E46 Xi Forum
Old 11-23-2011, 08:48 AM   #1
snp1973
My Ride: 2002 325xi
!Substantial Oil Leak Traced to CCV System ?? !
Our '02 has been leaking a small amount of oil for some time now. I would say that, I was adding 1 qt. every 5K. Last month I noticed a big increase in the amount of oil being deposited on our garage floor. The underside of the engine is pretty wet.
I discovered that the pipe to valve cover was broken (part # 11611432559). When I got ready to order it I started seeing info about "kits", and how everything should be replaced, etc. etc.
So... I have a couple of questions. (1) Is it reasonable to assume that this broken line could be what's dropping so much oil out? [Guess if the leak stops after I do this job I've answered my own question]. (2) Should I order the "kit" (part # ending in 237)? I'm on a tight budget right now to be honest. (3) Related to #2 - there are cheaper kits that do not include the breather. Is that o.k. or should I stick to the full kit?
snp1973 is offline   Reply With Quote
Old 11-23-2011, 09:20 AM   #2
jasonbimmer
My Ride: 2001 BMW 330xi
check valve cover gasket and oil filter housing gasket.
I dont know which kit you are talking about.
2009 Mazda RX-8 R3
2013 Toyota FJ Cruiser
2008 YAMAHA YZF-R6
Old 11-23-2011, 09:24 AM   #3
snp1973
My Ride: 2002 325xi
Valve cover gasket was done 1 year ago.
Here is a link to info concerning the kit:
http://blog.bavauto.com/5434/bmw-m54...30i-525i-530i/
Old 11-23-2011, 09:26 AM   #4
jasonbimmer
if you gonna do CCV, do all of them at once.
2009 Mazda RX-8 R3
2008 YAMAHA YZF-R6
Old 11-23-2011, 09:42 AM   #5
Kubica
My Ride: 2003 325xi
CCV job is much easier if you do OFHG at the same time.
The kit will save you money in the long run.
Read the DIYs on here.
