E46 Xi Forum
Old 11-26-2011, 11:51 PM   #1
davesalkin
My Ride: 04 330 XI
Defrosting heat
Hi:
On my 04 330XI when the temp is about 50 degree's outside. I turn on the defroster to clear the windows. It clears the window but this huge blast of heat comes out. How do I control the temp? I have it set on lowest temp 59 inside the car, is it because it is 50 outside that the defroster blasts heat? I turn on the a/c at the same time but the air is still very warm? What would anyone suggest?
Dave
davesalkin is offline   Reply With Quote
Old 11-26-2011, 11:55 PM   #2
LittleChrist12
My Ride: 2003 BMW 325xi
Defrost, by nature, is designed to melt frost and ice off the windscreen. If you want to defog without melting your contacts to your corneas, turn on the A/C and the "Up" vent and increase the fan until it starts to take care of the fog. This will run the air through the defroster vents with whatever temperature you have set, rather than the preset "Defrost" option.
2003 BMW 325xi
2010 BMW M3 Sedan
LittleChrist12 is offline   Reply With Quote
Old 11-27-2011, 06:54 PM   #3
tomoyer
My Ride: 03 325xi, 01 325xi
Send a message via Yahoo to tomoyer
For light fog, best to use the AC on the upper/windshield setting and adjust your temp and fan spend. Not only will it defog the windows, it will also pull moisture out of the car more so than on the defroster setting (though in defroster mode, the AC compressor does run, but temperature is harder to adjust so that it isn't too hot/warm.
tomoyer is offline   Reply With Quote
Old 12-03-2011, 03:49 AM   #4
steve108819
My Ride: 2002 325xi
Originally Posted by davesalkin View Post
Hi:
Dave
You don't. If you're pushing the defrost button, the owners manual states that the car runs a defrost "program". It's going to be hot air. Follow the previous suggestions if you want it different.
steve108819 is offline   Reply With Quote
Old 12-03-2011, 10:02 PM   #5
xi_ter
My Ride: 2003 325xi
Can you park the car in a garage? Anything damp in the car? You might also try wiping your windows with an anti fog coating.
I really never have fogged or frosted windows and it's cold here now.
Old 12-05-2011, 01:26 AM   #6
Viktimize
My Ride: 2002 325i,2003 330ci
I don't mind the heat blast when the defroster turns on, but I'm not very fond of the defroster trying to crack my windshield everytime it turns on by putting the fan to full speed.
Viktimize is offline   Reply With Quote
