Sponsored by The Tire Rack
Old 12-22-2011, 07:00 AM   #61
zaharias
My Ride: Now has a 3lt :P
Is there any E46 (non M) coupe on 9.5x18 ET35..??
zaharias is offline   Reply With Quote
Old 12-22-2011, 01:40 PM   #62
SpoiledBrat
My Ride: 330Ci zhp
According to this: http://www.1010tires.com/wheeloffsetcalculator.asp those wheels will stick out 29mm more than my rear zhp wheels. I don't think their going to fit, but that'd be pretty awesome if they do.
SpoiledBrat is offline   Reply With Quote
Old 12-22-2011, 11:44 PM   #63
SkrApUNB
My Ride: 03 325i
if i can do 18 x 9.5et35 on my sedan, you can do it on your coupe.
-Brandon
SkrApUNB is offline   Reply With Quote
Old 12-23-2011, 03:04 AM   #64
zaharias
Thumbs Up
Thanks! Very useful site..
Thanks mate! I was looking at your pics yesterday.. (By the way, your sedan is very nice )
I was thinking the same thing.. if they fit your sedan, they will fit my coupe also..
Any rubbing..?? Any inner wheel lip clearance issues..??
(my set up= Koni FSD+Eibach Pro Kit springs, no fender mods)
Iam thinking of a squared Apex arc-8 set up 9.5x18 ET35..
Old 12-23-2011, 09:12 AM   #65
bigjae1976
bigjae1976's Avatar
My Ride: A car
Old 05-08-2012, 05:37 AM   #66
zaharias
Talking 9.5 x 18 ET35 - 255/35 f/r
Old 05-08-2012, 10:37 PM   #67
Steven747
My Ride: 05 330ci
here my 05 330ci on coil overs
9.5 squared with 225/40/18 pilot sport 2's rear fenders are shaved and -2 camber offset is 25 with a 10 mm spacer on every corner offset was 35 to start *
fenders are not rolled or pulled.
running a 10mm spacer on all 4 corners
Name:	epic bimmer pic 330ci.jpg
ID:	450832   Click image for larger version
Name:	in n out photo shoot.jpg
Old 05-12-2012, 04:09 PM   #68
zaharias
Old 05-13-2012, 08:54 PM   #69
Steven747
My Ride: 05 330ci
^^^ u need a mad drop browski
Old 05-14-2012, 01:05 AM   #70
zaharias
Hahaha.. I wish i could.. Iam on Koni FSDs & Eibach Pro Kit springs. Front is ok for me.. I wish i could lower the rear a bit. I like the ride of my set up, i don't want coilovers for now, maybe later..
Old 05-14-2012, 11:00 AM   #71
Steven747
My Ride: 05 330ci
thats perfect run the same setup as me. buy racelands and just use the fronts with your koni;s in the rear and either race land springs or custom liners. i have bilstein in the rear with that setup and its very very good and cheap.
Old 06-27-2012, 12:52 AM   #72
zaharias
Old 06-30-2012, 08:23 AM   #73
Mc 007
My Ride: 325ci Performance
looks very good
Mc 007 is offline   Reply With Quote
Old 07-03-2012, 02:54 AM   #74
zaharias
Smile
Originally Posted by Mc 007 View Post
looks very good
Thanks!! Its nice. I wish i could go lower at the rear. But its ok as it is cause our roads suck!!
Old 11-05-2012, 04:40 PM   #75
NASAE30
My Ride: 01 330CI,99 540iT
I love the wheel and want to get a set for my NASA TTD 330ci, At the least a 255 or wider R compound tire Whats the limit on wheel and tire combo under stock rolled bodywork? Suspension is H&R sports and bilsteins. A true coilover will be next.
17x? 18x? et? spacers?
Zach Mickle
Event Director Nasa Mid Atlantic Autocross
Zach@get-fast.net
NASAE30 is offline   Reply With Quote
Old 11-05-2012, 05:27 PM   #76
Joe@ApexRaceParts
My Ride: E36 M3
Zach,
The widest set up for your E46 is either a 17x9" ET42 square with a 255/40/17 tire or 18x9" ET42 square with a 255/35/18 tire. Either set up will need a 12mm spacer in the front. If you were using a street tire I would say that you could get by with a 5mm spacer but the R compound tire would need the wider spacer. Either of these set ups will need camber plates in the front to fit the wider front tire. Down the road a 265/35/18 tire can fit with enough negative camber in the front and fender rolling in the rear.
| * Joe V. | 888.499.9135 x803 | joe@apexraceparts.com | Facebook | Blog |
Joe@ApexRaceParts is offline   Reply With Quote
Old 11-05-2012, 07:35 PM   #77
NASAE30
Thanks Joe. That was exactly the answer I was hoping to get. I tracked a GTS2 330i yesterday and now I'm all gung ho for my build. I still have to figure out the rest of the car but ARC-8's are going to be the wheels for sure. Thanks for the info man.
Zach Mickle
Zach@get-fast.net
Old 11-05-2012, 07:42 PM   #78
zan
My Ride: 06 m3 sold/ 03.5 m3
Originally Posted by Eddy@APEXraceparts View Post
Eddy what are the specs?? Thanks
Current ride: 2003.5 M3 COUPE 6 SPEED SILVER GRAY DD
zan is offline   Reply With Quote
Old 11-06-2012, 11:44 AM   #79
Joe@ApexRaceParts
My Ride: E36 M3
That E46 M3 is using 18x10" ET25 wheels square with a Hankook race slick.
Old 11-06-2012, 12:20 PM   #80
KrisBoss
My Ride: Custom AA SC E46 M3
Send a message via AIM to KrisBoss Send a message via Skype™ to KrisBoss
I want to thank David@ApexRaceParts for helping me out on deciding what setup to run and answering all of my questions!
My setup:
Apex ARC-8 18x9.5 ET22 Front -1.8 camber wrapped in Nitto NT05 265/35/18
Apex ARC-8 18x10.5 ET27 Rear -2.5 camber wrapped in Nitto NT05 285/35/18
I had to roll my fenders, but that wasn't a big deal at all. The wheels sit flush with the fender and spacers are NOT needed or required.
Pictures:
Follow Me: Facebook | Youtube | Zima Motorsports
CLICK HERE to check out my Custom Exhaust Build
2004 BMW E46 ///M3 Active Autowerke Supercharged Stage '5' Custom
KrisBoss is offline   Reply With Quote
apex, arc-8, gallery, track, wheels
