The Tire Rack's Tire & Wheel Forum
Use this forum to discuss anything in relation to wheels to tires to offsets. Sponsored by The Tire Rack |
#61 |
Is there any E46 (non M) coupe on 9.5x18 ET35..??
#62 |
According to this: http://www.1010tires.com/wheeloffsetcalculator.asp those wheels will stick out 29mm more than my rear zhp wheels. I don't think their going to fit, but that'd be pretty awesome if they do.
#63 |
if i can do 18 x 9.5et35 on my sedan, you can do it on your coupe.
-Brandon ![]() |
#64 | ||
(By the way, your sedan is very nice )I was thinking the same thing.. if they fit your sedan, they will fit my coupe also.. ![]() Any rubbing..?? Any inner wheel lip clearance issues..?? (my set up= Koni FSD+Eibach Pro Kit springs, no fender mods) Iam thinking of a squared Apex arc-8 set up 9.5x18 ET35..
#65 |
#66 |
![]() Last edited by zaharias; 05-09-2012 at 08:21 AM. Reason: links |
#67 |
here my 05 330ci on coil overs
9.5 squared with 225/40/18 pilot sport 2's rear fenders are shaved and -2 camber offset is 25 with a 10 mm spacer on every corner offset was 35 to start * fenders are not rolled or pulled. running a 10mm spacer on all 4 corners
![]() Last edited by Steven747; 05-08-2012 at 10:45 PM. |
#68 |
#69 |
^^^ u need a mad drop browski
#70 |
Hahaha.. I wish i could.. Iam on Koni FSDs & Eibach Pro Kit springs. Front is ok for me.. I wish i could lower the rear a bit. I like the ride of my set up, i don't want coilovers for now, maybe later..
#71 |
thats perfect run the same setup as me. buy racelands and just use the fronts with your koni;s in the rear and either race land springs or custom liners. i have bilstein in the rear with that setup and its very very good and cheap.
#72 |
#73 |
My Ride: 325ci Performance
looks very good
#74 |
Thanks!! Its nice. I wish i could go lower at the rear. But its ok as it is cause our roads suck!!
#75 |
I love the wheel and want to get a set for my NASA TTD 330ci, At the least a 255 or wider R compound tire Whats the limit on wheel and tire combo under stock rolled bodywork? Suspension is H&R sports and bilsteins. A true coilover will be next.
17x? 18x? et? spacers?
#76 | |
The widest set up for your E46 is either a 17x9" ET42 square with a 255/40/17 tire or 18x9" ET42 square with a 255/35/18 tire. Either set up will need a 12mm spacer in the front. If you were using a street tire I would say that you could get by with a 5mm spacer but the R compound tire would need the wider spacer. Either of these set ups will need camber plates in the front to fit the wider front tire. Down the road a 265/35/18 tire can fit with enough negative camber in the front and fender rolling in the rear.
#77 |
Thanks Joe. That was exactly the answer I was hoping to get. I tracked a GTS2 330i yesterday and now I'm all gung ho for my build. I still have to figure out the rest of the car but ARC-8's are going to be the wheels for sure. Thanks for the info man.
#78 |
My Ride: 06 m3 sold/ 03.5 m3
![]() Current ride: 2003.5 M3 COUPE 6 SPEED SILVER GRAY DD |
#79 |
That E46 M3 is using 18x10" ET25 wheels square with a Hankook race slick.
#80 |
My Ride: Custom AA SC E46 M3
I want to thank David@ApexRaceParts for helping me out on deciding what setup to run and answering all of my questions!
My setup: Apex ARC-8 18x9.5 ET22 Front -1.8 camber wrapped in Nitto NT05 265/35/18 Apex ARC-8 18x10.5 ET27 Rear -2.5 camber wrapped in Nitto NT05 285/35/18 I had to roll my fenders, but that wasn't a big deal at all. The wheels sit flush with the fender and spacers are NOT needed or required. Pictures: ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]()
Follow Me: Facebook | Youtube | Zima Motorsports
CLICK HERE to check out my Custom Exhaust Build 2004 BMW E46 ///M3 Active Autowerke Supercharged Stage '5' Custom ![]() |
| Tags |
| apex, arc-8, gallery, track, wheels |
