Miscellaneous BMW and E46 Parts
All other BMW and E46 Parts. Random car parts, BMW posters, lifestyle items, etc. |
#1 |
Modified Coding/Diagnostic Cable
I have 4 modified coding/diagnostic cable
- you can use the cable to disable DRL, and change settings in your car -for coding and diagnostic -real ignition detection -tested and working on INPA, NCS, GT1, SSS, carsoft 6.1 ![]() ![]() $35 each shipped to anywhere in the US....
![]() Last edited by gleech; 11-30-2011 at 07:43 PM. |
#2 |
I guess it should but Does it work with BMW scanner software 1.4?
Quick bump for you, I might be interested but the price is same as new and I don't know if those softwares are compatible with mac.
#3 |
no, this will not work on PA SOFT 1.4, they have their own cable....
and the Cable I'm selling is all brand new....and all the BMW software are windows based....
#4 |
Bummer. I don't have windows PC. I know the softwares you listed are more powerful than PA soft, but how much better are they? And how difficult it to setup with virtual PC. I might go virtual PC way if it is supported and better than PA soft.
#5 |
bump....
#6 |
Interested
Are these compatible with an 03 330i, and if so where could i get the appropriate software to use it? I see you list several choices in software, which do you feel is best for general diagnostic and feature activation? I won't be doing any power tuning.
#7 |
check your pm....
#8 |
Bourbon
Still for sale?
#9 |
I got 5 available right now....
#10 |
I'll take one
#11 |
OP, are you doing the pin/ resistor mod on these cables?
- UUC Stg. 1 LTW Flywheel - UUC SSK + DSSR - UUC TM +TME - UUC Rear Adjustable Control Arms - UUC Swaybarbarians - AST Sportline II - - RE Underdrive Pullys - RE FCABs - BMW Performance Control Arms - Shark Injector - EMP High Flow Water Pump - TMS Adjustable Endlinks - K&N CAI - - M3 Motor Mounts - For Sale |
#12 |
yes....
#13 |
can you disable post cat o2 with these?
#14 |
My Ride: 2004 E46 M3 SMG Vert
can i use this to program my signals to 3 blinks?
#15 |
if you have LCM SW version 4.0, then yes, you can program the 3 blink, otherwise, you need to buy LCM with SW version 4.0....
and I have one LCM 4.0 for sale....
#16 |
if you can disable post cat o2 on INPA or GT1 or SSS, then yes, you can use this cable....
![]() Last edited by gleech; 01-20-2012 at 06:54 PM. |
#17 |
#18 |
pull out your LCM, and you can see it on the label, check my picture here....
http://forum.e46fanatics.com/showthr...947&highlight=
#19 | |
#20 |
it's easy, just carefully pry the trim, and there's only two screws holding the LCM....
