Sponsored by BAVSOUND
Thread Tools Search this Thread Rating: Thread Rating: 403 votes, 4.99 average.
Old 10-27-2011, 01:31 PM   #2081
owenxguo
My Ride: 02 M3 + 01 S2000
where is the steering wheel control box?
owenxguo is offline   Reply With Quote
Old 11-08-2011, 02:31 AM   #2082
mrmozz
My Ride: E46 touring
Hi Does it have a light sensor that would dim the screen when it's dark in the car? And brighten the screen when daylight? Or can it be connected to the cars stock instrument light dimmer? Or non of the above?
I'm imagining it will be rather annoying to have to go into settings on the dynavin every day to adjust the brightness.
Great forum btw!
mrmozz is offline   Reply With Quote
Old 11-08-2011, 04:42 PM   #2083
Dominic_M
My Ride: e46 M3
I GO Maps, where do I get them...?
Dominic_M is offline   Reply With Quote
Old 11-08-2011, 06:15 PM   #2084
jeffb325@NavigationSolutions
J&T Distributing
My Ride: BMW
Great forum btw!
It can be set to turn off OR dim (on D95) the screen by holding down the mute button.
jeffb325@NavigationSolutions is offline   Reply With Quote
Old 11-09-2011, 02:07 PM   #2085
mrmozz
Ok, thanks But why not have a light sensor? Even cheap mobile phones have had this for many years now. It works great. When I hook up my phone in the car the screen always adjust to a comfortable brightness day and night. They should really think about implementing this feature. Are the developers open for suggestions from the consumers?
Old 11-09-2011, 05:33 PM   #2086
Shade00
My Ride: 03 325Ci
I will probably be getting rid of my E46 before long but I have enjoyed my Dynavin V5. I use the USB function everyday and have liked the bluetooth capabilities. However, the one thing that continues to drive me crazy is that my bluetooth phone volume is almost intolerably low - I have the bluetooth phone volume turned up to 39 and can't hear callers that well in the city, and can barely hear them at all on the highway. Bluetooth music is much better. I'm thinking maybe my phone (Droid X) is limiting the volume because it recognizes the Dynavin as a bluetooth headset instead of a car kit. Oh well.
Edit: forgot to add that I am on the stock, non-HK amp. Volume is pretty low overall but I have considered trying the Dynavin's internal amp with 4 ohm 6.5" speakers to see if it helps.
Shade00 is offline   Reply With Quote
Old 11-15-2011, 11:39 PM   #2087
rmckinney
My Ride: 2003 325i
I've done DANe46's Epic Dynavin iPod Touch setup and really like the set up but was wondering if there was anyway to control the iphone using the dynavin touchscreen. The only thing that I have found that is comparable is the mimic module that works via bluetooth signal https://store.mp3car.com/ProductDeta...e=MimicsModule. Anyone know if this module could be integrated into the dynavin or any ideas on how to make this work?
rmckinney is offline   Reply With Quote
Old 11-24-2011, 02:47 PM   #2088
Laine
My Ride: 2006 330Ci+2008 535i
I have read through as many of the 105 FAQ pages as I can stand. I have a 2006 330 CiC (E46) without OEM navigation, and am investigating the Dynavin. Can you help me with the following:
1) I have factory Bluetooth (am able to use my iPhone over the radio). I saw that this will become obsolete with the install, but can I still use the factory microphone?
2) What are the added functions with the D99 unit? Would I need them if I have a factory Bluetooth system? Is D99 the V6 system?
3) What is the lead time for D95 and D99 orders?
4) Is the US TV tuner now available? (FAQ says hopefully by end of 2010).
5) Can I access email directly on-screen through iPhone interface?
6) I have a Passport QI45 radar detector and would like to pipe the small display unit in. Any advice on how you would approach that?
Thank you for the response.
Laine is offline   Reply With Quote
Old 11-24-2011, 04:35 PM   #2089
E36M3FORNOW
My Ride: CLK55 AMG, 02 M3 SMG
When are the units going to be in stock?
Looking to get one for my M3
E36M3FORNOW is offline   Reply With Quote
Old 11-26-2011, 10:45 AM   #2090
gray311
My Ride: 203 M3
Installation issues
Hi Everyone,
I have been reading up for a few months now on the Dynavin units and decided to plunk for one of the Android Units. To make things a wee bit more complicated I have a M3 with the OEM Sat Nav head unit, therefore all of the electronics are in the rear. Anyway, my issue:
5M extension cable run from rear to front (loads of fun that in a converible - not!), with the cabling plugged into the connection that was in the BG54 Radio unit. Dynavin unit connected to 5M cable at front of the vehicle.... and no power. Nothing! I checked the fuses and they are all fine (including the one on the Dynavin itself).
To make it a wee bit more confusing the wiring on the back of the Android unit is completely different from all of the other models!
Any ideas?
Name:	Dynavin Wiring (1).jpg
ID:	426596   Click image for larger version
Name:	Dynavin Wiring (2).jpg
gray311 is offline   Reply With Quote
Old 11-27-2011, 05:24 PM   #2091
shimal
My Ride: BMW 325i
miopocket
anyone have any experience with miopocket as a replacement front end for the windows side? its seems a lot like the other hack, but its free and contains 100% of freely-distributable content including media players, calendars, ebook readers, etc and can be used with any of the gps programs made for CE.
Website:
http://netfresco.com/MioPocket/default.aspx
shimal is offline   Reply With Quote
Old 11-27-2011, 10:57 PM   #2092
WillE46
My Ride: Topaz M3 Vert
Originally Posted by gray311 View Post
Hi Everyone,
Any ideas?
Looks like you have a V6 Dynavin unit but maybe a V5 Fakra harness. The V6 Fakra harness has the steering wheel control box up front on the headunit side of the harness; not the trunk side.
WillE46 is offline   Reply With Quote
Old 11-30-2011, 04:13 PM   #2093
Dominic_M
My Ride: e46 M3
it seems liek users must put something nasty on here to get some atention:
1. I have been asking to see where do i get the maps from and no one will reply. I bought the android version but do not have android phone. I have an Iphone and am not using any tetherding at this point. I would like to get an stand alone GPS software as the unit does not come with it.
I have actually purchased a copilot GPS for $20 but it is preveting me from download it on my PC and save it it to the micro card. On the copilot site, it states that I have to download from phone directly but I do not have internet on my DINAVIN as i am not tethering. Any help here?
2. As far as sound... There is too much background noise coming from the unit. I like the sound as it is ok if the music is really loud but in low volume the background noise is bad enough so you can hear it. I have played with the system setting but then again no luck on background noise.
3. I put the business stock radio and the DINAVIN unit back and fourth to test it and the volume is not high enough as the OEM. i would say DINAVIN is only 75% volume compared to OEM.
I hope i am doing something wrong as i like the unit but the volume i am not a fan of. I have also played with the setings on this and have all the equilizer knobs to 100% and still not loud enough. then again I am comparing with OEM. I hear lots of users here raving about the sound quality on their DINAVIN units that i just hope is as simple as adjusting some settings i may be over-looking.
Please help
Old 11-30-2011, 04:34 PM   #2094
ChiTownTrav
My Ride: 2004 325CI
Send a message via AIM to ChiTownTrav Send a message via Yahoo to ChiTownTrav
I'm running into the same issue with the backround noise with no luck playing in the settings.
ChiTownTrav is offline   Reply With Quote
Old 11-30-2011, 07:22 PM   #2095
boyfromnowhere
My Ride: beemer
Please help
This is the V5 thread....
Try here...http://forum.e46fanatics.com/showthread.php?t=839753
boyfromnowhere is offline   Reply With Quote
Old 12-03-2011, 06:25 AM   #2096
gray311
My Ride: 203 M3
Cheers WillE46 - In the end I took the Bimmer down to an auto electrician and discovered that it was faulty soldering within the Fakra cable's fuse box. Sorted and now up and running.
Old 12-04-2011, 02:23 PM   #2097
BimmerDoc
My Ride: E46 AWD, ///M Coupe
Send a message via AIM to BimmerDoc
Mp3 car
Website:
I would join mp3 car, you can get custom look BMW front ends and programs or contribute to design
BimmerDoc is offline   Reply With Quote
Old 12-05-2011, 11:33 AM   #2098
shimal
My Ride: BMW 325i
I looked around that website, but didnt find any information on miopocket specifically on the dynavin e46. Anyone else have any luck?
Old 12-05-2011, 02:47 PM   #2099
Garmac
My Ride: 2002 325i
same here, and it's horrible. I get background noise with ipod, and worse is with the AUX. I will take the unit out and check all the cabling... hope this is something that is easy to fix...
Garmac is offline   Reply With Quote
Old 12-05-2011, 03:46 PM   #2100
bimmer2u
My Ride: 2003 325i 104,000 mi
desktop screen
I have had my dynavin working great for some time now but I had it set to default to navigation on start up and now I forget how to get to wince desktop screen.
2003 325i 104,000 miles
bimmer2u is offline   Reply With Quote
Rate This Thread
