbass21
My Ride: 04 330i6
What is NVH? And I heard that e9x m3 engine mounts can work for our e46s or am I thinking wrong and thinking of the e46 m?
wtbass21 is offline   Reply With Quote
Old 11-09-2011, 12:08 AM   #25
flipm3
NVH = Noise, Vibration, and Harshness
At some point over the past several years, BMW released a newer version of the E46 M3 Engine Mounts which are the same as the E90 M3. I am honestly not sure if it's the same part for the non-M but I will guarantee that the newer engine mounts are pretty nice. I just installed brand new/updated OEM Motor Mounts in my E46 M3 a year ago.
Old 11-09-2011, 12:54 PM   #26
SL Blak Soldier
My Ride: 3 Pedal SG S54B32
Send a message via AIM to SL Blak Soldier
interesting to read that you run oem mounts.
from what i hear, people also run oem e28(i think they are e28) tranny mounts. they just redrill the mounting bracket for the tranny.
SL Blak Soldier is offline   Reply With Quote
Old 11-10-2011, 08:34 AM   #27
ZeroSum
My Ride: 05 325
I use Bimmerworld group N engine mounts and RE tranny mounts and after 2+ years find them perfect, If I remember correctly I used slightly less torque on the nuts which helped with the vibration. I would say it is 15% more vibration than stock but combined with a DSSR and heavy shfiter knob I have no more trouble shifting when accelerating / braking hard.
ZeroSum is offline   Reply With Quote
Old 11-21-2011, 11:41 AM   #28
LivesNearCostco
I switched back to the UUC Black poly mounts last night, but this time with the UUC enforcer cups. Took it for one short test drive. Vibration is slightly more than stock but less than the BimmerWorld poly mounts with BW enforcer cups. My memory and butt dyno are not good enough to say if the UUC black with enforcer cups have more vibration than UUC black without TME cups. To further confuse things, I noticed that the top nuts on the Bimmerworld mounts might have been over-tightened by the indie shop, but I don't know if over-tightening the nuts will pre-compress the mounts and increase NVH or not. On all the bolt-through mounts (Vorshlag, UUC race), over-tightening makes the mount stiffer and increases NVH. But these mounts are not bolt-through.
New UUC black mounts with cups are 1.5 to 2mm taller than BimmerWorld mounts with cups, but the BimmerWorld mounts have been on the car for ~500 miles so might have compressed a little. If it were more of a track car that's also street driven, I'd stay with the BimmerWorld mounts or maybe try UUC red poly (not the bolt-through race ones). I'll be keeping the BimmerWorld mounts in hopes that next year I can buy a dedicated E36 or E46 for the track.
Note that for street cars, BimmerWorld's web site recommends and sells the Rogue Engineering poly mounts. For hard-core race cars, they sell solid aluminum motor and tranny mounts! My thanks to Gary at BimmerWorld and Rob Levinson at UUC Motorwerks for their help as I sort through transmission mounting options.
